Question about Kenmore 24032\24036 Top Load Washer
Kenmore top load will not fill. It aggitates when it should fill!
  • warrenjay Feb 28, 2009
    Thank you so mutch!!
    President:
  • Kenmore Master
  • 2,651 Answers
Your experiencing an issue with your pressure switch. it thinks its full of water, so its going rith to the agitate mode. you would need to remove the back panle, and the pressure switch/fill switch is conected to a thin plastic tubing, reomve the tubing and blow through it, you should either here it gurgrle( through the water in hte tub, or air depending on water level. after clearing the line resecure the hose and see if that helps
Posted on Feb 26, 2009
Tries to aggitate but wont everything else works
Sounds like the transmission is out. If it fills up and will pump out while spinning? Then more than likely that is it. Or could be the belt underneath. When it aggitates the belt go's in one direction then spin out it go's the other direction and turns the transmission and drum.
Dec 09, 2011 | Kenmore 24032\24036 Top Load Washer
Fills and drains but it makes a loud squeeling noise when it try to aggitate
does it spin ? if it spins sounds like you have in internal transmission problem to replace it would be roughly 1/3 cost of the machine
Dec 01, 2009 | Kenmore 22422 Top Load Washer
Washing machine will not aggitate.
if it fills with water then stops check you lid or door switch. will the unit drain or spin if so the the timer may be bad
Sep 16, 2009 | Washing Machines
Kenmore top loading washing machine manual for 110. Machine does not activate pump to empty water. Also, spin cycle does not work. Machine will fill up OK and aggitate OK.
Check the lid switch for failure.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Aug 08, 2009 | Kenmore Washing Machines
Will not agitate 110 92587210 Kenmore Washer
I have 2 words for you: "dog ears".
the dog aggitation ears are what cause the aggitator to aggitate. Those things wear down and not grab after time.
Pretty easy to change out. You just need to pull the aggitator out and change the 4 little plastic ears. Good luck :)
Jul 13, 2009 | Kenmore 24032\24036 Top Load Washer
Kenmore 20842 won't spin or aggitate
Check your motor drive coupler. Tilt washer back against wall and look between motor and transmission . You will see a rubber grommet and two plastic couplers on each end of rubber , They may appear broken or you will see rubber shavings under washer.
May 11, 2009 | Kenmore 24032\24036 Top Load Washer
Aggitator won't work and won't spin/ drains ok
Coupling is bad.
There is a coupling between the motor and the transmission. When this part breaks then it will pump the water out but won't spin or aggitate.
Jan 18, 2009 | Kenmore 15944 Top Load Washer
Kenmore washer
ckd wires to motor ..next timer slim chance could be water level switch most likely motor wire
Jul 21, 2008 | Kenmore 24032\24036 Top Load Washer
Kenmore 24032\24036 Top Load Washer Logo
Sal DeAngelo
fordexpert
Ed Mac
