Question about Kenmore 95002 / 95004 Electric Kitchen Range
Oven gets very hot when all cntrols are turned off
When oven is off , when the whole stove is off ,the oven gets so hot it sets the smoke alarm off and it displays the code F1 whats that?
  • jjstrand1313 Mar 07, 2009
    Nothing but the clock is running, but the bake function is glowing orange and only the breaker switch can stop the madness. I have searched for a solution on the web but noone has an answer. The whole thing is rediculous.
  • Kenmore Master
  • 3,361 Answers
Your electronic oven control has malfunctioned and must be replaced.
Posted on Feb 27, 2009
  • 107 Answers
The bake relay on the oven control is stuck..This is a non servicable part and must be replaced. In this condition the sensor/thermostat will not turn it off. Dangerous condition, repair ASAP
Posted on Mar 14, 2009
  • Chris Mar 20, 2009
    I meant the relay is non servicable and the entire control to be replaced, not the oven. Sorry for not being more clear.
I already purchased a 613 dollar oven based on the first recommendation from Chris7084. Nutts!
Posted on Mar 21, 2009
I have a kenmore range # 79094152310. And when I turn on the right front burner, the top of the oven gets so hot you would get burnt if you touched it, is this normal for this stove?
no --not normal
stoves even glass top stoves are only hot in vicinity of the hot plates
if the whole top is hot , call an electrician in to check the systems
Oct 02, 2016 | Kenmore Kitchen Ranges
Our new home has a GE XL44 gas stove the top works fine but when I use the oven it smokes and sets off the smoke alarms.The stove is over 3 years old Any ideas before I have to call the repairman in?
A gas stove shouldn't smoke. Is is clean? There is some grease that has eluded your cleaning efforts of interior surface?
Here are some tips that may help you resolve this problem:
Check the broiler flame. If the broiler flame is not adjusted properly, you could be creating soot from the burner flame.
Position the items that your are broiling lower so that they do not splatter grease up onto the broiler baffle.
Use a broiler pan that will drain grease and drippings down below the top surface.
Broiling many items will naturally produce some smoke. If you have the oven door closed when broiling then the only place that the smoke can go is up and out of the oven vent. If you partially open the oven door, some of the smoke will come out of the door opening.
You may have residue on the top walls of the inner oven cavity. Do you have self-clean feature on your range to clean the oven? Follow all of the procedures in your owner's manual to properly clean the oven using the self-clean cycle. This may clear out any undetected residue that could be causing excessive smoke during broiling.
Aug 26, 2015 | GE Kitchen Ranges
Did a cleaning on the stove. in middle of cleaning the stove started to smoke so they hit the off button. Now the stove wont open. How do we get the stove oven door to open?
All you have to do it wait and it will unlock itself. It just gets very hot so the stoves are made to seal themselves until cool!
Aug 17, 2011 | Ovens
Smoke comes out of grill on electric cooker
This sounds like some of the power wiring, or leads which go to the "electric" burners. the smoke is a wire based or very chemical based smell. that in it self is toxic. when it comes to something as major as this you should for your own safety contact the seller if it is under warranty. The voltages and risk or burns electrical and heat wise are not worth the risk to your person and or life and or property.
Nov 10, 2009 | Stoves 720EF Electric Double Oven
Oven smells like gas when on
If the oven is new and has never been used, it should be cured before using. There is a curing your oven page in all manuals before use. You have to wash and burn off all the chemicals used in making the thing. Are u sure it sets off the smoke alarm and not the carbon monoxide alarm. Be careful some alarms are equipped with both now a days and people cant tell the difference. Get your gas company there to check it. Carbon monoxide is undetectable to the nose and is deadly so please be very careful! If there is smoke and u have cured ur oven then there maybe some old food on the burner, remove the bottom plate and check. If there is no smoke and no food on the burner then u need to change ur ignitor. It maybe old, cracked or both. Typical repair cost on high end range is 300 - 400 for 1 ignitor. Good luck. And I urge u to see if it is Carbon Monoxide!
Sep 04, 2009 | Hotpoint RGB745 Gas Kitchen Range
When cleaning my oven, the whole house fills with smoke.
sell cleaning on ovens just causes problems like this, it is normal. it cleans by burning everything inside at high temp. i always recommend cleaning the old fashioned way, once a year , with oven cleaner, or as req. roasting an oven itself to clean it is insane i think
Jul 23, 2009 | Ovens
Turn up pilot light
The ajustment screw to increase the intensity of the piolet flame is located on the oven gas valve(behind the cntrol knob.
Apr 04, 2009 | General Electric Stove/Oven/Range Chrome...
Self cleaning oven directions
MAKE SURE OVEN IS EMPTY LOCK OVEN DOOR AND TURN OVEN SETTING TO CLEAN, IF YOU HAVE A VENT TURN IT ON THERE WILL BE SMOKE! LET RUN TWO HOURS,TURN OFF,LET COOL BEFORE TRYING TO UNLOCK IT (WILL NOT UNLOCK WILE STILL HOT!) OPEN DUST OUT ASH ITS CLEAN!!!
Dec 07, 2008 | Whirlpool GR465LXLS Electric Kitchen Range
Kenmore 95002 / 95004 Electric Kitchen Range Logo
180 people viewed this question
Top Kenmore Kitchen Ranges Experts
Dan Webster
Dan Webster
Mike Carew
Are you a Kenmore Kitchen Range Expert? Answer questions, earn points and help others
