Question about Maytag SkyBox MBV1976A Beverage Dispenser
Skybox does not get cold
I have a maytag skyboxk, you can hear the compressor running but it does not get cold
    Problem Solver:
  • 4 Answers
Reed.. I had the same problem.. a maytag repair guy could not fix it .. Thanks to someone in FIXYA I got the part I needed ($23.00) Whirlpool 4387835 relay. I called the repairman and he would not returned the call.. So I opened up the box myself and carefully looked at the parts , replace the wires one at a time (it was easy) now I have cold beer just in time for baseball season pool side....lol Good luck!
Louie
Posted on Mar 10, 2009
It does not continuously run and it is not cold
These units are not repairable.(per Maytag) The entire unit must be replaced.(per Maytag)
May 26, 2009 | Maytag SkyBox MBV1976A Beverage Dispenser
Skybox is freezing and making a humming noice.
The temperature in the SkyBox is controlled by the thermostat located within the beverage compartment. If set too high, product can feeze. In addition ice will build up behind the dispenser assembly. The ice buildup can eventually make contact with the circulating fan blade and cause a constant noise.
You should hear the compressor stop running as you turn down the cold control, but prior to reaching the "off" position. Select a lower setting for the cold control, and unplug the unit for 24 hours with door open to thaw out the ice build up. Reconnect power to resume normal operation.
Apr 04, 2009 | Maytag SkyBox MBV1976A Beverage Dispenser
Hi my skybox stop cooling
The SkyBox operates with two individual systems. The dispenser assembly, the LED indicators and the circulating fan operate on a low voltage circuit. The circulating fan runs anytime the SkyBox is plugged in.
The cooling system operates on 120vac. The cold control inside the beverage compartment is an on demand switch that sends 120vac to the compressor when cooling is needed. There are no parts available for the compressor, so if it determined that power is reaching the compressor, the windings are ok, a 3 in1 hard start kit (Supco URCO210) can be installed by a qualified service technician.
Mar 16, 2009 | Maytag SkyBox MBV1976A Beverage Dispenser
Maytag skybox start relay is bad
you need to change the overload relay ---- there is a company called appliancezone.com
they sell the overload relay unit with all the parts for $26.00
email me back if you cant find it---- put in the model # for the skybox unit and you will see the item
item # 4387835
this is the problem -- if this relay goes bad the compressor will stay on and not supply cold air to the unit ----
Dec 16, 2008 | Maytag SkyBox MBV1976A Beverage Dispenser
Not getting cold
need to replace the relay overload switch
go to
appliancezone.com
part # 4387835
cost $ 26.00
Dec 12, 2008 | Maytag SkyBox MBV1976A Beverage Dispenser
Maytag Skybox
good to hear another skybox lives...thanks for the kind words. alex
Dec 10, 2008 | Maytag SkyBox MBV1976A Beverage Dispenser
Skybox not cold
Sorry but it sounds like the same thing that happened to mine and my diagnosis by the repair guy was that the compressor is bad. The cost of repair? $400! Maytag only covers the compressor for ONE YEAR!
Nov 11, 2008 | Maytag SkyBox MBV1976A Beverage Dispenser
Maytag SkyBox
For the soda name tags, I pulled logos off the internet and printed them the correct size on 20-pound paper. Different paper gives different translucence, so you might have to experiment to get the right amount of light coming through.
PS: thanks for the part no. on the relay
Apr 21, 2008 | Maytag SkyBox MBV1976A Beverage Dispenser
Maytag skybox cooling
Is it cooling at all? Do you hear the compressor start or just a buzz for a few seconds? This sounds like a compressor or compressor start relay failure. Unplug the machine. Access the compressor and remove the relay that is plugged to the side of it. Shake it and see if it sounds like there are a lot of loose pieces in it. Inspect it for burned spots. If you find either one of these, it is bad. If it doesn't rattle or appear burned then the compressor is probably bad. Even if it seems ok, I would try a new one on it anyway. They aren't usually very expensive. If the relay is not the problem, check your owners manual for the warranty info. The compressor may still be covered by warranty even if the rest of the unit is out of warranty.
Oct 10, 2007 | Maytag SkyBox MBV1976A Beverage Dispenser
Maytag SkyBox MBV1976A Beverage Dispenser Logo
282 people viewed this question
Top Maytag Retail Supplies Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
Are you a Maytag Retail Supply Expert? Answer questions, earn points and help others
