Question about Nintendo Wii Fit for Wii
Wii balance board weight differently after put on a wii board sk
I weight myself regularly. Yesterday, I weight 7 lb less after I putted on a will skin on the board. What should I do?
    Sniper:
  • 80 Answers
Sometimes the silicone skin can have an effect on the Wii Fit Balance Board if it gets pinched. Make sure that it is not interfering with the the total movement of the top portion of the Wii Fit balance board and the space between the top and the middle of the unit. If there is any obstruction, refit the skin on the balance board.
Posted on Feb 27, 2009
Wii board does not show correct weight, sometimes im a stone heavier or half a stone lighter my actual weight
The Wii balance board isn't known for being hugely accurate, I wouldn't pay too much attention to what it says your weight is.
May 10, 2011 | Nintendo Wii Fit for Wii
How do you sync the wii fit board and wii console
  • Put four AA batteries into the battery housing located on the underside of the Wii Balance Board.
  • Insert a Wii Balance Board compatible game into the Wii system.
  • Select the "Disc Channel" on the screen with the Wii remote, and choose "Start."
  • Open the SD card slot to reveal a sync button on the Wii system. This is located behind a cover under the power and eject buttons.
  • Turn the Wii Balance Board upside down.
  • Remove the battery cover under the balance board to reveal another sync button.
  • Pres the sync button on the balance board, then press the sync button on the Wii. Do not hold down the buttons. You know it is synchronized when the blue light on the Wii Balance Board stays steady
  • Place the board on a flat surface directly in front of the TV. Face the power button away from the TV.
  • Mar 03, 2011 | Nintendo Wii Console
    Yesterday when connecting the balance board i held down the sync button too long and now the remoter for the console won't work. when i sent a request to fix this they told me to put a game in and ust the...
    If you hold the SYNC button in the SD Card Slot on the Wii console for too long (10 seconds or longer), all the remotes synced to your Wii will be erased and then you have to sync them and the Balance Board again.
    Visit support.nintendo.com
    Or call 1-800-255-3700 for assistance on your Wii
    Jan 05, 2011 | Nintendo Wii Remote Controller
    I have used my wii fit plus 3 times with no problem but yesterday i did body test then went training first few games were fine then it started saying my weight was a little different than before do i want...
    Yes, it's completely normal. To avoid this, try to take the BMI test at the same time everyday. If you have a big meal in between the weights, it might say that.
    Also, the batteries on the board may be running low. Try with some new ones and see if the problem persist.
    Also, try keeping the Wii Balance board on a flat hard surface, such as the floor. Do not use it on thick carpets since it might report bad measurements.
    Hope this helps.
    Aug 26, 2010 | Nintendo Wii Fit Plus for Wii
    The board thinks there is weight on it when there
    If you have tried turning the wii and balance board off and then on again (sometimes board can get confused when initializing), you may need to contact Nintendo for repair/replacement. If the board is new, try bringing it back to the store.
    May 02, 2010 | Nintendo Wii Fit - Balance Board + Game...
    Communications with the wii balance board interrupted
    dont push your feet hard or the batteries might come off of the cap isnt put on or the batteries are fully used
    Feb 12, 2010 | Nintendo Wii Fit for Wii
    I got a brand new wii fit balance board and i syncd it, put in the batteries that came with it, (new batteries) put on a cover, and its working fine. about 2 weeks later it was bought, I was playing a game...
    According to the Nintendo support site, here's what to do.
    Your movements are not being correctly detected
    1. Make sure that the Wii Balance Board is placed properly in front of the TV: The blue power light should be facing away from the TV. If the Wii Balance Board is facing the wrong way, your movements will be reversed.
    2. Check the battery life of the batteries in the Wii Balance Board. If the battery level is low, try a fresh set of batteries.
    3. Check to make sure nothing is pressing against the bottom of the Wii Balance Board. If you do find anything pressing against the bottom (such as carpet), try using the foot extensions.
    If the Wii Balance Board is still not correctly detecting your movement, please call 1-800-255-3700 for assistance.
    Here's the link if you want to see for yourself
    http://www.nintendo.com/consumer/systems/wii/en_na/ts/balanceBoard.jsp#movement
    Jun 08, 2009 | Video Game Consoles & Games
    Wii Fit Weighing Me Wrongly
    You should probably put it on a board but if that doesn't work, you could try putting something weighing 12 pounds on the board or in your pockets or whatever.
    Feb 28, 2009 | Nintendo Wii Fit for Wii
    Want to use two wii fit boards at the same time?
    You can't sync 2 balance boards to one wii.
    I heard this is why but this isnt confirmed...
    the wii can only register 4 controllers at one time... the wiifit balance board counts as 2 controllers, leaving only 2 controllers available... obviously a person would want at least one regular controller to use along with the wiifit balance board, so just using wiifit leaves only one free controller slot available...
    hope this helps...
    Feb 05, 2009 | Nintendo Wii Fit for Wii
    Nintendo Wii Fit for Wii Logo
    382 people viewed this question
    Top Nintendo Video Game Consoles & Games Experts
    Bee Santiago
    Raj Patel
    phil
    Are you a Nintendo Video Game Console and Game Expert? Answer questions, earn points and help others
