Question about Dual Electronics CECT P168 Cellular Phone
I can't find speed dial on my I9 cect phone - Dual Electronics CECT P168 Cellular Phone
  • harglester Apr 27, 2009
    i found where to set it up but i dont know how to use the speed dial after it is set up
    Problem Solver:
  • 12 Answers
Go to call --> call settings --> speed dial
Posted on Feb 28, 2009
Follow the following:
>Call Center at the bottom
>General call settings
>03 Speed dial
>Check that "enable speed dial" is on
Then
>02 Set number
>You will see a list of "empty"
>Touch on the one you want to assign a number
>Edit
>this takes you to your phone book
>Choose a name from your list and save it to your speed dial.
>To call the number from your speed dial list, click on the "Phone dial" icon, and hold the number down. For example, is the number 2 is home, hold 2 down until you see it dial and there you have it.
Hopes this helps
Posted on Sep 10, 2009
  • alexander_ir Dec 30, 2010
    There is no "Phone Dial" icon on my CECT i9 touch screen. I cannot use speed dial until I get this icon. How do I get it? Any ideas?
    Problem Solver:
  • 8 Answers
My calls make noise in the calling end
Posted on Sep 13, 2009
SOURCE: My computer does not recognise my CECT i9 phone
START MENU <MY COMPUTER> REMOVABLE DISC(E)-(G) ARE FOR THE PHONE.
Posted on Feb 05, 2009
truenoae86jp
  • 44 Answers
SOURCE: cect i9 phone
Well let me start off by saying Cect makes knock off phones and in your case its a knock off Iphone.
They are imported phones from Hong Kong (i believe) and are made very cheap.
Most likely if your memory card is too big in size, lets say a 4gig Transflash, and they phone only supports up to a 2gig, well the reason is right there. Your memory card is too big and the phone wont support it.
If the memory card you are using came with the phone, most likely something has gone corrupt or there is a virus on a file you have uploaded or its missing the phones format on the card.
I would go in and first check to make sure the size is supported.
(check the manual or online where you bought it)
if it isnt, than thats your problem.
if it is, i would erase your files from the memory card and see if they phone will read it then. If it does, than one of your files is corrupt and just narrow it down with trial and error until you figure it out.
if you still cannot open the card,
i would search your phone in the settings and the menu until you find a memory card option or an option to format a memory card. Once you have found that, format the card (on your phone) and then go about placing your music and videos in the correct labeled folders.
I hope this helps
Posted on Feb 17, 2009
  • 193 Answers
SOURCE: I9 Phone Unlock wont move
Try Calibrating the touch screen. Listed is the instructions how.
Please use the stylus to calibrate!
The fastest way is to be on the slide-lock screen & hold the side volume button in the Up position until
"Press volume down key to check" comes up onscreen. This may or may not work on all firmware versions
on the current i9, but works on most. Make sure to hold the button firmly in the Up position. You will first
see the normal volume speaker icon show onscreen and the volume rise, but just keep holding it Up, and
eventually you should see the pop-up box noted earlier. The moment you see that pop up onscreen,
immediately press the side volume button in the down position. A white calibration screen should now
show & you can calibrate the touch screen using the stylus. Try to tap as close to the center of the little
pulsating icons as possible, as this will more accurately calibrate your touch screen. If the calibration
screen didn't come up using that method, then you can get to it from the Main menu screen.
Select "Settings", then select "Pen calibration", & follow the previous instruction.
For full help topics I have a cd available for 10 us dollars. Has 100's of mp3 ring tones wallpapers, and java games and opera java browser. Guaranteed help on every question ever asked on these phones. And all settings for all cellular services. I have answered 100 questions with this CD. If interested contact prestorose@aol.com Pay Pal only, will send out First CLASS Mail in padded envelope. If interested I will send Pay-Pal invoice that can be filled out and returned with instructions. Guaranteed safe transaction.
Posted on May 01, 2009
Z00T
  • 76 Answers
Switch the phone on, then connect. You should have 3 options; Mass Storage, Webcam and PictBridge. Select Mass Storage. Depending on your system on your PC will connect immediately or maybe (older model) ask for driver. Driver for mass storage is 'generic' so will install automaticaly. After that go to 'my computer' and there will be 2 (!!!) new 'drives', the first one the external card on your phone, the second one the internal drive of your phone.
Posted on Jun 12, 2009
  • 248 Answers
SOURCE: problem removing battery cover of cect i9 cellphone
Usually these covers slide off. Look at it carefully and you can see that there is only one direction it could possibly move. Push it in that direction with both thumbs. I am not familiar with that particular model.
Posted on Jul 25, 2009
How do you change the java settings on the cect i9 3g?
*#0044# dial this code. your phone will change into English manual.
mobile phone wholsale: www.eshopbing.com
Sep 26, 2009 | Dual Electronics CECT P168 Cellular Phone
HELP !!! How do i sync my cect i9
try going to this webpage,
http://www.mobilerated.com/cect-i9-home.html
please vote me! :)
Jul 27, 2009 | Lands Phones
My usb for cect i9 does charge phone
my cect i9 was not charging from usb I though it was the cable but after I took out battery and scrapped the 3 contacts on the batttery with my fingernail it started to charge and be recognized by computer again
Jul 13, 2009 | Dual Electronics CECT P168 Cellular Phone
I9 phone won't recognize sim card and dial out or receive
In any other phone the shiny gold bars go face-down, but with the i9, the gold bars face up-wards.
Jul 07, 2009 | Dual Electronics CECT P168 Cellular Phone
Speed dial
go to your phone book select the person...now go to options and add to speed dial (slots 2 thru 9)...
to speed dial..go to phone and press the number on keypad then press phone...you can also speed dial 11 thru 250...by pressing the number then #....come just for the fun of it...go to phone and the keypad (act like we making a call) now press 19# (who came up)...try 15# and so on (this also depends on how many is in you contact....if you only have a fave 5...19 & 15# will not work,,,
feel free to rate the help
Jun 16, 2009 | Dual Electronics CECT P168 Cellular Phone
Problem with receiving pics via mms on cect i9 phone
You will need to configure your i9 for Cingular manually. You can find a manual with the GPRS and MMS settings at http://chinamanuals.com
Mar 23, 2009 | Dual Electronics CECT P168 Cellular Phone
I want to load Games on to my cect i9 touch screen phone, can you
I'm sorry to say that that guy is wrong because the CECT i9 does have java depending on who you purchase it from. If you want proof go on youtube and look at some videos of people actually downloading java games to their phone.
Dec 22, 2008 | Dual Electronics CECT P168 Cellular Phone
Dual Electronics CECT P168 Cellular Phone Logo
796 people viewed this question
Top Dual Cell Phones Experts
William Alequin
Computer Repairing
Computer Repairing
Shehu Pro
Shehu Pro
Are you a Dual Cell Phone Expert? Answer questions, earn points and help others
