Question about MSI K8MM-ILSR Motherboard
Try to install 2gb PC2700/DDR333 memory on MS-6741 motherboard
I try to install 2 X 1GB PC2700 184 PIN 333 MHZ DDR RAM on a K8MM-ILSR (MS-6741) motherboard http://www.msicomputer.com/product/p_spec.asp?model=K8MM-ILSR. With the new memory the computer is working but it became unstable (frozen screen, windows errors..) Do I have to change the bios setup? My old ddr RAM was 2 X 512MB PC3200 184 PIN 400 MHZ. I have flash the AMI BIOS to version 3.7.
Thank you.
Luc
  • 2 more comments
  • lucbourdages Feb 27, 2009
    Hi jell587 and djmadrik,
    Thank you for your quick answers. The part number of the memory stick is 1GBUFURTULAA. I also verify and the memory is set to auto in the bios, so the problem is still the same.
    Thanks again
    Luc
    Hi jell587,
    Thanks again for helping me with my problem. I bought this RAM on ebay ( http://cgi.ebay.ca/ws/eBayISAPI.dll?View... )
    Here are the spec given by seller:
    Product Details:
    184-pin unbuffered DIMM
    • Density: High
    PC2700 333FSB
    2.5 Volts
    • 6 Layer unbuffered
    • CAS Latency 3
    • 4 Bank
    • Off-chip driver (OCD) impedance adjustment, and on die termination (ODT)
    Technical Information:
    Memory Size:
    1GB DDR 184 Pin
    Number: 2 x 1GB
    Memory Speed: 333Mhz
    More Information:
    1024MB
    Non ECC
    Non Registered
    UnBuffered
    6 Layer
    Non Parity
    Physical Characteristics:
    Form Factor: 184-pin DDR, Gold Pin, Green PCB
    Warranty: Life Time Manufacturer warranty
    • Performance: PC2700
    • Dual Channel ready
    • 2.5 Volts
    • DQ DQ Burst Frequency: 333MHz
    • Inputs and outputs are SSTL-18 compatible
    • CAS latency 3.0
    • 128x4 X 2 DDR SDRAM CHIP CONFIGURATION
    • SDRAM have 4 internal banks for concurrent operation
    • Differential clock inputs
    • Data is read or written on both clock edges
    • Bi-directional data strobe with one clock cycle preamble and one-half clock post-amble
    • Address and control signals are fully synchronous to positive clock edge
    • Programmable Operation:
    • Burst Type: Sequential or Interleave
    • Burst Length: 4, 8
    • Operation: Burst Read and Write
    • Auto Refresh (CBR) and Self Refresh Modes
    • Automatic and controlled precharge commands
    • Serial Presence Detect
    • SDRAMs in FBGA Package
    • RoHs compliance
    But I don't know what I have to write on the Bios to make it working fine.
    I already try to put PC3200 400 MHZ but the MOBO don't see it at all as it is written on the user guide (
    The mainboard provides two slots for 184-pin DDR SDRAM DIMM (Double In-Line
    Memory Module) modules and supports up to 2GB memory size. You can install
    PC2700/DDR333 & PC2100/DDR266 modules on the DDR DIMM slots (DDR 1~2).)
    OK Thank you,
    Now I know what to change on the Bios but i don't find the latency (I have AMI Bios 3.31a). I know that it's supposed to be under andvanced chipset features menu but I found notting to set the cas latency.
  • John Elliott
    John Elliott May 11, 2010
    Hey Luc,
    According to Crucial.com these are the memory sticks that are compatible with your unit. Can you post the exact part number of the 1gb memory you have installed so that we can cross reference it?
    Thanks!
