Question about Acer Aspire One PC Notebook
I want to make a video but how?
I want to make a video i have xp windows i have windows movie player but i dont now what do i press so i start videoing myself
  • 3 more comments
  • yomnaz1998 Feb 26, 2009
    it is the camera on the laptop.
    hi sorry but i cant find crystal eye on my laptop usally acer use crystal eye i searched for it but its not there is there anything else you now for the cameras instead of crystal eye
    thank you !
    product name :nootbook pc
    model number:zg5
    thats all i now i hope it helps you
    thank u again
    unfortunatly none of them work i tried more then 2 times and they wont work its okay if u dont now anything else and thank you soo much for helping me
  • RescueTechLA
    RescueTechLA May 11, 2010
    You need a camera. Have you got one? If so, what kind?
    President:
  • 2,653 Answers
Acer has a program on most of their laptops called Crystal Eye or something.
Check in your programs list for it.
Just run the program and there should be a record button somewhere.
Sorry I can't tell you exactly what to do step by step since I've never owned an Acer.
Afterwards use Windows Movie Maker and import the video into the program. Now you can edit the video, add music, etc.
Let me know if you get stuck.
Best of luck!
Posted on Feb 26, 2009
  • 1 more comment
  • RescueTechLA
    RescueTechLA Feb 26, 2009
    What's the exact model of your laptop?
  • RescueTechLA
    Your laptop isn't supported by Acer offically.
    These were a pain to find. Hopefully one of them will work for you.
    http://download.notebook-driver.com/driv...
    Copy and paste the above addresses into your browswer than download, unzip the files and run the setup or install files.
    Let me know what happens.
  • RescueTechLA
    Sorry man, this is what happens when new operating system's come out, slowly but surely users are forced to use them or end up with problems like yours.
    You can try using the windows update "custom" search. Drivers might pop up under the hardware section.
    If not, try again in a month or so and hopefully someone will by then will have found a compatible driver.
    Take it easy,
    RescueTechLA
The file format is not supported
Hi driddle00...
This information came from the Microsoft WebPage:
"Cannot play back the file. The format is not supported. This behavior occurs because PowerPoint can play back only QuickTime movies (.mov and .qt files) that use compression schemes with corresponding Media Control Interface (MCI)-compatible codecs.
A codec (compressor/decompressor) is an algorithm or scheme that is used to record digital video or audio. For example, when you transmit video over the Internet, the video must be compressed on the sending end and decompressed on the receiving end. A codec can be chosen based upon the user's audio or image quality and image size preferences.
When you read a QuickTime movie, a Video for Windows decompressor decompresses the QuickTime files. If the decompressor does not support the compression method used by the QuickTime movie, the decompressor cannot display the movie on the screen.
To work around this behavior, use one of the following methods. uparrow.gifBack to the top Method 1: Create a hyperlink to the .mov file loadTOCNode(2, 'workaround'); Create a hyperlink to the .mov file, and then let the QuickTime Player for Windows play the file instead. To do this, follow these steps:
  1. Select the object or text that you want to assign the hyperlink to.
  2. On the Insert menu, click Hyperlink.
  3. Under Link to, click Existing File or Web Page.
  4. Select the QuickTime movie that you want to play, and then click OK.
    Note Under Look in, click Current Folder to see a list of files, click Browsed Pages to see a list of recently viewed Web pages, or click Recent Files to see a list of recently used files.
During the slide show, click the linked object or text to play the movie. If a valid player is available, the player starts, and then the player plays the QuickTime movie. uparrow.gifBack to the top Method 2: Convert QuickTime movies to AVI format loadTOCNode(2, 'workaround'); Note In the following steps, you must use QuickTime 4.0 Pro. You cannot follow these steps with the basic version of QuickTime 4.0. The steps are the same for both Windows and Macintosh versions of QuickTime 4.0.
You can use other QuickTime editing programs instead of QuickTime 4.0 Pro. To do this, see the QuickTime documentation for the relevant steps.
To convert the QuickTime movies to AVI format, follow these steps:
  1. Start QuickTime Pro, and then open the file that you want to convert.
  2. On the File menu, click Export.
  3. Set the Export file type to Movie to AVI.
  4. Click Options, and then click Settings.
  5. In the Compressor group, click the list of compressors, and then select one from the previous list. Cinepak is a popular format. Select the format that you think works best with the movie.
