Question about HP LaserJet 4050n Printer
I have black vertical lines - HP LaserJet 4050n Printer
    Sniper:
  • 121 Answers
Image defects on LJ printers are usually the toner cart. or the fuser:
This is the test to determine toner or fuser issue.
Print a test page
When you hear the paper feed into the machine open the top to stop the machine
Remove the toner cart.
You should be able to see the page with printing on it. (This is before the page hits the fuser)
If you can see the image Defect on the page the problem is most likely the cartridge but NOT the fuser.
If the page is clean the problem is most likely the fuser.
Hope this helps
Posted on Mar 28, 2009
    Novelist:
  • 121 Answers
Black vertical lines could either be a scratch on the drum or a dirty charging corona wire. Order a new drum and clean the Corona with a brush. Image of Corona This should resolve the issue.
Thanks,
ArmyMason
Posted on Feb 26, 2009
How do I get rid of vertical black bars on a plasma television
Fix Panasonic Plasma TV Vertical or Horizontal Bars ...
? 10:21
https://www.youtube.com/watch?v=CpWZTnAXbLg
Dec 30, 2013 - Uploaded by Pet Rock's Garage
This video covers how to fix a Panasonic 42" Plasma TV model TH-42PX600U that has vertical distorted ...
Horizontal black lines on Samsung 50" plasma tv - Forums - CNET ...
www.cnet.com > Forums > Samsung
CNETJun 11, 2015 - This past spring, a thin black horizontal line appeared across the screen, everything else is working fine. Next day ... In reply to: Horizontal black lineson Samsung 50" plasma tv .... I tried a white wash on the TV, but that didn't removethe line. Plasma TV has 3 thin black lines
Jun 11, 2015
Black Line across Samsung 50" Plasma has appeared?
Jun 11, 2015
Vertical black line on Sony PFM-50C1 Plasma Display
Jan 28, 2007
More results from www.cnet.com
Jan 05, 2016 | Samsung Televison & Video
Vertical black line on scans or copies;
Hello James,
Please click Vertical Bands Lines or Streaks in Copies Faxes or Scans to access the troubleshooting steps that should resolve the issue.
Mar 03, 2014 | HP Officejet Pro L7680 All-In-One Printer
How to get rid of the vertical black line on the paper?
Usually replacing the toner cartridge fixes that problem. Sometimes it's the fuser.
Jan 20, 2014 | HP LaserJet 1018 Printer
Samsung scx-4521f xerox and printout taken a black vertical line appear on the paper
black vertical lines are generally an indication that the imaging drum needs to be replaced
Nov 25, 2011 | Samsung SCX 4521F All-In-One Laser Printer
Black vertical lines on samsung lcd tv.when powered on the black vertical line appears in the middle
Vertical lines are usually a a sign that your T-con board is going bad. You can get replacement parts for this TV at www.interliquidparts.com
Sep 27, 2011 | Samsung LN32A330 32 in. LCD TV
I have a black line on the tv samsung
IF YOU HAVE A SOLID BLACK LINE RUNNING VERTICALLY THEN YOU HAVE A FAULTY MATRIX INVERTER. IF CENTRAL THE MAIN VERTICAL INVERTER NEEDS CHANGED. LEFT = LEFT VERTICAL INVERTER RIGHT=RIGHT.........
ANOTHER WAY TO GET THIS FAULT IS WORN OR DAMAGED RIBBON/PLASTIC GOING FROM THE SCREEN MATRIX TO THE INVERTER
Hope this help......
Jun 22, 2010 | Samsung HLP4663W 46" Rear Projection HDTV
Black vertical line 2" wide with a very thin green line
The black vertical line is caused by a leaking capacitor, Check and replace poped capacitor with a new won and it will work fine again. No worries.
Thanks for using fixya.
Jun 27, 2009 | Panasonic Televison & Video
Nec plasma tv 42MP4
these plasma vertical black lines are notorious. there's a video of a fix on this plasma tv repair site. good luck!
Jul 29, 2008 | Samsung PPM42S3 42 in. Plasma Television
Screen only showing single line of video in center.
hi there, is the single line horizontally or vertically? if horizontal line, you do have a vertical section problem, check some parts at vertical section, the vertical ic, the power source of vertical section ie diode & resistors. ty
Dec 26, 2007 | Zenith Z32X31D 32" TV
HP LaserJet 4050n Printer Logo
623 people viewed this question
Seeker5211
Seeker5211
