Well I have windows, and am trying to connect wireless.The work offline tab is not checked. But computer keeps saying not available off line press connect to go online when ever i follow the prompts i still get the this page not available. My service is through att, why is this so complicated. My playstation 3 got right on. i have been trying for 3 days, all att can say is they believe my system is blocking this service. I
We can try to isolate whether it's a problem with IE by having you download and install Mozilla Firefox and seeing if it allows you to browse the web.
You may want to check your connection settings in Internet Explorer - Tools + Internet Options + Connections. If you had any dialup settings or anything in there previously you should disable them. The other thing you can try is running the network setup wizard and telling the machine that you connect directly thru a network hub.
Report your results back here.
Let's do this - connect your Acer directly to the hub with an ethernet cable (on the LAN port) and open IE. Do you get the internet? If so it's not an issue with the browser itself. If you connect the ethernet and still have no internet this may actually be a problem with IE. It helps us narrow it down.
If you are having problems with the wireless adapter itself you would get an error to the effect of "limited or no connectivity" or "unable to authenticate". I'm attempting to rule out what it isn't in order to figure out what it is.
Please post back with any additional info.
Point of clarification - Are you talking about a USB connect device from AT&T or a standard broadband connection?
I do not have a hard drive, so how will i do this
