Question about Western Digital Caviar SE16 (WD5000AAKS) 500 GB SATA Hard Drive
Raid Status: Offline?
I installed a new drive yesterday and tried to setup a Raid-0 set. The two drives are identical (make/model) 500GB sata-II. Unfortunately, one of the drives was not formatted (or the wrong format) and when I rebooted, the system hung at the Raid ID/config step.
Now, when I try to create a RAID set, the motherboard's built-in Raid utility reports that the Status of one drive as ''Off Line''. The drive is otherwise fine. I have tried unplugging power and swapping data cables, and the problem followed the drive. I have reformatted both drives as well as run ''FixMbr'' and ''FixBoot'' from the Windows Recovery Console to no avail.
There is no way to re-enter the Raid setup utility with both drives connected (I can if I unplug the offending drive, which is no help). Western Digital tells me there is no ''Status'' recorded to the drive and the problem must be with the Raid Controller on my MoBo. (I have updated to the latest BIOS, dated 1/13/09). But as I noted, when swaping cables, the problem followed the drive (changing from ''ID: 2'' to ''ID:1'').
How do I reset the ''Status'' om my drive so I can setup my Raid?
  • rjivaro May 11, 2010
    Sounds like a drive failure. Try replacing it.
5 Suggested Answers
SOURCE: Bad logic board on Western Digital Caviar SE16 500 GB SATA Hard drive
i Have a 1tb with the same problem i can't get to match the dcm.
Does anyone know where i can get a 1TB with DCM#HBRCHV2AB?
I will buy it from anyone who has one
Posted on Apr 17, 2009
mrrichardlbo
  • 59 Answers
SOURCE: Western Digital Reset / Set Hard Disk Size ?
hit F1 when you bootup dont let windows come on . Go in you Biso to set you new hard drive.dont forget to F10 to save changes...Good Luck
Posted on Aug 16, 2009
jimmydwyer
  • 10 Answers
SOURCE: Windows Server trying to boot from external hard drive
in the bios, check that Hard Drive is before External Devices in the boot order.
Posted on Aug 24, 2009
pctech1
  • 1940 Answers
SOURCE: Hi, I have an NAS
Download TestDisk here: http://www.cgsecurity.org/wiki/TestDisk_Download
TestDisk is a powerful free data recovery software! It was primarily designed to help recover lost partitions and/or make non-booting disks bootable again when these symptoms are caused by faulty software, certain types of viruses or human error (such as accidentally deleting a Partition Table). Partition table recovery using TestDisk is really easy.
TestDisk can
  • Fix partition table, recover deleted partition
  • Recover FAT32 boot sector from its backup
  • Rebuild FAT12/FAT16/FAT32 boot sector
  • Fix FAT tables
  • Rebuild NTFS boot sector
  • Recover NTFS boot sector from its backup
  • Fix MFT using MFT mirror
  • Locate ext2/ext3/ext4 Backup SuperBlock
  • Undelete files from FAT, NTFS and ext2 filesystem
  • Copy files from deleted FAT, NTFS and ext2/ext3/ext4 partitions.
TestDisk can run under
  • DOS (either real or in a Windows 9x DOS-box),
  • Windows (NT4, 2000, XP, 2003, Vista, 2008, Windows 7 (x86 & x64),
  • Linux,
  • FreeBSD, NetBSD, OpenBSD,
  • SunOS and
  • MacOS X
Source files and precompiled binary executables are available for DOS, Win32, MacOSX and Linux from the download page
TestDisk can find lost partitions for all of these file systems:
  • BeFS ( BeOS )
  • BSD disklabel ( FreeBSD/OpenBSD/NetBSD )
  • CramFS, Compressed File System
  • DOS/Windows FAT12, FAT16 and FAT32
  • Windows exFAT
  • HFS, HFS+ and HFSX, Hierarchical File System
  • JFS, IBM's Journaled File System
  • Linux ext2, ext3 and ext4
  • Linux LUKS encrypted partition
  • Linux RAID md 0.9/1.0/1.1/1.2
    • RAID 1: mirroring
    • RAID 4: striped array with parity device
    • RAID 5: striped array with distributed parity information
    • RAID 6: striped array with distributed dual redundancy information
  • Linux Swap (versions 1 and 2)
  • LVM and LVM2, Linux Logical Volume Manager
  • Mac partition map
  • Novell Storage Services NSS
  • NTFS ( Windows NT/2000/XP/2003/Vista/2008/7 )
  • ReiserFS 3.5, 3.6 and 4
  • Sun Solaris i386 disklabel
  • Unix File System UFS and UFS2 (Sun/BSD/...)
