My computer screen shuts off at random and will not come back on without shutting it down and restarting what can i do?
    President:
  • 2,653 Answers
If possible, try hooking up another monitor. That way we can figure out if the problem is with the monitor or the PC itself.
If you do this we can narrow the problem down a great deal.
Let us know what happens.
Posted on Feb 26, 2009
NEW HP Spectre 13T-3000, 13.3" Touch will not run with the battery and shuts down randomly
you can use the unit without the battery. Remove the battery, plug in the charger/power supply and turn on the unit and wait for the result. if the problem persist?..... maybe the fault is in CPU fan. check the fan...overheating the processor. Cleaning the heat sync and reapplying silicon compound on CPU's can cure the problem.
Sep 02, 2014 | Computers & Internet
What causes HP Pavilion to shut down and then restart at random times?
your powersupply might be giving out disconnect unused usbs that may be faulty or just ripped or broken
Aug 03, 2014 | HP GX614AA Pavilion A6330F Desktop PC
Random Restarting Issue with Sony Vaio VGC-RB30
send it in to check the fan inside if not cooled it could shut down and start back up when cooled
Nov 29, 2013 | Sony VAIO RB30C (VGCRB30) PC Desktop
1990 dakota engine shutting down randomly
I had a 1988 dodge Dakota ,and it did the same thing. I fould that the o2 sensor was bad. I am a self employed mechanic
Oct 28, 2012 | Dodge Dakota Cars & Trucks
Laptop randomly shuts down and shows a blue screen saying
Make sure you don't have any unecessary programs loading up into windows when your laptop boots up. The next time the system randomly reboots check to see if the laptop feels a bit warmer then normal. Could be that your air vents are being blocked by dust. That would cause the air not to flow properly. Take a can of air and blow the vents clear so the air can flow properly and that would take care of the problem.
Jul 05, 2010 | Gateway CX2618 Notebook
Dell Laptop shuts off
Take out the battery and only hook up the AC Adapter to the laptop. See if it still shuts off on you at random.
If it still does then try another AC Adapter and if it still shuts down randomly then it might be a motherboard issue.
Take a can of air and blow it into the air vents on your laptop. This will remove any dust or debris that might be affecting air flow.
If that doesn't do it then the only other thing to try would be to take apart the laptop and where the heatsink sits on top of the CPU, take the heatsink off and make sure there is no dirt or dust buildup on it. If there is buildup on there that would cause the laptop to shut down without warning cause that means its not cooling like normal.
At this point if you went thru all of this and you still get shutdowns then the motherboard is bad
Aug 08, 2009 | Dell Computers & Internet
Random Blank screen at startup. All lights runed on.
shut it down properly from the command line or/and keep power button pressed for 5 sec's or so
Jun 23, 2009 | ASUS Eee PC 901 XP Notebook
Random shut down
The PSU voltages can be checked with a digital multimeter at the ATX connector, 3.3v (orange), 5.0v (red) & 12v (yellow) if the DMM is indicating values of MORE than 5% variation your PSU is the likely villain (best to rule it out first).
Are you getting a BSOD (Blue Screen Of Death) or error messages when you PC randomly shuts down?
Jan 23, 2009 | Nexus Prolong:Extra Cooling after PC shut...
Monitor randomly shuts off and computer restarts
After you turned it on and the screen shut off, check the image on the screen by shining a flashlight into the screen, not directly but find the best angle to the screen and take a look very closely. If you can see the icons or any image, there will be a minor problem. This is because of the lamps inside screen. Some of them were broken and it is very easy to replace. If you cannot see anything on the screen, there'll be some problems with inverter board. If the computer shut down immediately after the monitor shut off, it might be because of fault operating system. Check with another monitor.
Thank you,
Mar 08, 2008 | HP Compaq FS7600 17" CRT Monitor
Computers & Internet Logo
60 people viewed this question
David Payne
David Payne
