Question about Maytag Neptune MAH5500B Front Load Washer
I am trying to put a new boot back onto my Neptune front loading washer. I get it all lined up, carefully place the retention wire around with spring, start to pull the wire loop to the spring and the whole thing slips off into the middle. Is there trick I need to know. Im very frustrated.
  • kenandkristi Feb 26, 2009
    thanks
  • josh1111 May 11, 2010
    no trick thats part of fixing things! just a pain in the a**
    President:
  • Maytag Master
  • 2,651 Answers
I use a pair of needle nose vice grip pliers, to hold one side ofthe wire and pull with a nother set connected to the spring, the trick(pain in the a***) is to lean over the machine, or even better ifyou can ge to the side of the machine this allows you to pull straighter, infront of machine you tend to "pull" foward thus poppping off!!!
Posted on Mar 01, 2009
Wire came out of front plastic gray circular piece and washer leaked water everywhere
Sounds like some article of clothing got between the door glass and door boot and pulled the rubber door boot away from the front of the washer. Check and make sure the rubber boot is not torn. If it is ok you should be able to slip the lip of the door boot back onto the front of the washer, make sure you get it in the grove. Then put the wire retainer back around the boot, you may need an extra hand or two to hold it and stretch the spring back on. Hope this helps
Sep 02, 2011 | Kenmore HE2 Plus Front Load Washer
Trying to start the wash cycle on my Whirlpool Duet front-load washer and "DL" and "F" keep alternating on the control. What do I do?
1. Unplug washer.
2. Remove the outer portion of the door bellow. This is the gray rubber boot around the door. Feel around the edge of the door bellow where it attaches to the front of the washer. You will find a wire retaining hoop in the seam between the rubber and the front case. Follow this wire hoop to the bottom of the door bellow and you will find a tension spring. Carefully, stretch this spring apart and remove the wire hoop.
3. Pull the rubber bellow from the door facing on the front of the washer being careful not to rip or tear it. Once removed, fold the rubber backwards inside the drum so you can access behind the front panel. DO NOT remove the rubber bellow from the wash tub.
4. The door latch assembly is located behind the front panel of the washer on the right hand side. Locate and remove the three screws on the washer front that hold the door latch assembly in place. The whole assembly should come free from the washer front and be held by a plastic mounting bracket and several wire connectors.
5. Carefully remove the latch assembly from the plastic mounting bracket BEFORE attempting to unplug any wires. It makes it much easier to access if you do.
6. Unplug the wire connectors using care not to break any of the wires. You may want to write them down, but I believe they will only plug into their respective slots.
7. Remove the old door latch and install the new one in the reverse order of the steps I just presented to you. Plug the wires back in first, then place the whole assembly back into the plastic mounting bracket, and then reattach to the front of the washer.
8. Now, when you get the reinstalling the rubber door boot, you may want to get the assistance of a second pair of hands as it can be difficult sometimes to manipulate the wire retainer back into place. Carefully reattach the rubber bellow to the door facing on the front of the washer first.
9. Starting at the top of the door bellow at the 12 o'clock position begin inserting the wire hoop back into the groove. Work your way around with both hands to the 4 and 8 o'clock positions. (This is where you could use those second pair of hands). While holding a slight downward tension on the wire hoop to keep it in place, pull the tension spring apart enough to snap the remaining part of the hoop into place at the bottom. Once you've completed these steps make sure the door closes and latches properly. NEVER slam a door with an electronic latch. They can break easily.
Now plug the washer back in and test operate. NOTE: You can run diagnostics on these washers by referring to the tech sheet provided by the manufacturer. The tech sheet is located behind the lower panel under the door, or along the interior cabinet walls. Included, are instructions on how to run diagnostics and troubleshooting tips associated with the list of fault codes. It is recommended that this tech sheet remain inside the washer to prevent it from being lost.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.@#$%
Jun 07, 2010 | Whirlpool Duet GHW9150P Front Load Washer
A couple weeks ago our Kenmore HE4T front load washer was flashing a FDL code. called Sears and was told we needed a new door lock module. received it last week. Put it in and it worked fine until today....