  • XFS, SGI's Journaled File System
Posted on Feb 17, 2011
Sata Hard drive errors and Raid errors
See this answer
Reboot your system and hit F2 as soon as you see the Dell startup screen (the options are F2 for setup, F12 for boot sequence).
In the System Setup screen, do these steps.
Select Drives:
Make sure your Diskette Drive (3.5 floppy) is set properly (Usually set to Internal)
Make sure that "Drive 0: SATA-0" drive is set to "ON"
Go to "SATA Operation":
Your system proabaly came set to "RAID Autodetect / AHCI" - THIS SETTING CAUSES YOUR SYSTEM TO GO INTO AN IDE LOOP AND DOESN'T ALLOW IT TO FIND YOUR FACTORY INSTALLED SATA DRIVE.
CHANGE THE SATA OPERATION SETTING TO "COMBINATION"
Reboot - make sure that the boot sequence is set to CD rom before HD and make sure that the reinstall CD is in the drive. Setup will load, hit enter to reinstall XP. Your HD should now be detected and you should see the licensing agreement.
If you have your files backed up I reccommend deleting the partition and reformatting prior to installing XP, it will give you that option after the license agreement.
Once you have successfully reinstalled the OS, Dell reccommends that you change the SATA Operation setting back to RAID AUTODETECT / AHCI (or back to whatever your factory setting was) to avoid any problems with other IDE devices installed on your system.
Source
Restore Complete but Stuck on DRMK
Sep 03, 2012 | Dell Dimension 9150 (DIM915MIN) PC Desktop
Model: HDD2H,does not detect the drive,took out the drive from caddy and plugged it in the PC, shows RAW file system. One of them can be detected by bios but says 0MB,second drive shows as 500GB. Dont know...
If it was a "striped" RAID setup, then "half" of each file on the disk-drive has been lost,
including half of each entry in the Table-Of-Contents, when you try to "browse" either disk-drive.
Both disks will be "nonsensical".
If it was a "mirrored" RAID setup, then one disk is probably 100% "good", and one disk is probably 100% "bad", i.e., you now have just ONE copy of each file, rather than having TWO identical copies. Buy a new 500GB (or larger) disk-drive, and use the RAID-software to "rebuild" the "mirroring" (by copying everything from the "good" disk to the "empty" disk) setup.
Nov 03, 2010 | Iomega Computers & Internet
Building new machnie. 2 x 500GB HDD. Using Adaptec card. Have to build OS first as system has no FDD. Build OS (no problems). Insert RAID card, and connect SATA cables, to set RAID 1, and go into RAID BIOS...
You cannot really set up RAID of the machine, toy cannot transfer the drive identities as you are seeing... you simply MUST set it up on the machine it is to be used in, it is that simple, unless the machines are hardware identical... Could you not use a USB, drive to work from, instead of FDD? or perhaps a USB to DVD dongle? or a USB FDD? In any event, you will have to find a way, to do it, on that machine you that wish to use, that RAID on.
Mar 21, 2010 | Computers & Internet
As I stated earlier I have ASUS K8S-MX Motherboard, but when I connect IDE 80GB drive with 500GB SATA drive it does not detect my 4 SATA partitions, instead says it is only 500GB unformatted single...
