Question about ASUS P5VD2-MX SE Motherboard
Problem with post!
My pc many times freezes in post!
if not , then makes rebbot after 5 minutes after log on in vista!
  • Chuck May 11, 2010
    download and run the vista memory diagnostic. run the advanced option. here is the tool http://oca.microsoft.com/en/mtinst.exe
    it sounds like your having memory issues maybe. This problem that you discuss could be so many things but i would start here with this tool.
    did you set the memory timings and voltages in your bios?
  • 530 Answers
Hi im josh in cebu phils. may i help you? friend if it happens when your pc reboot after few minutes of log to vista. your main problem is the memory or RAM.your memory cannot accomodate the vista software thats why it shut off. you need to upgrade your memory chip inorder to make the vista software run. if still occurs try also to check the position of the processor if it is seated properly.
Posted on Feb 27, 2009
Scotsman ice maker cme 506 makes ice and turns off and blinks refrigeration
First check to make sure condenser fan is running during freeze cycle. Now check to make sure condenser coil is clean. Her is all the specks on the machine.
1. Ice production ( 500 at 70/50
2. BTUs per hour ( 7000)
3. Maximum times in Minutes. ( 50 freeze, 14 harvest.
4. Refrigerant charge ( R-404A ) ( A-D series: AC 32oz, WC 20 oz. E series AC 23 oz, WC 14 oz, F series AC 23 oz, WC 13 oz
5. Suction pressure ( PSIG ) 35-37 - end of freeze, 120-125-Peak in harvest.
6. Discharge pressure ( PSIG ) 240-260- 5 min in freeze.
165-175- minimum in harvest.
7. Metering device.( TXV plus distributor, E series and higher have two TXVs. superheat 3 to 15 deg F.
8. Average comp.amps. 10-11 during freeze, 11-12 during harvest.
9. Batch Weight. 6.5-7 lb
10. cycle time, 23 minutes @ 90/70. 19 minutes @ 70/50
Feb 24, 2013 | Scotsman Ice Maker CM3 30inW Cubed Ice...
Dell xps m1530 with intel core duo keeps freezing
To further investigate the issue you may do the following.
1.go to control panel --> administrative tools then select event viewer. check on system logs. you might be able to find a clue on why the notebook keeps on freezing after 15 to 20 minutes.
2.please check your virus definitions if its fully updated. If not please update it then do a full scan afterwards.
3. do a windows update on your system if it's not fully updated yet.
4. You may also check or try to remember what has been installed lately. It might be that the application installed have caused vista to freeze.
Or you may also check this link for another user who has the same issue.
hope this helps . . .
Apr 05, 2010 | Dell XPS M1530 Laptop
Post Boot Freeze
It freezes because one of the programs set to start at boot crashes. To identify which immediately after booting open Task Manager and look at the processes - one should reach 99% CPU use. Once you have found it stop it from launching at boot or just uninstall it.
Jan 22, 2010 | Dell Inspiron 1525 Notebook
Cant log in on vista password forgotten
Discussion: When we are running imagex we are not deleting user data from the HDD, in this process we are overwriting data. But, its better to set expectation to Customer that thre might be possibility of data loss. After completing the process we can logon to the system with new user account that we create and we can retrieve data from old user profile.
Here is the process to run Imagex:
1. Boot to the computer using VISTA DVD.
2. Select the option repair my computer.
3. Go to command prompt
4. Go to D: prompt
5. Type Path d:\windows;d:\windows\system32 and press Enter
6. Go to Tools folder using command "cd tools".
7. Use this command Imagex /apply d:\dell\image\factory.wim 1 c:\
This process will take 15 Minutes after that reboot the system. After rebboting we will get OOBE Screen.
We can logon to the system using new username. We can retrieve the data by navigating to old user profile.
How to retrieve the data from the old user profile after using the Imagex procedure :
1. Click Computer
2. Click Local Disk C:
3. Locate Windows.old and double click on the same
4. Click Users
5. Click <username>
Note : <username> would be the login name for which he has forgotten the password
6. Accordingly you can access the files available in the folders Desktop, Favourites, Music, Downloads etc
Nov 26, 2009 | Computers & Internet
How do i rebbot my window vista xp laptob if I
If you have the CD that Came with the PC you can use that to reinstall Vista, All Dell computers ship with A dell reinstall disk
Nov 06, 2009 | Dell Latitude D520 Notebook
Toshiba Satellite L40-17U freezes up after 5 minutes
Norton antivirus takes big space in the computer coz it try to block all the files and make them secure, so it slow down your computer specially if you have vista and with low Ram. so First Try to remove norton and check your computer? it seems the Ram is low so its unable to continue its froze, or if you feel its over heat, check the fan on the Cpu could be not working which make ur Cpu Froze.
Jun 17, 2009 | Computers & Internet
Vista Issue
While this is a common symptom, its causes are many...
To begin with, make sure you are current on all updates from Windows update, and check to see if there are optional hardware updates available for your system.
Have you gone to the event viewer to see if there are error events reported with respect to the running processes? Look to see if you have repeated warnings or errors with the same code, at times when you experience the freezing.
It also could be symptomatic of a hardware failure... of some kind. See this article for comparison.
I would begin to troubleshoot the issue by attempting to work through Microsoft's optimize vista tutorial available here, and see if you can sort it out on your own. If you take those steps and still have difficulty, please post back with the results.
I hope this information allows you to resolve this issue. If you need further assistance, please post back with a comment to this thread. If I've managed to answer your question or solve a problem, please take a moment to kindly rate this post....thanks!
Apr 22, 2008 | Sony VAIO Digital Studio VGN-AR320E...
ASUS P5VD2-MX SE Motherboard Logo
61 people viewed this question
Top ASUS Computers & Internet Experts
Alun Cox
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