  6. Make sure that you change the extension on the file name to .avi, and then click Save.
uparrow.gifBack to the top Method 3: Recompress the QuickTime movies with compatible codec loadTOCNode(2, 'workaround'); Note In the following steps, you must use QuickTime 4.0 Pro. You cannot follow these steps with the basic version of QuickTime 4.0. The steps are the same for both Windows and Macintosh versions of QuickTime 4.0.
To recompress the QuickTime movies with compatible codec, follow these steps:
  3. Set the Export file type to Movie to QuickTime Movie.
  6. Click Save.
uparrow.gifBack to the top Verify that QuickTime movies are compatibleYou can use Microsoft Media Player to... loadTOCNode(1, 'moreinformation'); Verify that QuickTime movies are compatible loadTOCNode(2, 'moreinformation'); You can use Microsoft Media Player to verify that a QuickTime movie is compatible with PowerPoint.
Note Microsoft Media Player (Mplayer.exe or Mplay32.exe) is a different program than Windows Media Player. Microsoft Media Player is included with various versions of the Windows operating systems, and is an MCI-compliant device. Windows Media Player, however, is a new technology that does not rely on MCI to play various forms of media. Windows Media Player can play a wider range of video and audio formats than Microsoft Media Player can play.
To determine the compatibility of the movie, follow these steps:
  1. Click Start, and then click Run.
  2. In the Open box, type the appropriate command for your operating system:
    • In Microsoft Windows 98 or Microsoft Windows Millennium Edition, type mplayer.exe, and then click OK.
    • In Microsoft Windows NT 4.0, Microsoft Windows 2000, or Microsoft Windows XP, type mplay32.exe, and then click OK.
    Microsoft Media Player starts.
  3. On the File menu, click Open.
  4. Select the QuickTime movie that you want to verify. Click Open.
If the QuickTime movie is compatible, Microsoft Media Player opens the movie. If Microsoft Media Player opens the movie, but PowerPoint does not, there may be a problem with PowerPoint or with the MCI settings. If Microsoft Media Player does not open the movie, and then you receive an error message in Media Player, the movie is not compatible and cannot be played in PowerPoint. You may be able to make the movie compatible by using one of the methods described in the WORKAROUND section of this article."
Sep 06, 2011 | Philips GOGEAR SA6045 MP3 Player
When starting Windows Media Player, suddenly "Activemovie" starts and plays the movie with no controls. Where did it come from?????
Its playing default video, please right click on top of Window Media Player and you will see menu, navigate anywhere you want, you can also change the view of WMP by click on "View" --- "Classic Menus"
Sep 09, 2009 | Microsoft Windows XP Professional With...
Cannot get the visual from the videos
Today with HD High Definition TV these kind of problems appears because the new dvd players have more video resolution options, so, for playing all variety of dvd, and home done dvs,s (like family movies on dvd) you need set up your resolution video on your DVD player at 480i or 480p option, not higher because some DVD movies (mainly oldies) have lower resolution than newer , for example new movies on HD format have 1080 P resolution, and if you have this option chosen in your DVD player you only can see this kind of videos, on the other hand if you have chosen 480i or 480 p on your dvd player , you can play all dvd formats including home movies made with any movie software, in this way you can play dvd-r and +r movies and of cours you can play HD movies also. So put some dvd where your dvd player works well (you need see the dvd menu in the tv screen), then press stop. Then press setup in your remote control, go to video resolution and choose 480 I or 480p, then press ok AND ENJOY THE MOVIE.
Smart techniques
Jun 24, 2009 | Insignia IS-DVD1001 DVD Recorder/VCR
Problem in operating system
Hi So when you insert a DVD in your drive your computer probaly starts the default software to see that DVD. So if you installed any movie viewer recently uninstall it. You may need also to update your windows media player to the latest version. Of course i bet you already tried more than 1 dvd but i suggest that you try to insert a data/backup/game dvd anything that would not start the movie player software, and see how it goes. About your movies folder, it could be an old problem i had many years from now, about some video codec messing up the XP thumbnails. To fix this i had to find and remove that codec. now i use VLC as my video player and no need to install a million codecs anymore. So it could be related to the first problem, a video codec is messing with your video player. Hope this helps
Jun 03, 2009 | Acer Aspire 4720 Notebook
Vista doesnt play video clip files
download vlc media player it plays almost all video and audio codecs..
Dec 03, 2008 | Microsoft Windows XP Home Edition
Install video on archos605wifi from pc without windows media player
I dont like it to use Windows media player and to synchronise.
In Settings -> System you need to set USB on 'PC Hard Drive'
Then you can use My Computer to find the Movies, just copy and past them in Archos -> Video map. Notice that Archos can't play any movie, you need special extensions.
