Question about Canon PIXMA MP780 All-In-One InkJet Printer
Difficulty sending a fax
I am having difficult sending a fax can you send me step by step instructions on how to send a fax using my canon PIXMA MP780. I have tried and tried (10 times) with no sucess. am I pluging in the phone line in the right plug? what kind of message do I get if I am successfull? presently I am getting "busy/ no-signal" error message. Is this an error on my end or theres? I am asking this because now I am getting confused in the logic of things to do and there sequence.
  • 398 Answers
Busy no signal could mean a few different things. the line your sending to could be busy, your line could have a problem. all you have to do to send a fax, when your hooked up to the phone line is hit the fax button, type in the number, and hit send or enter, and it should start dialing and processing it. you cannot use the phone at the same time or it will knock you off. hook a phone up to that same line and see if it works if it does and the fax machine dials the number it isnt your problem.
Posted on Feb 26, 2009
  • 37 Answers
Hello. Please make sure your telephone line is plugged into the correct outlet.
Most fax machines typically allow you to plug the line (the cord that goes from the fax machine to the wall jack) and and a telephone (the telephone connects to the fax machine).
In order to fax correctly, you must plug the line into the jack with a block (looks like a 'T') marked on it. Do not plug the line into the jack marked with a phone hand set marked on it.
http://gdlp01.c-wss.com/gds/0900002546/PIXMA_MP780_750_Easy_Setup_Instructions_EN.pdf
This shoulds in detail how to connect the line properly. For this printer the line cord must be plugged into the jack labelled "L"
http://gdlp01.c-wss.com/gds/0900002542/PIXMA_MP750_780_Quick_Start_Guide_EN.pdf
This will show you how to actually send the fax. On your PDF View select page 42.
Canon pixma mx922 will not send fax error
The connection is through the rj11 port to your phone socket. Sorry if that sounds odd, just checking as a first step.
Jun 18, 2015 | Canon Pixma MX922
How to fax something using a canon mx320
If you have connected the device to a phone line, to send a fax simply press the FAX button, load the documents you wish to send in the top feeder, dial the number you wish to fax them to & press either start button
Aug 22, 2014 | Canon PIXMA MX320 Color USB InkJet Printer
How can your fax machine on your canon pixma mx397 work? steps please.. thanks!
For details check Canon Pixma Mx397 Manual. Turn on your your printer. Press "FAX" button from printer. Load the document you want to fax on platen glass. Customize scan contrast and resolution settings as you need. Use numeric numbers to dial receiver telephone number. Start sending. You document will be faxed successfully.
Aug 03, 2013 | Office Equipment & Supplies
Hoe do I set up fax functions on Canon Pixma MX452
My incoming fax issue was resolved when I enabled the answering machine function on my phone. All this time my answering machine was turned off. I have yet to send a fax. My model is the Canon Pixma MX452.
Apr 05, 2013 | Canon PIXMA Office Equipment & Supplies
How do i send a fax?
Hi kimberley299,
To send fax using your Canon Pixma MX340 follow the steps below:
1. First, you need to hook up a phone line from the wall jack to the lower phone jack on the back of the PIXMA.
2. Now go into the menu and set your PIXMA to telephone priority mode (manual fax recieve), fax priority mode (auto fax receive) or distinctive (fax) ring/auto answer mode.
3. To send faxes, put your originals in the feeder or on the glass, select fax mode, enter the phone number, and press start.
Hope this helps.
Thank you for using FixYa.
May 09, 2011 | Canon PIXMA MX340 Wireless Office...
I dont know how to send faxes woth my canon mx310. Where do i put the phone line in the spot that says L or under the picture of the phone?
You need to use your PC to send/receive faxes. You cannot directly use your printer to send/receive faxes. I dont know what operating system (e.g. Win7, Vista, Mac) you're using. But if it's windows, you can find instructions on how to set it up by clicking on the link below.
http://tinyurl.com/2b37whh
Hope this helps.
Oct 24, 2010 | Canon PIXMA MX310 All-In-One Printer
I not send a fax
If your having issues trying to send a fax does it give an error message? But if your not having an issues and need help setting the printer up to send faxes follow these steps.
Make sure you have the telephone line connected into the correct plug-in on the printer.
Go into the menu display on the printer and follow the steps on setting up your printer to send the faxes.
Once that is all done you there should be a button on the control panel that says "Fax" push that.
Now place your paper(s) in the top tray (face up or down depepnding on how your printer wants them. Look for the icon) that you need to fax over to where ever you are sending it.
Dial the fax number with the key pad and then click "send" or "start".
Hope this helps. Have a great day.
Jul 21, 2010 | Canon PIXMA MX310 All-In-One Printer
Sending a fax directly from computer using Canon Pixma MX 310
With the document open, you click Print, then choose Cannon ...Fax.
http://www.usa.canon.com/consumer/controller?act=ModelInfoAct&tabact=SupportDetailTabAct&fcategoryid=238&modelid=15603
Jan 02, 2009 | Canon PIXMA MX310 All-In-One Printer
We cannot receive or send faxes
hello dmhertz
anything here that may help Canon .
riz.
May 12, 2008 | Canon PIXMA MP780 All-In-One InkJet...
Canon PIXMA MP780 All-In-One InkJet Printer Logo
459 people viewed this question
old marine
old marine
