Question about Wolfgang Puck BFPR0035CF Food Processor
Hello I have a Wahl zx590 small food processor. When I plug it in without anything in it, it works fine, but as soon as I put something in it, it doesn't spin. It makes the noise but no cutting. Can anyone help? Christophe Thank you
    Problem Solver:
  • 5 Answers
Most likely you have stripped out the drive linkage at the coupling. (Where the motor seperates from the blades)
I am not specific to this device. And it's probably not going to be cost-effective to try to get the parts to fix the cheaper models. But most devices (with this problem) use a drive coupling made of a square or star shaped plastic drive hole in the bowl that mates with a matching end on the drive shaft made out of plastic. These round out if the motor starts with out fully engaging the drive first, or if the bowl is over loaded.
btw. This happened instantly when I followed my wife's suggestion and tried to make icy frozen drinks with her new Oster hand blender. It destroyed all the plastic parts completely. Leaving only the motor inside spinning uselessly. $24 USD completely destroyed. -- sithigh
Posted on Jul 20, 2009
  • 137 Answers
Somehoe the blade inside the jar ahs come loose, look on top of the blade you should see a nut if not you should see threads if you see threads then you have lost the nut.
Posted on Mar 02, 2009
Very frustrated with kitchenaid food processor - using any slicing disk only the first batch of food works, when you put in the 2nd batch nothing happens
Mine is older and works fine once I realized bowl has to be snapped into place before the cover and then the cover has to be locked in. This activates a small button at the base of the bowl that activates a safety switch.
Jan 03, 2015 | KitchenAid Food Processors
Tip
The cusinart pro classic food processor is not working ?
Try this procedure:-- It usually goes something like this, with minor variations depending on model number:1.Remove the work bowl completely from the base
2.Plug the food processor in and turn it on
3.Use a pen to depress the dark grey/black button on the base – if it spins, proceed
4.Put the work bowl on the base with the handle facing the front of the food processor – slide the work bowl until it locks - the white tabs show in the openings on the bottom of either side of the work bowl
5.Place the lid on the work bowl with the tab slightly left of the center of the work bowl handle – slide the lid counterclockwise until it won’t slide any more
6.Place the pusher sleeve in the feeder tube of the lid with the lock facing the front of the food processor (may vary depending on model)
7.Slide the lock to the right into the locked position
The food processor should now work.
This will help.Good luck.
on Mar 08, 2010 | Food Processors
User manual for jamesmartyn food processor
Actually the James Martin processors are distributed by Wahl. You might try contacting them here to see if they can help you find your manual.
http://www.wahlglobal.com/united-kingdom/contact.html
Sep 05, 2014 | Food Processors
The blender jug from the ZX717X-1 food processor has seized up
hi, where can i get the manual for this food processor?.
Thanks
Feb 27, 2013 | Food Processors
Can't get cuisenart pro 11 to start
I am assuming you have a DLC-8S Pro Custom 11, and not another Cuisinart food processor.
Remove the work bowl and all other parts completely from base.
Plug the base in, and turn it on.
Use a pen to press in the dark grey or black button on top of the base.
If you hear a spinning or other noise, the motor is still good.
Now that you have verified that the motor is good:
Put each work bowl piece on one at a time - if you don't out it on one at a time, it will not lock in properly.
Put work bowl on with work bowl handle facing front, make sure bowl locks.
Put lid on with hollow feed tube facing the back of the food processor.
Put pusher sleeve into lid's feed tube, with sliding lock switch facing the front of the food processor.
You should now be good to go.
Apr 07, 2009 | Cuisinart DLC-2011 PowerPrep Plus Food...
Machine on but not working
The video is generic, and may actually show a different model with completely different assembly instructions. For the DLC-8S and DFP-11 series, you want work bowl handle facing the front of the processor, feed tube on lid facing back of the processor, and sliding lock switch facing the front of the machine. For the DLC-2011, you want work bowl handle facing front, lid lined up with work bowl handle, and metal element hanging from pusher facing front.
To make sure the motor is working first, remove the work bowl, blade, etc. completely from the base of the food processor. Plug the base in and turn the food processor on. Then use a pen to press in the dark gray or black button on top of the processor - if it makes a sound, your motor is good. If it doesn't, call Cuisinart and get your processor repaired.
-Tha Mp3 Doctor
Mar 31, 2009 | Cuisinart DLC-8S Pro Custom Food Processor
I have a cusinart pro classic, went to use it yesterday, filled it and turned in on, got nothing. i tried a different plug and still nothing. it is not even making a sound.
1. Remove the work bowl completely from the base
2. Plug the food processor in and turn it on
3. Use a pen to depress the dark grey/black button on the base – if it spins, proceed
4. Put the work bowl on the base with the handle facing the front of the food processor – slide the work bowl until it locks - the white tabs show in the openings on the bottom of either side of the workbowl
5. Place the lid on the workbowl with the tab slightly left of the center of the workbowl handle – slide the lid counterclockwise until it won’t slide any more
6. Place the pusher sleeve in the feeder tube of the lid with the lock facing the front of the food processor (may vary depending on model)
7. Slide the lock to the right into the locked position
-Tha Mp3 Doctor
Oct 19, 2008 | Cuisinart DLC-10S Pro Classic Food...
Food processor
-Tha Mp3 Doctor
Apr 20, 2008 | Cuisinart DLC-10S Pro Classic Food...
It just stopped working
Remove the work bowl from the base of the food processor, and separate the bowl, lid, and pusher sleeve.
Plug the base into the wall outlet, turn the food processor ON, and then use a pen to press in the dark grey or black button on top of the base of the food processor - if you hear some kind of noise, then your motor is still good.
Put the work bowl on first, with the handle facing the front of the food processor.
Put the lid on, with the hollow feed tube facing the back of the processor.
Put the pusher sleeve in the lid, with the sliding lock switch facing the front of the processor.
Your processor should now turn on.
If your food processor still does not turn on, call Cuisinart and see if you are eligible for an in-warranty repair - it has a 3-year warranty.
-Tha Mp3 Doctor (also loves Cuisinart)
Oct 29, 2007 | Cuisinart DLC-10S Pro Classic Food...
Wolfgang Puck BFPR0035CF Food Processor Logo
354 people viewed this question
Top Wolfgang Puck Food Processors Experts
EugenesDIYDen
EugenesDIYDen
L Pfaff
L Pfaff
Are you a Wolfgang Puck Food Processor Expert? Answer questions, earn points and help others
