Question about Vacuums
How to replace power cord on Electrolux 6500 epic series
Need to know how to get the top off a Electrolux 6500 epic series
so I can replace the power cord
  • hrvster Mar 01, 2009
    need to replace the cord and would like to lubricate motor on
    Electrolux upright 10 years old.
  • 44 Answers
SOURCE: Repair manual for Electrolux EPIC 6500 SR
I don't have a manual for these but the trickiest thing about these units is taking them apart. If you have an Aerus/Electrolux dealer near you, it's not a bad investment to have them install the motor for you. You would probably receive a warranty with the work, and the things a long time. Great return on investment. But if you are determined to do it yourself, open the front of the canister and remove the bag. As you are looking at the front of the unit, there are two vinyl coverd strips that run the length of the unit. Pull forward on these strips and then pull out so that the vinyl seperates from the plastic underneath. Now grab the plastic strip with a pair of needle nose pliers and pull towards the front of the canister. These can be tough if the machine has never been opened up before, but pull as hard as you need to, to slide the strip out. Once both strips are out, turn the machine over, pull out on the sides of the bottom of the unit, and lift up. The bottom should come of relatively easily, and eveything will be exposed. Good Luck!!
Posted on Jan 01, 2009
  • 44 Answers
SOURCE: I can not get the power cord to go back into the canister.
If you can't get it to go back in by pulling on it, you will need to open up the machine to rewind it by hand. Open the front of the canister and remove the bag. As you are looking at the front of the unit, there are two vinyl coverd strips that run the length of the unit. Pull forward on these strips and then pull out so that the vinyl seperates from the plastic underneath. Now grab the plastic strip with a pair of needle nose pliers and pull towards the front of the canister. These can be tough if the machine has never been opened up before, but pull as hard as you need to, to slide the strip out. Once both strips are out, turn the machine over, pull out on the sides of the bottom of the unit, and lift up. The bottom should come of relatively easily, and eveything will be exposed. You can now see the cordwinder and the spring that pulls the cord back in. If it's not broken, you should be able to manipulate the spring reel by hand and get the cord started so that it will rewind by itself. If not, you probably need to have the cordwinder replaced. Good Luck!!
  • 44 Answers
SOURCE: I need a service manual Electrolux 6500
I don't have a service manual but maybe I can give you some instructions that will make some sense. Open the front of the canister and remove the bag. As you are looking at the front of the unit, there are two vinyl covered strips that run the length of the unit. Pull forward on these strips and then pull out so that the vinyl separates from the plastic underneath. Now grab the plastic strip with a pair of needle nose pliers and pull towards the front of the canister. These can be tough if the machine has never been opened up before, but pull as hard as you need to, to slide the strip out. Once both strips are out, turn the machine over, pull out on the sides of the bottom of the unit, and lift up. The bottom should come of relatively easily, and everything will be exposed. The control valve rests under the bag housing, since the machine is now upside down. I hope this helps. Good Luck!!
Posted on Jan 03, 2009
SOURCE: Replace power switch - Electrolux Epic series 6500
well, i post an answer in the wrong field, and i can't find it, so i will type one more time.
slide two vinyl side pieces off, and remove top halves. remove two screws from the switch, and remove it from top halve. between switch and outside button is a plastic rocker, which is broken. you will find two broken pieces, one spring for the rocker piece, and one small plastic rod, which goes inside of the spring for support. i do not know if part is available, but you can for quick fix like me, turn the switch on by the hand, assemble unit, and plug in, and plug out from the wall. whay? i dont have electrolux store close by.
john
Posted on Apr 04, 2009
  • 10 Answers
SOURCE: 1 ) how do you open the body of the vacum ? 2)
Very Carefully! LOL! Disconnect the hose from the door. Open the door. Remove the bag. Flip the vacuum on its top. You will then need to remove the trim pieces from the sides by sliding them toward the front of the machine(bag opening). Usually they won't want to go easily. The way I used to do it was by wedging a screw driver between the rear cover and the trim piece then gently tapped the side of the screw driver blade toward the front. Once you get enough hanging over you can grab and pull them the rest of the way. The vacuum should separate once the trim has been removed. ****I have to warn you. If you have never done this before it is extremely important to take note of how and where everything goes on an Electrolux. They are complex machines that are assembled in a fairly meticulous way.**** The best way for someone that has not had any training to replace the cord is by replacing the cord winder assembly that comes with a new cord. Otherwise you have to disassemble the cord winder. Not fun.
Posted on Jan 04, 2010
Testimonial: "Thank you very much. Could not have done it without the info. Tightly packed all together in there. PoppaMike"
Electrolux Epic 6500 SR cord will not rewind
Unfortunately most cord reels cannot be repaired and must be replaced as a unit.
That Vac Guy
Apr 13, 2013 | Electrolux Epic 6500 Vacuum
How do I access the hepa filter on my Electrolux Epic series 6500 RA?
Look at the back of the machine. There will be a "tab" on the top piece (aka tool caddy or air diffuser). Press on tab, lift tool caddy off machine. To remove afterfilter, simply lift off. Replace, if desired, to continue the filtering process.
Oct 24, 2010 | Electrolux Epic 6500 Vacuum
I have the electrolux vacuum epic series 6000 SR and bought it used therefore I dont have a manual. I have had it for about a yr and it worked great..it looked like it should have a filter but I didnt...
1. A manual can be downloaded from:
http://www.aerusvacuums.com/support/manuals/.
The Epic 60006500 is located under "Older Models". Download the Epic 6500 manual
2. Check for clogs in the hose and the power nozzle inlet.
3. Disconnect hose. Turn on vacuum. Does it run? If so, place hand over intake? Did it shut off? If it did, the problem is a worn out or broken component inside the vacuum. Generally a result of using generic "made to fit" Electrolux bags. This is a part that needs to be replaced in an authorized Aerus (Electrolux) shop.
Sep 15, 2010 | Electrolux Epic 6500 Vacuum
I am looking for an owners manual for my Epic Series 6500 SR.
Owners manual in pdf-format Electrolux Epic Series 6500 SR:
http://homeappliance.manualsonline.com/ex/thread/view/idThread/1424472
Clicking "Epic6500.pdf" will pop up a registration shortly,
but the manual appears directly after that.
Aug 09, 2009 | Electrolux Epic 6500 Vacuum
john
Feb 21, 2009 | Electrolux Epic 6500 Vacuum
Electrolux 6500 SR
The cord light just indicates that the machine is plugged in and has power. In other words, you did great!
Nov 20, 2008 | Electrolux Epic 6500 Vacuum
Vacuums Logo
415 people viewed this question
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
