Question about JVC TV-20241 20 in. TV/VCR Combo
Technika lcd15dvdid will not play dvd's, started a few days ago and when speaking to technician for help just kept flashing and wouldn't go back to tv. please help.
    Problem Solver:
  • 7 Answers
From experience this problem is happening all the time, to turn your tv back to digital you need to go into source and change it to dtv
With regards to the dvd not playing you could try a default reset which is,
Change it to dvd and eject any dvds in the unit
Press the setup or dvd setup button on your remote (it will be either or)
You should have options for tv type, tv system and default,
select default then it will show up with either yes or no, or it will show reset make sure yes or reset is selected press ok then turn off the tv at the wall so there is no power
then try a dvd, may work, may not
Posted on Sep 04, 2009
Technika lcd15dvdid 107
If the TV is alright, you should have only re-scan the channels [auto-scan] only once. By this time, all the available channels will be stored in its memory IC. No further scan should be done. If it do not store as described, be sure, the memory IC to your TV is faulty. Contact any service technician. If you wish to get some details, check the site linked here. Surf the site in "MOSAIC" view. It will make surf easy. Surf the site with patience.
Jan 27, 2014 | Televison & Video
Technika lcd15dvdid-107 has no signal
I have this same TV but have no sound at all?? i have picture but no sound, and its not on mute and the volume goes up and down on screen but no noise comes out. any clues, cheers
Jan 06, 2012 | Televison & Video
Purchased a Technika Model 19-220. 8 months ago never used the DVD recorder because we never had freeserve. Now we are connected to Freeserve the DVD will play DVD's but no accept blanks for recording...
Thanks for posting to Fixya and it is my pleasure to guide you.
"Will not accept blanks for recording it says No Disc."
from Technika manual: Start Quote
VCR/DVD Recorder; I have connected the TV to my VCR or DVD Recorder via SCART but it is not recording. In addition to connecting via SCART, you should connect the aerial cable from the wall socket to your VCR/DVD Recorder and another aerial cable from the VCR/DVD Recorder to the TV." Also; "Check the DVD is a region 2 disc - to change the region of the DVD player, refer to section 'Changing Regions'.
Note: USB record function is only avilable in Digital/Freeview TV/Radio mode. Due to copyright laws and illegal copying/recording it is not possible to record to/from any other input/output source.
DVD MENU: To access this menu, press [MENU] button on the remote control. TV System - Choose from the following options. NTSC; Normally used for discs from North America, Japan etc.
Auto; For both NTSC and PAL. This TV/DVD player is pre-set to play Region 2 DVDs.
Tip: This television contains one TV tuner, therefore it can only record the channel you are watching or record one channel while the television is in standby mode.
Tip: This TV/DVD player is pre-set to play Region 2 DVDs.
End Quote
You can not record to a DVD, according to their manual. That is why you get the no disc error. It does not have the play sector at the beginning of the DVD. You can record to USB Flash Drive however.
Built into this television is a USB record facility. This function is available in Digital/Freeview mode when used in conjunction with a compatible USB memory stick or USB Hard drive. The benefi ts of this are as follows:
• Pause live TV/Radio and then playback, fast forward and rewind (up to live TV)
• One button record, if you decide you want to record the current programme
• Easy programmable recording from the 7 day TV Guide
• Record TV/Radio and watch/listen back on your computer/laptop
Due to the nature of the product, it is necessary to use a high speed USB memory stick (as the TV reads from and writes to the memory stick at the same time, some memory sticks may not be suitable). You can purchase high speed memory sticks from some computer stores, alternatively, we have a selection of tested and compatible memory sticks available to purchase directly from the helpline/web site. These are available in 4GB, 8GB and 16GB. (Please check the web site/helpline for latest specifications and prices). End Quote
Good luck and please post back that you this has solved your problem and click thumbs up of your success or that I can be more helpful.
Jun 06, 2011 | Televison & Video
Technika LCD15DVDiD-108 no picture - sound ok
did anyone solve this please? i have the same problem and cant afford expensive repairs x
May 01, 2010 | Televison & Video
Problems with samsung DVD player
well are the dvds that play in the video are original or burns if the burns do not play proprerly maybe they were not formatted properly
Jul 28, 2008 | Samsung SGH-D500 Cellular Phone
Start up problems
I had the same problem few years ago with my 3950
I kept it on the charger and it just kept doing that, and finaly died totaly.
I send it to repairs and found out it was a motherboard / chipset problem and the motherboard would need to be replaced.
Mar 01, 2008 | HP iPAQ hx2410 Pocket PC
try pressing 9 7 3 5 when on the dvd source and no disk in.
this will get you to the region menu and can then scroll to the region option and then scroll to what region you want or to 0 for region free. then hit enter on the control scroll to exit and hit enter again
Jan 01, 2008 | Televison & Video
Technika LCD191d-107 LCD TV
You may want to check the solid state fuse on the power suppy or which can be called the inverter. The fuse will blow and finding a fuse can be hard.
C Dill
Aug 28, 2007 | Sampo PME-50X7 50 in. HD-Ready Plasma...
JVC TV-20241 20 in. TV/VCR Combo Logo
184 people viewed this question
Top JVC Televison & Video Experts
Jaime Hernandez
Are you a JVC Televison and Video Expert? Answer questions, earn points and help others
