Question about Roper REX4634KQ Electric Dryer
Roper dryer wont start when i push the button model no. rex3514pq
How do i fix the problem
  • ricebrian69 Feb 27, 2009
    dryer wont start when you push the button
  • pindad809 Mar 18, 2009
    I have the same problem. I've cleaned out the lint, and hose. Tried a new thermo fuse, made sure there was power going to the start switch, but the dryer still won't start. Any ideas??
  • Roper Master
  • 8,220 Answers
The first thing to do is check the vent for lint buildup. Then remove the rear dust cover and change the fuse.
roper dryer wont start when i push the button mode - b2421ee.jpgI have a few thoughts written down HERE about this
Posted on Mar 02, 2009
Roper dryer won't stay on after pushing start button. If I hold the button in it will stay running
YOU HAVE A BAD PUSH START BUTTON CONFIRM THIS BY TESTING WITH A METER FOR OHMS
Feb 23, 2015 | Roper Dryers
Roper dryer repair manual
90% it's the timer
Jan 30, 2014 | Dryers
Roper dryer wont start, do it have a reset button
Check the door switch. With the door open, press the button in and the light should go off. If you don't have a light, listen for a click form the switch as you push and release it. If you don't hear a click, you will need to replace the switch. If the switch is good, then problem will be with the thermal fuse located on the rear of the unit.
Sep 28, 2012 | Dryers
Dryer just stopped working,i pushed the start button and nothing?
The number one reason a dryer will not start is because of a blown thermal fuse. This tip i wrote will help ya to check the thermal fuse. http://www1.fixya.com/support/r10530385-dryer_power_but_start
I hope this will help ya to fix your dryer,
GENE
Sep 23, 2011 | Roper REX4634KQ Electric Dryer
I have a roper dryer .the dryer will just hum when you push the start button and will not do anything like its is in a bind . the humming occurs only when you have the button pushed , its like it don't ...
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor goingbad...
Here are a couple of tips that I wrote will help you to figure out why yourdryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Oct 27, 2010 | Roper REX3614KW Electric Dryer
Push start button and nothing happens on roper dryer how to check button to see if working
A dryer can not start for many reasons...
This tip that I wrote will help you to figure out what is happening...
http://www.fixya.com/support/r4460438-dryer_repair_dryer_will_not_start
heatman101
Apr 06, 2010 | Roper RES7646KQ Electric Dryer
Dryer starts only with putting pressure unevenly on dial. start button pushed doesnt turn on
Space between the terminal and the push button is stretched. Open the switch panel and fix the distance.
Oct 07, 2009 | Roper REX4634KQ Electric Dryer
TIMER NOT WORKING
The knob does not pull out on dryers. Turn the timer to the desired setting and push the start button. Eric
Sep 10, 2009 | Dryers
I am trying to fix a rooper elecetric dryers that starts on the push button but shuts down when evere the start button is released. The dryer would normally stay in the run mode once the start button is...
IF YOU HAVE A METER YOU CAN CHECK THE START BUTTON ON OHMS,CLOSED AND GET A READING GOOD,OPEN AND GET NO READING GOOD,OR JUST A WIRE ACROSS THE SWITCH TO SEE IF THE MOTOR STARTS RUNNING,IF ALL THAT FAILS I WOULD SAY THE MOTOR IS BAD,LET ME KNOW-MIKE
Feb 23, 2009 | Roper RES7646KQ Electric Dryer
Roper dryer will not start
Did you check where the door closes. There should be an accuatator on the door side that will depress a safety switch inside the housing. Take a flat scerw driver & push the lever in on the switch in the housing once you have set the controls to run. This could be the problem, but there could be other problems, Good luck.
Jan 21, 2009 | Roper REK2950W Electric Dryer
Roper REX4634KQ Electric Dryer Logo
186 people viewed this question
Top Roper Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal DeAngelo
Are you a Roper Dryer Expert? Answer questions, earn points and help others
