Question about Braun WK200 Electronic Water Kettle Cordless Electric Kettle
HOW DO YOU REMOVE ALL OF THE BROWN RESIDUE FROM A BRAUN WK200 KETTLE?
  • cstewart1942 Feb 28, 2009
    THANK YOU.
    THE IDEA OF LIME AWAY OR VINEGAR AND H2O IS GREAT!. THANK YOU.
  • 137 Answers
There are comercial products that will do this look for it in houseware stores, maybe some big Ace Hardware stores, maybe even at your chain grocery stores.
Posted on Feb 28, 2009
  • 653 Answers
The deposits are most likely calcium scale and minute amounts of rust or other minerals. The most environmentally friendly way to clean it is soak it overnight with a 50/50 mix of white vinegar and water, then scrub it out with steel wool. If this doesn't do it on the first or second try, go with Lime Away or other similar product. Just make sure you clean thoroughly before using after the chemical cleaner.
My kettle light is off and cannot heat
It has died Stephen! Get a new one - it will be cheaper than fixing this.
Jan 09, 2014 | Braun WK200 Electronic Water Kettle...
No light, no water heating
The heating element may have failed.
Sep 11, 2012 | Braun WK200 Electronic Water Kettle...
How to clean my Braun electric kettle
Hi, follow the instruction below to clean it up...
Unplug the tea kettle from the wall outlet, and detach the plug from the kettle.
Pour 1/4 cup white vinegar into the kettle, and fill the kettle halfway with hot water.
Agitate the kettle so the vinegar mixture hits the sides of the kettle walls, and let the water sit for 20 minutes.
Discard the vinegar water, and scrub the interior of the kettle gently with a nylon sponge.
Rinse the kettle with hot water, and repeat as needed until all buildup is removed. Let the kettle air-dry before inserting the cord back into the kettle.
Apr 17, 2011 | Braun WK200 Cordless Electric Kettle
Switch became totally loose and cannot be turned ON
you havent specified where the switch becomes loose and inoperable .......it is in the plug point or the base of the unit
if it is on the mains then change the point
it it is on the base of the unit ...
then give some padding to the base where the plug is connected then
it will start working////////
i hope this suggestion will solve your problem
Jan 08, 2011 | Braun WK200 Electronic Water Kettle...
Shuts off
Does the unit shut off only before the water boils, or does it shut off and on periodically? I just fixed my friend's WK200 Braun kettle. His would shut off and on, eventually coming to a boil. During normal operation, when you press the switch, it is connected to a rod which at its other end (ie the bottom of the kettle) is able to close the circuit allowing the current to pass through the heating element. In my friend's case, the contact had become weak - I just had to slightly bend the metal pole a little bit to provide a better contact when the switch was depressed. To repair the unit, I only needed a couple of torx screwdrivers and a voltmeter to measure continuity. (note, if you bend the metal pole too much, then the circuit will always be closed even when the switch is OFF - make sure you test for an open circuit when the switch is OFF)
Jan 29, 2010 | Braun WK200 Cordless Electric Kettle
Braun electric water heater lid came off along with spring parts, all intact. How do I re-assemble it? Manual? Schematic available?
This is the solution for the BLACK Braun electic water heater, so you must adjust the color to fit if yours is another color.
First take the 3 pieces that go inside the top. Two look like a "Z", and the other is the square, white doo-dad. Take the square piece and slip it into the slot with lid open. YOU CANT PUT IT IN FLAT UNLESS THE LID IS OPEN! Make sure that you can put it in FLAT. Once it is in flat, take it back out. Now you have the 2 "Z" pieces. Fiddle around with these pieces until you learn how to put them in together so they will fit together. This may take several tries. There is a piece that acts like a pivot. Now take all 3 pieces out. The trick is not to put the 2 "Z" pieces in together. You have to figure out what Z-piece to put in first. Then put the rectangular white piece in, and then the other Z-piece. This all must be done with the lid OPEN, otherwise the rectangular piece will not lie flat. Make sure the little spring inside this rectangular piece it put in properly - it should be against the little black doo-dad on the lid. If everything is sitting happily together, you should be able to snap the other black part onto the lid, and close it successfully.
May 16, 2009 | Braun WK200 AquaExpress Electric Water...
Won't turn on
I have the same problem. It started about a week ago and I have to keep flicking the on switch to get it finally working. I think there's a problem with the contact with the base. Not sure if it's worth getting a replacement part for it. It worked well for 4+ yrs!
Apr 20, 2009 | Braun WK200 AquaExpress Electric Water...
Switch problem
That is correct, the flat plastic rod that pulls when you depress the on/off button is attached to a switch lever under the bottom of the handle. The rod in mine broke off right where it connects to that switch lever. You can either try and find the new or used part, Braun may have new, I have not tried their 800 number, can't hurt? I fix everything from scratch though and rebuild when I can especially if parts are scarce or obsolete. So I used some marine putty to affix the rod end back to the lever. Marine putty is a stick with two putties you roll together for a rock hard compound, awesome stuff. You can get at Wally World or hardware, auto parts, boat supply stores. I also drilled very small holes in the broken rod on each side and the lever on each side and threaded some thin stainless steel wire through, just looped it around without twisting it togethor before putting the putty over it for a permanent, wire reinforced, fix.The handle is not screwed on exception of one little torx screw at very bottom of handle on base. The handle just snaps together. The base or bottom and 3 screws do not need to be removed either for this rod and lever fix. Remove the top 'cover' piece of the handle first, then remove the two brass pins under it at top next to the on/off button second. So, the handle 'snaps' off with a lock blade knife or equivalent, get under the handle pieces with knife edge and twist the blade, it will pop off as you go, be prepared to break a few little hook pieces off underneath, they break but it seems to snap back on ok anyway. Crazy glue alone won't hold these plastic pieces together btw, try another way, wire and putty, maybe a plastic welding kit etc.. Mine works great again, once I got the lever reattached to the rod..
Apr 16, 2007 | Braun WK200 Cordless Electric Kettle
Braun WK200 Electronic Water Kettle Cordless Electric Kettle Logo
1,418 people viewed this question
Top Braun Kitchen Appliances - Others Experts
Oscar Netto
Oscar Netto
Tom Chichester
Are you a Braun Kitchen Appliances - Other Expert? Answer questions, earn points and help others
