Question about Panasonic NN-S592 Microwave Oven
Panasonic NN-S592 Microwave keeps turning off during use
My Panasonic Microwave turns off by itself while in use. Sometimes within a few seconds or sometimes after a minute or longer. This happens when using timer mode or even when using the "sensor reheat" mode. Sometimes it works fine.
The microwave does not loose power, as the clock keeps showing the correct time.
This started happening a few months ago. When it works, it works fine.
Please help!
Thanks,
SOURCE: The microwave does not work.
check control circuit and related control panel circuit
Posted on Oct 01, 2007
MicrowaveSvc
  • 9047 Answers
SOURCE: PANASONIC INVERTER MODEL NN-S76OWF
While your exact model in not available for download, you should be able to find one close enough to work here:
http://panasonic.com.au/support/downloads/file_type_results.cfm?fileTypeID=2&productCategoryID=87
We're happy to help and we appreciate your thoughtful rating of our answer.
Posted on Dec 07, 2007
MicrowaveSvc
  • 9047 Answers
SOURCE: Microwave panasonic nn v453 swiches
In most cases, this is a problem with the inverter or a bad magnetron.
Due to the lethal voltages used and produced, I do not recommend that an inexperienced person work on these.
I would recommend that you contact your nearest Panasonic-authorized servicer. You can find one here.
Posted on Jun 29, 2008
SOURCE: Panasonic Model No. NN-S933BF Microwave Oven
could it be that i didn't follow the manuel because i got it second hand or is it because something is wrong with it,and i have to get it fixed.
Posted on Oct 21, 2008
MicrowaveSvc
  • 9047 Answers
SOURCE: Panasonic Microwave Oven Stops After 15 seconds - Never Heats
If it stops at 16 seconds and is a sensor model, it probably has a defective humidity sensor.
You can order Panasonic parts from Tritronics.
If you reconsider, you can find an authorized Panasonic servicer here.
Posted on Oct 22, 2008
NN-T563 shuts off after 5 seconds
We recommend you use the below link to locate an authorized service center. Panasonic microwaves have a 5 year warranty on the microwave.
www.panasonic.com/repair
Apr 12, 2014 | Panasonic NN-S563 Microwave Oven
Microwave shutts off after 2 seconds/
See if this describes what's happening:
  • Put in time, push start and unit runs for 2 seconds, relay clicks, unit goes off. Cook time on display goes off and clock time comes back. Bad upper interlock switch and charred connector
If so, see
http://207.234.249.73/mwd/safety.txt
http://207.234.249.73/mwd/disassembly.txt
http://207.234.249.73/mwd/doorsw.txt
Otherwise, if the digital programmer circuit / controller does not get a feedback signal from the inverter for a period of 3 seconds, the controller will stop the cook cycle.
It may be a loose connection in the wiring between the inverter, magnetron, and/or control board, or maybe one of those components has failed.
Due to the lethal voltages used and produced in inverters, I do not recommend that an inexperienced person work on these.
You can find an authorized Panasonic servicer here.
In Canada, you can find an authorized Panasonic servicer here.
If yours is not a Panasonic, please reply back with your brand and model number so we can help you.
May 22, 2010 | Panasonic NN-S592 Microwave Oven
Panasonic NN-T994SF Microwave Oven quits after 15 seconds
my microwave shuts off after a few seconds. is there a fuse that needs replacing?
Feb 01, 2010 | Panasonic NN-T994SF Microwave Oven
Microwave NN - T290SA starts but shuts off after a few seconds. Is it worth repairing?
usually this is the temeperature sensor that is faulty or that you have pushed the unit back against the wall too far and not enough airflow to allow it to remain within the tolerence levels of heat generation.
New sensor is about $30.
Please rate our help to keep Free service online ++++ Thanjks for using Fixya
Sep 02, 2009 | Panasonic NN-T790SA Microwave Oven
Microwave Oven shuts off after 5 seconds
What type of microwave is it (make and model)?
May 25, 2009 | Panasonic NN-S592 Microwave Oven
Panasonic NN-S592 Microwave Oven Logo
108 people viewed this question
Top Panasonic Microwave Ovens Experts
William Miller
William Miller
Jerry Greenberg
Jerry Greenberg
SHARCNET-USA
SHARCNET-USA
Are you a Panasonic Microwave Oven Expert? Answer questions, earn points and help others
