Question about Fat extraction holder Kitchen Hood
Which type of extrator fan
I need a extrator fan for both fresh air brought in and the stale air taken out fin my loft... what is the name for them? and how and where do i attach it to the beems and out to the the wall ?
  • 15,935 Answers
Thanks for your question!
I'm sorry that you haven't received an answer yet.
The response rate on FixYa FREE questions is usually over 80%, but sometimes questions go un-answered when:
1. the question is unclear, incomplete, or poorly worded...
2. the question is mis-categorized - so the correct experts aren't viewing it...
3. the question requires an answer for something that cannot be explained online adequately...
4. specific training, tools, or equipment are required to avoid injury or death...
5. the Experts that are online simply don't have the resources to answer your question fully...
Please feel free to re-work your question if you feel one of these may be the reason.
Of course you are not required - but converting your question to a PAID one usually increases the reply rate as well.
Normal rates for FixYa are...
$ 9.99 answer for one question.
$12.99 Live Real-Time online chat or premium e-mail support.
$29.99 Live Real Time phone support
Sometimes FixYa will run specials for unlimited questions via monthly subscription or reduced rates for limited periods.
Consider the savings that can be had when an informed Expert can save you a $100 service call, or a $350 trip to the car dealership.
Your problem solved - guaranteed! Or your money back!!
If you don't want to pay - feel free to re-submit your question so it returns back to the top of the work queue if you still need help.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for helping with your FREE question
Posted on Sep 05, 2010
Directions for assembling an IKEA loft bed - can't fins the name, but the ID n0 is 13672
if you can identify yours
this is there loft bed range
contact nearest ikea they can get you a copy of instructions
Loft Beds Frames IKEA
Loft beds bunk beds
Oct 24, 2016 | Furniture
Cleaning Air Conditioner Condenser Coil with Pictures
The most important Air Conditioning maintenance that needs to be done every year is the cleaning of the condenser coil. Doing the job of cleaning the A/C coil is the best way to make sure that your air conditioning system is working efficiently and giving you the best performance possible.
The tools needed to do the air conditioner condenser coil cleaning will be:
Garden hose with nozzle
Garden pump sprayer
Condenser coil cleaner (can be purchased at HVAC Supply houses, or many hardware type stores)
Hand tools needed to remove condenser fan
To do the job correctly you will need to first turn off the power to the unit and remove the condenser fan.
Once the condenser fan is removed then, you should wet down the condenser fins with a garden hose. Use nozzle that will give you a high volume spray but not with high pressure. Too much pressure will bend the fragile fins and cause them to shut off the ability of the air to flow through them, this is want you want to avoid. You want it to be as easy as possible for the air to get through the fins, for the best possible heat exchange.
After wetting the fins, you then will need to spray the fins inside and out with a foaming coil cleaner. Make sure to wear eye protection and hand protection. If you have sensitive skin, you may also want to wear long sleeves to protect exposed skin. I buy it in a concentrated formula then dilute it with water to the proper working formula. You may need to go over the fins a couple of times with the coil cleaner to get it worked into the fins. Allow the coil cleaner time to work the dirt loose and boil it out of the fins.
After about fifteen minutes start to rinse the coils with fresh water. This will take a long time and lots of water to fully rinse the coil cleaner from the fins. It also is very important that you get everything rinsed fully. Failure to do this will result in excessive dirt accumulation and also can cause corrosion. Make sure that the water is running clear and that all bubbles are gone before stopping your rinse.
Then reassemble the condenser fan, turn on the power, and check the operation of the unit. It is okay to run the unit immediately after washing it. The water will not hurt the unit.
You now will have an Air Conditioning unit that will give you the best possible performance!
on May 15, 2011 | Heating & Cooling
How can i fix it when kenmore type JD21, model 970-432603 refrigerator not cold but freezer is cold
Ice build up on the coils can cause this. If there is ice then you need to check the defrost timer first to see if it works. Then check the defrost coil, then the fan.
