Question about Koblenz Floor Polisher Model TP-2015
I need to down load a parts manual for a Koblenz Tp2015 floor machine.
  • 83 Answers
Ouch! My head hurts searching this one out but here you go.
Posted on Mar 30, 2009
Trouble keeping pads on my Koblenz floor polisher while stripping wax. Seems to glide at first then friction gets to strong for the pad . I tied more liquid but didn't seem to help. Thank you
You didn't strip enough wax with your mop, and now the old wax is plugging your floor polisher pad. Then the old wax starts to stick back to the floor. Flip the pad over and use the fresh side until it starts to stick too. Then soak the stripper pad in a mild soap solution and rinse it out thoroughly. After it dries, it should perform correctly. This is why you need several pads.
Dec 29, 2017 | Koblenz Tools & Hardware - Others
Washing machine is vibrating alot. machine is totally level but shakes the whole house
First off, the machine being perfectly level is really not that important (they are being used on boats). What is important is that all four legs need to be firmly on the floor (that can be adjusted). And the floor needs to be rigid. Put the machine in spin without any load. If it still shakes you could have bad bearings, or the spin basket could be broke. The back of the basket has three "arms" connected to a shaft which runs inside two bearings. One of those arms could be broke, in which case you probably can move the basket up and down manually. The basket has to be totally unmovable. Let me know if this helps.
Aug 09, 2011 | LG WM-2277HW Front Load Washer
My washer keeps stopping at the spin cycle and says UL for uneven load. The load is not uneven and evey load does this
UL is displayed when there is a balancing problem or when balancing sensor is defective.
The first thing to do is checking floor level and putting the machine at balance as explained in the user manual also try distributing the load
. If that does not work there are internal faults that may trigger the fault code. The balancing sensor and the electronic control board must be tested. The machine must be disassembled to locate the problem.
If you need parts see this tip explaining how to find parts and diagrams for most appliances: Where do I find parts and diagrams for my appliance?
Jul 24, 2011 | Whirlpool Cabrio WTW6600SBT Top Load...
I have a P- 820 Koblenz floor scrubber and the wire that controls the release of the water is broken. could this part be replaced? and if it can where could i get the part from? how soon could it be...
If you were to log on to the manufacturer's web site, I think you will be pleasantly surprised as usually one is able to download, by model number, Customer Instruction Manuals, list of Dealers for spare part supplies as required.
Just Google the manufacturer's name and follow the links. Make certain you are directed to the manufacturer's web site as some search engines direct you to other sites and they charge for the information that is normally free of charge.
I hope this helps.
Dec 19, 2010 | Microwave Ovens
Intermittent water on floor
Check the inlet valve hoses, even if inlet is at the back, the water may drip down and flow on the front part on the machine. There you also have the PUMP, a faulty pump may leak intermittently.
Here you get all diagrams and parts for your appliance.
Sep 25, 2009 | GE WJSR2070B Top Load Washer
It wont turn on
Most likely you have a bad stitch or a bad safety interlock switch. Take it to an apliance or electric motor shop to have them check it out.
Sep 15, 2009 | Koblenz Floor Polisher Model TP-2015
Koblenz P2600 manual
Here you go this link will pull it right up. I recommend printing it immediately or saving to your computer since I found it through a backdoor search. Seem they don't want everyone to have a manual.
Feb 23, 2009 | Koblenz Tools & Hardware - Others
Leaking water on the floor - Replacing Rubber boot
Type in your make and model and repair manual into the top right hand address bar of your pc. Scroll down the list and you will find the repair manual for your machine. I got full instructions to remove and replace the bearings on my hotpoint this way..
Best of luck
Jun 24, 2008 | Maytag Neptune MAH5500B Front Load Washer
Koblenz Floor Polisher Model TP-2015 Logo
242 people viewed this question
Top Koblenz Tools & Hardware - Others Experts
J.D. Browning
J.D. Browning
Are you a Koblenz Tool and Hardware - Other Expert? Answer questions, earn points and help others