Check your AHCI (or ACHI, can't remember) settings in your BIOS. Turn them off, use "standard pata mode" even though you're using a SATA drive, and try again.
Dec 18, 2009 | ASUS K8S-MX Motherboard
How were the partitions created on the SATA? Are they RAID configured from the other system? Does the new motherboard have the same support for your HD as the other system? Check the setup in the BIOS screen on both systems to make them identical as much as you can. According to Tom's Hardware: "In the SATA port configuration place you have up to four "mode" choices: IDE (or PATA) Emulation, native SATA, AHCI, or RAID." Check this section. Circe@pctechsonline.com
Dec 13, 2009 | ASUS K8S-MX Motherboard
I am using a single SATA II Drive in a new system, GIGABYTE GA-MA790X-UD4P, AMD 790X & SB750 chipsets. I know I can let the SATA II be a "Native IDE" but isn't that loosing any benefit of the SATA II...
The "Native IDE" mode causes the motherboard to "report" to the Operating System that the installed SATA drive is an IDE drive, rather than reporting "no IDE drives installed", and then requiring the Operating System to load a SATA device-driver to interface with the SATA drive.
Using RAID to "mirror" your hard-drive is a very-cool way to provide a "real-time" and "up-to-date" backup.
Should one of your drives suddenly "die", the other will continue to work, and you can buy another hard-drive, re-establish the "mirroring", and continue to work productively -- no fiddling with offline/stale backups.
Sep 18, 2009 | Gigabyte GA-MA790X-UD4P Motherboard
Installing windows xp on my SATA h.d. and setup program cant find
Lookup your Motherboards Brand and Model. Google to find the Brands website, as most brands have a download section. Look for a file in downloads for YOUR MODEL motherboard with a name along the lines of SATA RAID DRIVER, download it and follow the manufacturers instructions for using it. Most will want you to copy all the files inside the SATA RAID DRIVER zip file onto a floppy and when windows xp setup is loading at the bottom one of the first things it says is "Press F6 and insert the SATA RAID Driver floppy diskette you just made. Then you are allowed to select the required driver for your motherboards SATA chip. Allowing windows to know what settings to use to communicate and see your drive. Hope this helps.
Jun 20, 2009 | Computers & Internet
RAID rebuild problem
Your NUMBER 1 ENEMY when doing multiple drives in a single case is HEAT!!!! Make 100% sure those drives are COOL!!! if not you will continue to have issues.
Dec 10, 2008 | Biostar P4M800-M7A Motherboard
Slow transfer from SATA II (IDE) drive to 3 SATA II Drives configured as RAID (1). Drives wouldn't format until we installed the OS onto the RAID -- but it wouldn't install completely. We boot from the...
It appears you have made an error with the RAID configuration. RAID 1 is mirroring and requires an EVEN number of drives unless one is a hot spare. Also, RAID 1 is for redundancy and is slower than a single drive or RAID 0. Verify your RAID configuration and make sure you have RAID 1 and not RAID 0 or RAID 5 which can be an even or odd number of drives.
Nov 17, 2008 | Computers & Internet
1 TB HD of Samsng is not recognized
some motherboards and processors are compatiable with certain hd's only. Here is a list:
Pentium: 2GB through 5GB
Pentium 2:5GB through 20GB
Pentium 3: 20GB through 40GB
Pentium 4: 40GB through 500GB
Pentium D: 40GB through 1TB
Celeron: 2GB through 500GB
All AMD's: 300MB to whatever.
so, that's probably your problem. I suggest
Jun 05, 2008 | Asrock K7VT4A-Pro Motherboard
Western Digital Caviar  SE16 (WD5000AAKS) 500 GB SATA Hard Drive Logo
397 people viewed this question
Top Western Digital Computers & Internet Experts
Arora Singh
Arora Singh
Alun Cox
Are you a Western Digital Computer and Internet Expert? Answer questions, earn points and help others