Jan 23, 2015 | Kenmore Refrigerators
Laptop emachines e725 overheating
Could be simply a blocked CPU vent, clear with a can of compressed air. Make sure Fan is spinning when you power up the PC.
When the fan is spinning place the back of your hand by the Vent you should feel hot air. If you feel cold air the CPU heatsink may need to be reseated with fresh thermal paste. Worst scenario is the Heatsing has Failed and needs replacing.
If the Fan is not spinning it may have failed or a lump of fluff has jammed it
Mar 01, 2013 | Acer eMachines E7254520 Notebook PC
The laptop must be taken apart and cleaned, remove fan and heatsink get a can of compressed air attach straw, now give a good few blasts to the heatsink fins to remove the dirt including fan, Next get rubbing alcohol and clean the old thermal paste from the processor and heatsink, when finished apply fresh thermal compound to both items and assemble.
Jul 03, 2012 | HP Pavilion dv6000z Notebook
Need to know if the vent should be open or closed or fresh air setting while running ?
personal choice, open allows unit to exahust stale air, closed gives better efficiancy (minimal)
Jul 22, 2011 | Frigidaire FAC127S1A Air Conditioner
2.5 ton goodman coming on but the fan isnt blowing air throught the ducts smoke
>check for the content of refrigerant from the accu-chiller maybe the refrigerant pipe has a leak that is why the condensation of the basic refrigeration cycle does not takes place so in return high temperature is producing on the fan coil unit to which the air duct to supply fresh air to the room is discharging a smoke instead of a fresh air.
>check if the accu-chiller has an air restriction from its condenser fins because if it has an air restrictions the hot air from this unit cycling around cannot discharge to the atmosphere that is why the FCU to which the airducto to supply fresh air is connected will be producing a smoke.
>check for the FCU fan motor overloading to which the airduct to supply fresh air was connected that is why it is producing a smoke.
Jun 18, 2011 | Goodman Heating & Cooling
My nv7802 overheats and shuts off,fan is running but the heat sink gets very hot
The fan may be running too slow (faulty bearing) or the fan and heat sink assembly may be clogged with dust.
Check the CPU fan to see if it spinsfreely, if not replace the fan. If the fan and heat sink is clogged withdust the remove the dust and make sure the vents are clear and dust free. Use acan of compressed air to do this.
Dec 30, 2010 | Gateway NV7802U Notebook
My HP pavilion dv9000 keeps crashing when I am on the internet and if I type too fast the curser stops and just keeps flashing then the laptop just crashes. I thought my laptop was getting too hot so I...
Your Laptop Is Overheating... First thing you need to do is go to the HP website/Drivers and Support... and Download/Install The Newest Available BIOS download.. You need this because in it is a Fan Controller Fix.. It Will Speed Up The Fan..
Next .. You Need To Clean The Fan/Heatsink Assembly..
This means complete disassembly of all parts down to the motherboard, The Fans Blades Need To Be Cleaned and the Heatsink Cooling Fins Need To Be Cleaned and free of dust/debris....
You can not simply use a can of compressed air and blow it into the general area of the fan from the underside of the case... You wil make things worse...
If same symptoms still occur, You will need a Video Chip/GPU Reflow of the motherboard.
Nov 17, 2009 | HP Pavilion dv9000z Notebook
Foul odor from back area of fridge/Kenmore bottom freezer
I had the same problem, but just fixed it. I have a maytag bottom freezer and when the fan blower comes on, there was a foul/stale smell that permeated the kitchen. There is no drip pan that I could remove to clean.
I just removed four screws from the back cover of the fan blower area, reached in with a small cup of organic odor remover and poured it into the drip pan just under the fan blower.
Any odor remover would work. probably vinegar or enzyme odor remover would work, too.
I now have fresh smell when the fan blower comes on.
Jul 03, 2009 | Kenmore 50522 / 50524 Side by Side...
Fat extraction holder Kitchen Hood Logo
79 people viewed this question
Top Fat Kitchen Ranges Experts
Dan Webster
Dan Webster
Paul Carew
Are you a Fat Kitchen Range Expert? Answer questions, earn points and help others
