Question about ASUS Eee PC 1000H Laptop
Keboard stopped working on eee pc laptop some key make a beeping sound other just wont work and the delete key makes squares on screen when pressed
  • weemadscotsm Feb 27, 2009
    whaT SPEAK ENGLISH SON
  • Anonymous May 21, 2009
    same problem
Hi
your keyboard not working
may your keyboard in dust problem firstly u clean your keys
Posted on Feb 27, 2009
My asus laptop has no screen display and can sense flash disks
First you thing to check is when you turn the laptop on it should make a single beep sound. if not then in means you need to replace you cpu (central processing unit} or known as a processor. thy tend to blow wen the cpu dose not get serviced. the thermal compound on the laptop cpu must be removed properly and reply st every 3-6 mouths max. If it dose beep then take a normal PC monitor and connect it to your laptop and see if that works. if it dose work then it means that the screen is busted or you should pess the screen buton on the keyboard
Nov 02, 2013 | ASUS Eee PC 1000H Laptop
Asus Eee PC 1005HA wontl load OS
what key do you see during the boot up process
you should see a certain key it will be very quick you might have to restart a few times to get a good look
try pressing the delete key
hope it helps
Apr 09, 2012 | ASUS Eee PC 1000HE Netbook
Keyboard keys are not working
make sure that water has not filled into keyboard . unplag then re-plug the keyboard , if still not working then u need to replace the keboard
Sep 12, 2011 | ASUS Eee PC 1000H Laptop
I got eee pc 900a but wireless not working i try
  1. Turn off your computer
  2. Turn it on and immediately begin rapidly pressing F2 by itself
  3. Go to the Advanced tab by pressing the right arrow key once
  4. Go to onboard devices configuration by pressing the down arrow key once, then pressing Enter
  5. Go all the way down to Onboard WLAN by holding down the down arrow key until it is selected
  6. Press the minus key (-)
  7. Press F10
  8. Press Enter when it asks you to save configuration changes
If that still doesn't work, make sure you have the drivers you need from here:
http://support.asus.com/download/Download.aspx?SLanguage=en-us
Mar 22, 2010 | ASUS Eee PC 900 Notebook
Bios version for asus eee pc 10005ha touchpad screen freezes
Its not the Bos,just dont corrupt the boot procedure with unnecessary key presses.
Or reinstall factory settings properly--it has very little to do with the bios
Dec 18, 2009 | ASUS Eee PC 1000H Laptop
Can't get in the BIOS
This should be a simple key stroke that you would press when you first power up the PC. Turn it on, and you should get some sort of screen saying ASUS, or something. when you see that you should be able to press a key... like F2, F10, F12, Delete.. to enter the BIOS. Look on the screen upon turning it on, you should see something that tells you what to press to enter BIOS, or Setup. Press that key continuously, like 5 to 10 times.. then stop and you should enter BIOS.
It's simple, but I don't know the exact key for ASUS PC's....
Hope this helps...
Sep 09, 2009 | ASUS Eee PC 1000H Laptop
ASUS keyboard delete key won't work
are you sure that the key is seated properly on the board? This can easily be fixed by popping it off and checking to see if the 1, or 2, plastic like springs are connect to the key and the board.
Mar 12, 2009 | ASUS Eee PC 1000H Laptop
Laptop problem
Hi George you may have the brightness turned down or The screen turned off Press FN Key and F4 if this dosent help
Try FN Key and F5 and do it slowly give it a second or 2 to happen Try looking pge 3.8 at special keys in your manual and try these
Hope this helps if it dosent try and restore your OS by pressing F9 when starting then see if the screen comes up if this doesent work you may have a screen Lighting inverter problem
let me know
Gary
Feb 16, 2009 | ASUS Eee 4G Notebook
My EEE PC 4G webcam is not working
Go into the BIOS Setup (press F2 when the screen lites up).
Right arrow key to Advanced
Down Arrow key to Onboard Devices Configuration
Enter
Arrow key down to Onboard Camera
Enter
Arrow key to Enable
Enter key
F10
Enter
Hopefully that takes care of it. :)
Oct 28, 2008 | ASUS Eee 4G Notebook
ASUS Eee PC 1000H Laptop Logo
1,668 people viewed this question
Top ASUS Computers & Internet Experts
Alun Cox
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
