Question about Proscan 32LA25Q 32 in. LCD TV
Sleep timer won"t stop
Happen at 3pm
    New Friend:
  • 27 Answers
Get to the system menu and select reset
to return to the factory settings.
it may be defective
here are is the contact info for the manufacture
Limited warranty 12 months for parts and 12 months for labor.
Support URL: http://www.oncorpus.com
Support Phone Number: 1-888-977-6722
Posted on Feb 26, 2009
Sole treadmill won't go in to sleep mode
You need to go into the maintenance menu.
Take out the red safety stop key, hold down the "start", "stop" and "Enter" buttons, keep holding them down while putting the red key back in (a bit tricky), keep holding the keys down until you see "Maintenance menu" scrolling (this will happen as long as you didn't let go of the three keys).
Initially when you put the red key in it'll might show software version etc, after a few seconds it'll change to maintenance menu. Use the speed UP and Down buttons on the console or arm to scroll through menu until you reach "FUNCTIONS" press enter.
In the functions sub-menu, depending on what year model/software version it has, it should have a selection called "Sleep Timer" if so set it using up down keys to "ON". If your model doesn't have "sleep timer" listed (i.e. a newer model) it's now just called "DISPLAY" and in that case set it to "OFF". That should fix it.
Press Stop, to go back. If you want you can disable the key tone/training beeping as well in the "functions" sub-menu of the "maintenance menu".
To exit press stop repeatedly until you're back to the normal display.
Dec 30, 2012 | Sole Fitness F63 Treadmill
I have a 2003 sony kp51ws500 television and there's a timer on the tv and it won't turn on. A red light blinks 6 times then nothing happens. I unplugged, I hit the reset button, nothing happen
read the instruction manual and see how to operate.
if the timer is for to sleep, the problem will be the IC associates with him, you must see the block diagram and w.diagram. and tracking the signal.
go to www. retrevo.com and download the diagram. God bless you
Jul 31, 2012 | Sony Televison & Video
My radio powers off every few minutes. Needs to be turned back on by the on-off switch. How can I stop it from turning off automaticly?
When you press the Power/Sleep button the radio turns on and displays a number 90, or some other numbers. This is the play time that the radio will stay on then turns itself off. It could be that yours is configured with a sleep timer set to 01 minute, 10 or 15. You need to set the timer for a longer period. Thus we turn it on by pressing the Power/Sleep button, read the timer length then press again. Keep making short presses: The timer will cycle through all preset sleep timer durations. Select the length you want.
Jun 20, 2011 | Grundig S350 AM/FM/SW Radio
I HAVE A 42-1014 TIMER I SET IT SAY 3PM AND HOUR LATER IT IS STILL ON 3PM IS THE TIME SUPOSE TO DO LIKE A CLOCK THIS IS THE SECVOND ONE I GOT FROM WALMART AND IT DOES SAME THING
Timer is not identified.
If you have analog timer, the dial is supposed to rotate as time passes.
Check that circuit has power.
1) You posted under Intermatic T100 series outdoor timer.
Open following link to troubleshoot Intermatic.
http://waterheatertimer.org/How-to-troubleshoot-Intermatic-timer.html
2) My local Walmart does not sell Intermatic timers.
They sell Brinks timers.
Open following link for possible troubleshooting help for some types of Brinks timers:
http://waterheatertimer.org/Woods-timers-and-manuals.html#troubleshoot
3) Add a comment with photo of timer that you posted on Flickr for possible identification and help.
4) Upvote the help.
And take advantage of fixya expert assistance live.
For a price, expert works with you while you work on timer or any do-it-yourself project.
Fixya is always less expensive than a service call.
May 12, 2011 | Intermatic & Indoor/Outdoor Rain Tight...
Model 6626lct turns picture off in ten minutes.
This can happen for 2 reasons. One is that some TVs are equipped with a set up that will turn the set off if no input source is detected ( cable, antenna etc...) Check all connections. The most likely cause is the TIMER settings. Use your remote to access your menu, then TV settings, then into Timer (sleep timer). Set the sleep timer function to off ( or "0" on and "0" off) This should do it.
Jan 08, 2011 | Sylvania 6626LCT 26 in. LCD Television
This is a mechanical timer. The clock runs, but the timer never turns on the pump.
If the clock runs, the only thing left is the switches - and trippers.
If you can power up the pump by manually moving the switch from OFF to ON, that means the switches are good. The trippers are likely going to be the problem.
This timer needs white (or bright metal) "ON" trippers and black "OFF" trippers to turn the pump on and off at the times you select. The picture below shows a white ON tripper at 3PM (between 2 and 4) and a black OFF tripper at 11PM (between 10 and 12). This timer turns the load on at 3PM for eight hours and shuts it off at 11PM. You must have BOTH color trippers to turn ON and OFF. The trippers should be seated fully against the edge of the timer disc, and the screw tightened fully by hand.
More below the picture.
The manual can be seen here. Please rate my reply and good luck!
Dec 28, 2010 | Intermatic Mechanical Timer Switch - Pool...
Tv philips 29'' 29PT 9416/12 the time that the tv is on automaticaly alone stop. Then i turn on tv and it works.
You may have "sleep timer" set up. Try selecting "Timer" on your remote control to see if the "sleep timer" set. if so make it "0".
Nov 24, 2009 | Philips Televison & Video
Can't set the sleep timer
I have the same problem. Does anyone have a fix?
Dec 23, 2008 | Panasonic TH-42PX50U 42 in. Plasma HDTV
Proscan 32LA25Q 32 in. LCD TV Logo
Top Proscan Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Jaime Hernandez
Are you a Proscan Televison and Video Expert? Answer questions, earn points and help others
