Question about Samsung DLP HL-P5663W 56" TV
SAMSUNG DLP HL67A510- CLICKING, LAMP LIGHT BLINKING WONT TURN ON
Hi,  I have a HL67A510, there is a rapid clicking sound and the green lamp light is blinking. The TV won't turn on. When you first push the on button, you here a second or so of music and the rapid clicking sound for a second or two. Nothing happens the lamp light keeps blinking and the sound stops then after a short time it repeats the same clicking sound. The clicking sound seems to come from a roughly 10" square removable panel on the back.
  • 100 Answers
SOURCE: SMASUNG DLP 50 HDTV
The ballast that powers the lamp is bad
Posted on Oct 31, 2007
SOURCE: Samsung DLP won't turn on-rapid clicking sound, lamp light blinks
it was bad bulb
Posted on Mar 04, 2009
dap_music385
  • 15 Answers
SOURCE: Samsung 61"DLP wont turn on.
1. Your tv is on stand-by condition. First press the main power switch and then the channel button and wait for a while. If your tv does not turn on assume that problem is on the mother board.
2.The next procedure needs an expert to avoid accident, cause the most common defect in this case involve low voltage power supply ranging to 220 v and high voltage power supply to 15 to 30 kv. If your a technician you can ask me my technical support if you confirm that you do.
Posted on Jul 11, 2009
SOURCE: Samsung DLP TV time, temp and lamp lights blinking... won't turn
Les,
I'm not a TV repair guy but my owners manual states that when all three LED's or lights on the front of the TV are flashing, that the lamp needs to be replaced. Might want to look into this. Good luck!
Greg
Posted on Aug 31, 2009
fillmore85
  • 62 Answers
SOURCE: I own a Samsung HL-R5067W 50
Check your color wheel. There is a DIY guide for replacing the color wheel. Mine did the same thing yours is and my color wheel was all busted up. Unfortunately after replacing the color wheel my set continues to do the same thing, but this could mean I need to replace the ballast as well.
Posted on Oct 20, 2009
Power light blinking red..tv won't come on after replacing lamp
DLP TV Repair Tutorial - DLP Bulb Won't Turn On - YouTube
? 14:13
https://www.youtube.com/watch?v=5frOnh58Z6M
Jun 26, 2013 - Uploaded by ShopJimmy.com
DLP TV Won't Turn On Common How to Replace Ballast DeadTV ... solid green power light plus sound ...
• New Lamp Doesn't Turn On? Try This! - Fix Your DLP - FixYourDLP.com
www.fixyourdlp.com/forum/viewtopic.php?t=19
Mar 12, 2009 - 50 posts - ‎36 authors
Mine did the same thing after replacing the lamp. ..... TV won't turn on and Color Wheel is GOOD, Temp sensor is GOOD, Ballast is GOOD, and ... • NEW Bulb- still not working
Jan 14, 2010
• Resetting the Samsung DLP Lamp Counter/Hour Meter
Mar 20, 2009
• Samsung Dead Lamp, Black Screen, or Intermittent
Mar 12, 2009
More results from www.fixyourdlp.com
Samsung DLP: replaced lamp however tv won't turn on - HDTV ...
Dec 09, 2015 | Televison & Video
Hi, My hc1500 Is having a problem. When I turn it on it makes a clicking sound. Then the Lamp fails to light. The Light is green and the status is green, but soon after the projector shuts off the power...
The clicking sound is the high voltage power supply trying to
ignite the gas in the lamp. The lamp is not firing and coming on.
Check the bulb/ lamp life. Possible the lamp has exceeded its
useful life and may need to be replaced.
Jul 16, 2010 | Mitsubishi HC1500 DLP Projector
The Control Panel/Dispenser light went crazy...
Sounds like a electronics problem would need to replace the board, LG parts are not normally expensive.
Apr 11, 2010 | LG LFX25960ST Stainless Steel French Door...
Samsung dlp acts as though the lamp is gone. Put
It may be the ballast or aother problem. First, unplug your TV for about 5 minutes, plug back in. LISTEN very carfully when you turn the TV on. (put ear on the left hand side of TV towards the back) if you hear a clicking sound. It may be your light engine. BUT most important what lights on front panel are blinking.
Hope this was helpful, Big Irish.
Nov 21, 2009 | Televison & Video
Wont turn on. Green light comes on for a few seconds, andthen goes back o0ff.
Hi if its a Lcd or Dlp rptv most likely its time to replace the lamp if tv is between 2-4 yrs.If you hear clicking it could be the ballast which is the board that powers the lamp.Make sure fans are running ok ,dust them out if they are dirty.God bless you!
Oct 07, 2009 | Mitsubishi WS-55511 55" Rear Projection...
Green status light keeps blinking after lamp replacement
continuous blinking green light indicates that the capacitors have failed on the DM pwb. You need the V26 DLP DM repair kit which is available at the following link under their repair category.
http://servicemanuals.vstore.ca/
Sep 07, 2008 | Mitsubishi WD-52525 52" Rear Projection...
Samsung DLP HL-P5663W 56" TV Logo
524 people viewed this question
Henry  Thomas
Henry Thomas
