Question about Bose 3 2 1 GSX System
What does the Bose car cd player code ''CPED'' mean?
Instead of playing my cds, often times my Bose cd player doesn't play it and it says the code CPED on the dispaly. Does this mean it needs cleaning or that it cannot read the cd?
  • 203 Answers
Get a head cleaner, clean it and see. if it still comes up then its not dirty. its a cd problem.
Posted on Feb 26, 2009
Why won't bose play some cds
Could it be the CDs you can't play, are burned in a PC?
Not all CD players can or will play CD's burned in a PC. Sometimes the CD player is to old, so not compatible with these CDs. Sometimes the player just does not play these CD's, because of rights protection.
A CD burned in a PC is less reflective than an normal music CD. Normal CD's do have a metal coating and are highly reflective. Burned CD's have a dye, and where the laser burned the dye, it only changed colour. Making it less reflective.
All modern CD playes should be capable of playing CD r's. But the player that is really compatible, is labelled CDr and CDrw compatible.
May 13, 2014 | Bose Wave music system Multi-CD Changer...
Not playable bose
your car stereo and computer are more than likely able to play the files but the bose cannot because the music files are burned in MP4 format I believe. I'm not sure if iTunes can be converted to MP3 so it will play in your bose.
Nov 09, 2013 | Audio Players & Recorders
Cd changer is not reading disc even after it was cleaned
Please check the format of the CD. It should be commensurate with the formats which can be played by the CD Player. This information is available within the booklet which has been provided with the changer. To give you an example I purchased Bose surround system in 1998. It can only play CD's which are recorded in wma format and will not play any mp3 CD. Some of the CD players do not play re-writable CDs. Please check.
Dec 02, 2010 | Bose Audio Players & Recorders
Can't play burned cds through bose
get a 3.5mm male to 3.5mm male cable(one end to the laptop headphone jack and the other end to the AUX jack of the Bose wave music system), you are good to go...
Jan 01, 2010 | Bose Wave Music System CD Shelf System
My front loader reads disc error or unplayable no matter what disc I insert. It worked just fine for about 2 years. It doesn ot get heavy cd use, but everyday radio/alarm use.
To resolve this issue, try one or all of the following:
  • The Wave® music system is designed to play commercial CDs, CD-Rs, MP3-encoded CDS and CD-RWs. If your system has trouble playing MP3 CDs, make sure the discs were recorded with compatible formats. See Cannot play MP3 CDs
  • The system may not be able to play certain CD-RW discs. Playability is dependant on how the disc was recorded, including the format it was recorded in and the actual disc used for recording.
    Note: iTunes defaults to AAC as the encoding format. In order to use iTunes to make CDs that will play on the Wave® music system, you’ll need to change the format to MP3 How to Choose Import Options
  • Different brands of CD-Rs and CD-RWs use different materials which may affect the ability of a player to read them. If you are burning your own CD-Rs or CD-RWs, experiment with different brands of discs
  • If a commercial disc won’t play, check for scratches, fingerprints or other physical damage. Try the CD in another player. If it still won’t play, there may be a problem with the disc
  • Reset the system by disconnecting the power cord from the wall for one minute, then plug the system back in
Dec 05, 2009 | Bose Wave Radio
Player will not play cd - it reads then says
Your CD player is failed. It will need to be replaced. Some folks can repair but it cost less to have it replaced. If no one local will do it BOSE will for about $150.
Jul 11, 2009 | Bose Acoustic Wave music system II -...
Dropped a portable bose cd player and now it doesn't "read" CDs
yeah im sorry but i think your cd player is junk now, most electronics dont survie a drop. did you try a different cd
Jan 11, 2009 | Bose Audio Players & Recorders
Error code 6 & error code 4
hi try first to insert a clean up CD, and test your Cd player with an original CD, if the problem persist , your laser sense is defficient you have to go to fix it to a specialist.
hope this helps you
sserpentio
May 21, 2008 | Clarion DXZ438R CD Player
My cd player wont play my burned cds
this happens all the time, instead of getting CD-Rs, try getting the CD-R Music, they are specially made to be played on CD players, I buy these all the time and they work in every CD player.
Feb 09, 2008 | Jensen CD4610 CD Player
Error 2 on Display
Mabye. I would suggest either opening the unit up and cleaning thr "laser" (optical pickup) with a q-tip. Or try using one of those cleaning cds that have the little cleaner fabric on the inderside... if that doesent work something is most like wrong with the cd machanism wether its not spinning the cd or just not reading it due to a defective laser.. ampman!
Sep 05, 2007 | Sanyo ECD-T1550 CD Player
Bose 3 2 1 GSX System Logo
149 people viewed this question
Top Bose Audio Players & Recorders Experts
Electro Med Services...
Are you a Bose Audio Player and Recorder Expert? Answer questions, earn points and help others
