Steam cleaner not creating steam
I have a polti 1500 cylinder steam cleaner which is heating up the water ok but no steam comes out of the hose
    Novelist:
  • 121 Answers
Sorry this wont get resolved in this area, this is the Computer section. Please repost this in the correct location.
Thanks,
Armymason
Posted on Feb 26, 2009
My Polti keeps tripping the electrics?
power cable coming out of the Polti steamer sometimes splits at the base causing wires to short circuit as it is being used
Apr 13, 2015 | Polti Vaporetto 2400 Steam Cleaner
Repair Polti VT Evolution steam cleaner doesn't work
Steam nozzle/lines are probably clogged. The minerals in the water will eventually clog up the system, you need to use only Distilled water whenever possible to eliminate as many minerals from the water as you can. If the screws are spinning and not coming out, you will have to pry up slightly on the cover the put pressure on the inner parts so they will come apart. Easiest way is to push something like an old credit card betwen the seams and pry up carefully. go slow and easy so you won't break anything.
Aug 20, 2014 | Vacuums
Polti vaporetta comfort steam cleaner...no steam
if you put two much water in it it wont steam
Dec 26, 2012 | Vacuums
Due to illness etc I've not used my Polti 2400 for a couple of years. Now I want to use it I have all the paperwork that came with it - except the instructions! Can you help.
Polto steam cleaner 2100/2400 yellow, the on switch will not click on so the water does not heat up. The orange light comes on when i press the on switch but goes off and the button comes back up as soon as i let go. Any ideas will be gratefully received.
Dave
Mar 14, 2010 | Polti Vaporetto 2400 Canister Steam Vacuum
Polti spare parts
i have a 950 and it does not heat up any more . the red light comes on but thats it
Feb 13, 2009 | Polti Vaporetto 2400 Canister Steam Vacuum
Polti steam cleaner
It should go just below the red providing steam isn,t escaping from the cap otherwise you won,t get the pressure build up to enable it to come out when you pull the trigger
Oct 23, 2008 | Polti Vaporetto 2400 Canister Steam Vacuum
Polti steam cleaner problem
Here is a site where you can obtain information or service for your equipment. There is no online support that I can find.
http://www.polti.it/eng/index.htm
Good luck to you.
Aug 18, 2008 | Vacuums
Polti 1500 no steam just droplets of water
Before trying anything else make sure you turn up the pressure control knob in the direction of the + sign if it is turned right down you will have steam in the system and the gun will be heard to click open the flow control valve but you will not get any steam because the control screw is set too low just turn it anti-clockwise to increase the flow and your good to go .I hope this helps I have one too and I some times forget to turn up the flow and wonder why for 3 minutes then realise that during storage and manuevering it gets turned down by accident and i turn it up and all is well again.
Jun 20, 2008 | Polti Vaporetto 2400 Canister Steam Vacuum
NO STEAM EVEN THO THE DIAL GOES RIGHT UP TO THE RED
Hi i've had the same problem Put a phial of Kal stop into 1000 or 1500ml of water into the tank, let it heat up and it should break down the limescale of the solenoid. It's worked for me. Have a good evening;-)
Dec 10, 2007 | Polti Vaporetto 2400 Canister Steam Vacuum
Computers & Internet Logo
239 people viewed this question
David Payne
David Payne