1. Unplug washer.
Mar 28, 2010 | Kenmore 3.8 cu. ft. HE4t Front Load Washer
Hi looks my Maytag Neptune needs to have the front boot replaced
It is not too difficult to replace the boot. You have to remove the door (remove the screws that go into the door frame, not the door itself, and tilt the door out). Remove the screws on the opposite side of the door frame and remove the front panel (this will hinge on the bottom). From there, remove the soap dispenser bezel (4 phillips screws) and the two brackets (5/16" nutdriver) that are located in the front, just under the top. Now the top will tilt up. The boot will be pressed into the white plastic boot bezel (tongue and groove style) this needs to be pulled away from the bezel at this point. Now, remove the (4) 5/16" screws that hold the boot bezel in place and put aside. There is a wire ring with a spring that holds the boot to the drum, carefully roll the ring off the boot, it may snap on you so be careful. Pull old boot off and replace with new. Make sure to align the new boot with the indicators on the drum. *****NOTE!!! A bad boot is often an indicator of other part failures, most common of these are the shocks/struts that are under the drum assembly. If these are bad, your new boot will go bad quickly.*******
Dec 07, 2009 | Maytag Neptune MAH5500B Front Load Washer
Door boot seal on a front load washer how to change
front gasket/door boot.... replacement isn't easy but do-able. first remove three screws that hold front lower panel on and remove panel (where lint filter is). then remove 3 screws that hold on top panel (screws located at rear of top of washer), next remove 3 screws on top front of washer, then remove 4 screws that secure the contol panel. you must remove the washer door at this point, just a few screws and pin hold the door on. now, remove control panel by gently pulling the top away from the washer, it's held by a few plastic snaps. then, remove three screws that secure front panel of washer. now you're ready to remove the old boot/gasket. first look toward lower right side of gasket and pull the spring and remove wire that secures front of gasket. next... at about 3 o'clock on the gasket you'll find a longer screw (about 3 inches) that secures the rear of the gasket. loosen this screw until you can remove the gasket. remove the water inlet and hose from the boot/gasket.... now remove gasket from washer. you're ready to install new boot/gasket. find the small triangle on the new gasket and line this up w/the triangel at the top of wash tub. begin working the gasket onto the lip of tub, make sure to align the triangle and water outlets of the gasket w/the triangle and outlets of the washer tub. once back of gasket is on install the rear wire holder and tighten screw to former tightness. now work front of gasket onto the lip of washer, install spring wire to secure the front. place water inlet and hose into respective holes on the gasket. put front panel back on, put door on, put control panel on, put top on... and wash. like i said, not easy but do-able... i completed it in 1.5 hrs w/no instruction.
Nov 11, 2009 | GE WSXH208A Front Load Washer
How do I open the top of my front load washer (Neptune Mod. MAH3
there 3 screws on the back u take off but to take door latch off u dont need top off u open your door take the spring off the front of your boot then remove the screws from door latch reach back there behind boot unplug put new in and put back togather
Apr 08, 2009 | Maytag MAH6700AWW Neptune Front-Load...
Maytag Neptune front loader rubber boot replacement
can be done just need PATIENCE!.. youll need ot remove the door assembly, and the 2 screws oppisirethe heing willalow for the front "u" shaped panel to be reomved.. next remove the 4 screws from with in the dispenser area, and then there are perhaps (6) 5/16 screws holding the nextfront bulkead and maintop assy down.. after removing theese screrws youll be able to lift eh main top back wards( prop it with something, a few more screws will release te hlatch assembly.. from here you can probably install the new bellow, remove the spring and wire, and the work the new bellow around the tub lip. a third hand will come in handy, after working it around , youll needto reconnect the tension spring..HARDEST PART OF JOB>>> REQUIRES PATIENCE!!!!!. sometimes this goes on for me with out issue in 5 min, other times 25 min and im PISSED AT IT!!!!!!!,, wrap the wirer around bottom of lip and your going to hold one end of spring, needlenose vice grips work perfectly. then with another set of needle nose. stretchthe spring togethr to lock the wire around.. whern you finally get this reassemble the latch and drop the top back down replace all teh screws, and finally you need to retuck the bellow into the front bulkhead( tabbs line it up nicley.. good luck!!!
Feb 21, 2009 | Maytag Neptune MAH5500B Front Load Washer
I need to replace the door lack how do i do it??
the front boot can be pulled off from the front to get to it
Nov 25, 2008 | Maytag Neptune MAH5500B Front Load Washer
Maytag washer door boot
   Remove 2 screws holding door hinge to cabinet and remove door.  Then remove 2 screws opposite these. Grab front panel with thumbs at area of screws you removed and pull outward with thumbs. Panel will pivot forward.  Remove panel from lower clips.  At top of exposed area remove 2 5/16 screws.  Remove brackets under them.
  Open dispenser and remove 4 screws.  Careful not to drop in dispenser.  Remove dispenser frame assembly.
  You can now raise top of washer to a 90 degree position.
   Now back to front exposed area.  Grab boot where it contacts front and peel out of groove.  Also remove two screws holding light assembly and remove cover.  Remove all 5/16 screws holding front assembly and the ones on top area where it is on a bevel.  Remove front assembly by folding up and onto top.
  Now we are at the boot.  Remove spring and wire assembly holding boot to drum.  Make note on boot position and spring position.  Remove boot.  Install new boot onto drum.  wrap wire around drum with ends at top.  Now the fun!  Hook spring to on end of wire and using vise-grips,  pull to other end to hook into wire.  It can be done,  honest.
  Now just reverse to reassemble.  should be instructions with boot.   Good luck!
Oct 14, 2007 | Maytag Neptune MAH5500B Front Load Washer
Maytag Neptune Door Boot Change
Oct 05, 2007 | Maytag Neptune MAH5500B Front Load Washer
Maytag Neptune MAH5500B Front Load Washer Logo
62 people viewed this question
Top Maytag Washing Machines Experts
Richard Roth
Richard Roth
Bill Long
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