  • 77 Answers
Hiya Luc
the problem is with your memory, i have read your post and b4 you was using pc3200 and now using pc2700 have you made sure that the memory is set to auto in the bios as it sounds like it is still set to ddr 400 and not ddr 333
regards Rik
Posted on Feb 26, 2009
  • Richard Ray Feb 27, 2009
    hiya luc
    i notice that you only have 2 dimm slots on your mobo, i know that some boards have issue's with using max memory installed as this causes lock ups and random reboots this a limitation on the chipset
    Rik
  • 447 Answers
Hey Luc,
I got a chance to check on that memory part number. Most of the sources that I ran across were outside of the USA (and there were very few of them). Was this memory purchased from an online vendor or over the counter at a brick and mortar store?
Here's the thing - I can't find any listings for this memory module on ebay which is odd because generally you can find anything by punching its part number into ebay and a lot of the time you get more detailed specs on the part thru ebay than you would thru a regular web search. I did determine that the specs you posted were pretty much right but I couldn't get any more advanced specs than what you provided.
You may want to source a diffrent module(s) for your unit using the specs I posted a link to before and going with the PC3200 mods. Just make sure you match the CL and voltage detailed for your machine.
I wish there was a better answer for you but if I can't verify the validity of the memory you're trying to use than I have to recommend going with a different module altogether.
Post back here with your progress on this, I'll be curious to see how it turns out.
Posted on Feb 27, 2009
  • John Elliott
    John Elliott Feb 27, 2009
    In the PC2700 style your machine calls for CL2.5:
    1GB: DDR PC2700 • CL=2.5 • Unbuffered • NON-ECC • DDR333 • 2.5V • 128Meg x 64
    If using PC3200:
    1GB: DDR PC3200 • CL=3 • Unbuffered • NON-ECC • DDR400 • 2.6V • 128Meg x 64
    Note the difference in voltage and latency (CL). The memory you purchased on ebay has a latency of 3 (although it has the correct voltage) when the PC2700 recommended for your mobo is 2.5.
    If any other tech monitoring this thread wants to comment on this please do.
How many pins in the hyundai ddr 512mb?
SO- DIMM 512 MB 333 Mhz / 200 PIN PC2700 64Mx8
DDR SDRAM memory has 184 pins, where as SDRAM has 168 pins. DDR SDRAM Memory is a new type of SDRAM that is able to double the read / write speed of the previous generation of SDRAM memory. There are currently, PC2100 (DDR266), PC2700 (DDR333), PC3200 (DDR400), PC4200 (DDR533) These DIMMs are 184 Pin in size and are not interchangeable with older SDRAM modules.
Dec 29, 2010 | Dell Inspiron 1525 Notebook
I have 2 slots, currently only one is in use, it has 512 DDR 400 MHz PC 3200U. Can I use both slots and how much RAM will my SiS 963Lua support? Thanks. Richard
Hey Richard, your board has 2 x 184 DIMM slots, that are both usable, with a maximum capacity of 2GB, supported RAM types are 333MHz, and 266MHz..
Hope this is what you are looking for,
Cheers,
Memory Type DDR SDRAM Number of Memory Slots 2 x 184 Pin DIMMs Supported RAM speeds 333 MHz • 266 MHz Max Supported RAM 2 GB Memory Type DDR SDRAM Number of Memory Slots 2 x 184 Pin DIMMs Supported RAM speeds 333 MHz • 266 MHz Max Supported RAM 2 GB DDR SDRAM Number of Memory Slots 2 x 184 Pin DIMMs Supported RAM speeds 333 MHz • 266 MHz Max Supported RAM 2 GB
Apr 09, 2010 | Foxconn K7S741MG-6L Motherboard
Please identify RAM upgrade options for Asus PSCH-L motherboard. Thank you.
From the Asus spec site: Memory Memory Type dtrquestion.gif DDR SDRAM Number of Memory Slots 4 x 184 Pin DIMMs Supported RAM speeds 400 MHz • 333 MHz • 266 MHz Max Supported RAM dtrquestion.gif 4 GB
Memory Memory Type dtrquestion.gif DDR SDRAM Number of Memory Slots 4 x 184 Pin DIMMs Supported RAM speeds 400 MHz • 333 MHz • 266 MHz Max Supported RAM dtrquestion.gif 4 GB DDR SDRAM 400; 333; 266mhz
4 GB max 4x1024 184pin
Hope this helps.