I kow 1 exension, I convert my movies always in that 1 so Archos can read the movie: AVI MPEG4
There are more, but I need to find out.
Anyway, good luck trying to 'install' video's on Archos and also watch them ;)
Sep 10, 2008 | Archos 605 WiFi Digital Media Player
HOW DO I PUT VIDEOS AND MOVIES IN CREATIVE ZEN MP3
idk how to put movies on but put your videos onto your computer then download them onto windows media player in your library and then go to sync and drag them to download and them click start sync
Aug 28, 2008 | Creative Labs Zen Digital Media Player
Videos cannot be transferred to the PC (Windows XP)
Maybe you need a movie playback application that should be installed on your computer that supports the file format of the video from the camera. I believe the video file format from the camera is mpeg. You may try Quicktime player whick also works with Windows.
http://www.apple.com/quicktime/player/
Or you may try VLC Media Player.
http://www.videolan.org/vlc/
May 01, 2008 | Pentax Optio 50L Digital Camera
How do you put movies dvds and videos on your mix max mp3 player?
Ok these are the directions from start to finish.
You need Prism Video Converter and Windows Media Encoder 9 series. You can google both and download for free. You use Prism Video Converter to convert AVI or whatever file to WMV and then use Windows Media Encoder 9 Series to convert the WMV file to a WMV9 file. I know its stupid but if you follow my directions it will work and it cheaper then buying the individual cartridges. Once you have these installed do the following.
Click and open up Prism Video Convertor.
Click to "ADD FILES" on top toolbar. Find and choose the movie you want to convert and double click on the movie and it will add it to the list. Add all the movies that you want to convert. Each one takes about an hour.
At the bottom choose a different output folder. Then scroll through the OUTPUT FORMAT tab at the bottom and choose. .WMV
Click on ENCODER OPTIONS and change everything to the following:
Video Compressor------ Windows Media Video 9
Video bit rate ------------- 4096
Sound Compressor ----- Windows Media Audio 9.2
Sound Format ------------ 128 kbps,48 kHz Stereo CBR
Press ok and then click on VIDEO OUTPUT OPTIONS and change everything to the following
Make sure that there is a check next to RESIZE VIDEO "Shrink or enlarge video to selected size."
Width---- 220
Height --- 176
Make sure that there is a check next to CHANGE FRAMERATE
30.00
Click on OK and then CONVERT when the movie is finished you can move on to the next step
STEP 2
Open Windows Media Encoder 9
click on COVERT A FILE and press OK
Then choose your source file ( the movie you just converted with Prism)
Then Choose a new output file like make a new folder and name it MIX MAX MOVIES and click ok
On the next screen just press ok. Don't worry about the setting at this point because we will change them later.
Name the movie. and click ok and FINISH
Once the converter starts press the STOP button on the top toolbar., its RED, a window will pop up, click CLOSE to close the window. Then at the top of the converter click on the PROPERTIES tab. A window will pop open. Click on the COMPRESSION tab in the middle of several tabs. Click EDIT on the right hand side of the COMPRESSION window.
Now you should see 2 tabs. A GENERAL tab and a 259kbps tab
On the GENERAL TAB change everything to the following:
Make sure Video and Audio are both checked
Audio CBR Windows Media Audio 9.2
Video CBR Windows Media Video 9
Click the 259kbps tab and change to the following. ( If you see something I don't mention here THEN DON'T CHANGE IT )
Audio Format 128 kbps, 48 (NOT 44) kHz Stereo CBR
Video Size 220X176
Frame Rate 30
Key Frame Interval 2 sec
Video Bit Rate 384K (this is a little tricky. MAKE SURE IT SAYS 384K)
Buffer Size 5 sec
Video Smoothness 0
Decoder Complexity Simple
for a total of 521.02
CLICK APPLY and wait a few seconds for it to apply and then START ENCODING on top toolbar. When this movie is finished it will play on your MIX MAX, if it still says that the FILE IS NOT SUPPORTED then you have to go into the setting on the max and change the mass storage setting. There are 2 choices can't remember off hand what they are but choose the opposite one obviously and try again. Also you actually have to go to the movies or video tab on the max player not NOW PLAYING cuz that button is pointless.
any problems email me @ cera1756@gmail.com
I have converted many movies that have worked on both our players so if you follow these directions correctly there shouldn't be a problem.
ENJOY
Jan 18, 2008 | Disney Mix Max Digital Media Player
Acer Aspire One  PC Notebook Logo
150 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