Aug 26, 2009 | ASUS PSCH-L Motherboard
Ddr ram sdr ram i am same time input that tw0 thats not show two ram capacities just show one ram'' asus p4s533 model please help me
Hi safran0785,
The Asus motherboard, P4S533-MX can run two different types of memory.
(Just not at the same time & in different slots).
You can use 2, 184-pin memory, PC2700/PC2100 MHz or PC1600 up to 2GB. (1GB DIMMs) inserted in the two memory slots closest to the CPU.
Or you can run SDR memory, 168-pin PC133 or PC100MHz DIMMs up to 1GB of memory in the last two slots farthest from the CPU.
You can not run both types of memory at the same time.
The 184-pin DDR PC2700MHz memory is much faster then SDR memory.
The maximum amount of system memory supported is 2GB.
Need more information/questions, just post here.
Good luck safran0785!
Mike
Mar 22, 2009 | ASUS P4S533-MX Motherboard
Try to install 2gb ddr memory on MS-6741 motherboard
pls check you motherboard manual if it accept that kind of memory because some board cannot accept.
Jan 08, 2009 | MSI K8MM-ILSR Motherboard
Unable to get 3GB of memory to work on the motherboard
Hi enj1956, according to the manual the MB supports only,
"one" DIMM of DDR400MHz.
See page 2-7 in your manual.
You can use 3, PC2700/DDR333 / 3, PC2100/DDR266 or
3, PC1600/DDR200 to reach the 3GB.
All DIMMs must be the same memory type & speed.
MSI KT4V (MS-6712) link;
http://global.msi.com.tw/index.php?func=proddesc&maincat_no=1&cat2_no=&cat3_no=&prod_no=505
Good luck enj1956!
Any more questions?
Happy holidays!
Mike
Dec 23, 2008 | MSI KT4V (MS-6712) Motherboard
Want to upgrade from 512ddram to at leat 1G. How would i know that my new purchase would be compatible with my set. I'm using a pentium d 820 on foxconn 865G7mf-sh motherboard. Tnx.
http://www.foxconnchannel.com/product/Motherboards/detail_spec.aspx?ID=en-us0000166
That page has all the specs.
It says that you can use Dual Channel 400 / 333MHz DDR x2 DIMMs, Max 2GB
That can be bought at bestbuy for under 45 bux!
Kingston Technology Kingston ValueRAM - Memory - 1 GB - DIMM 184-pin - DDR - 333 MHz / PC2700 - 2.5 V KVR333/1GR $44.99
http://bestbuy.upgradebase.com/
Dec 16, 2008 | Computers & Internet
Memory
184-pin DIMM DDR PC2700-333 so nothing fancy or expensive.
Nov 02, 2008 | Foxconn 661GX7MJ-H LGA775 Micro ATX...
Upgrade RAM
Max Supported RAM is 3 GB Memory Type DDR SDRAM Supported RAM Speeds 400 MHz · 266 MHz · 333 MHzNumber of Memory Slots 3 x 184 Pin DIMMs
yes, I beleive you can...
Mar 21, 2008 | ASUS A7N8X-X Motherboard
Gigabyte GA-81EXW memory chips
Any 184-pin ddr ram should work on this. You can actually use pc3200 (ddr 400) ram as well. Pc2700 ram is ddr333, and a higher speed ddr ram like pc3200 will work just as well if not better than pc2700, it will simply go down to the speed that the processor requests the ram run at. It's all backwards compatible, faster ram can run slower if the computer needs it to run at the slower speed. Depending on the price you can find as long as you get 184 pin ddr ram either pc2700 or pc3200 with work fine with your motherboard. Peter
Oct 02, 2007 | Intel Motherboard
MSI K8MM-ILSR Motherboard Logo
1,179 people viewed this question
Top MSI Computers & Internet Experts
vsri9
Alun Cox
David
David
Are you a MSI Computer and Internet Expert? Answer questions, earn points and help others
