Question about Dell Dimension E521 PC Desktop
My cd drive does not open some of my disc
Pls.help me solve the problem
  • RescueTechLA
    RescueTechLA May 11, 2010
    Does the problem occur with just cd's or dvd's too?
Open the driver outside youe pc ,untie the 4scrowes for its cover, by your plower air kindley suppose its lens to air for 50 seconds it will be cleaned dont use any liquid or somthing to deal directley with lens it will damage if you tuch it or drop liquid on it
Posted on Feb 26, 2009
I am having trouble getting my LG multi drive to boot an OS. Im trying to load XP but it hangs up and tries to read the XP disc over and over. I went in BIOS and selected the DVD drive to boot up FIRST and...
pls note that these kind of problems are usually caused when either the xp cd disc is bad or the DVD/CD drive is weak. so pls kindly try with another cd drive and along side another bootable windows xp.
and all will bwell
Dec 26, 2010 | Intel DH55TC Motherboard
No disc inserted problem
i have installed crashday and also copied and pasted the exe file inthe place where the game has installed but still its asking to insert the cd or wrong disk inserted. please help me.
Apr 23, 2010 | Atari Crashday
I have dell D630 i like to install webcam pls help me how i can install webcam driver
Put the drive disc that comes with your webcam in your computer and run it from there. Most driver cd has auto run and show load when insert the disc. If not, go to MyComputer and double click on the cd drive to open it. Just follow the on screen instructions to install it. Hope this help.
Apr 22, 2010 | Dell Latitude D630 PC Notebook
How to insert a cd in a laptop I have never operated a laptop befoe.Plz help .
go to my computer then you can see your disc drive there,
right click it then click eject, then the disc tray will pop out then put your disc and push the tray,
pls rate if this thing helps
Jan 25, 2010 | Computers & Internet
Drives d and e wont even play a cd but the contents of disc can b
HI, WHAT IS THE CONTENT OF THE CD. IS THIS A MUSIC CD? IF IT IS , ALL YOU NEED IS A SOFTWARE LIKE WINDOW PLAYER OR ITUNE TO PLAY THE MUSIC. YOUR WINDOW PLAYER MAY NOT BE SET UP AS AN AUTOMATIC TO PLAY YOUR CD. OR YOU LOST OR THE SOUND DRIVER IS DE ACTIVATED. YOU CAN CHECK THE SOUND VOLUME FIRST, OR CLICK START, CONTROL PANEL, CLICK THE SOUND DEVICE AND CLICK THE HARDWARE TAB AND CLICK THE WHAT KIND OF SOUND DEVICE RIGHT CLICK AND THE PROPERTY WILL APPEAR CLICK THE UP DATE DRIVER AND FOLLOW THE COMPUTER INSTRUCTION. HOPE THIS INFO WILL HELP YOU SOLVE YOUR D & E DRIVE PROBLEM.
HH
Aug 16, 2009 | Asrock K8Upgrade-VM800 Motherboard
I have a LG DV8621 DVD player and no matter what disc I put in it comes as disc error, appreciate ur help please. Jase
Initially try cleaning the lens using a CD ROM disc cleaner similar to those used in PC's CD ROM drives. They are normally and readily available from most computer shoppes. If the cleaning would not be corrective, pls try to manually clean by opening and use cotton buds to clean the laser/optics. it may also be worth your while to spray the insides with a can of compressed air to remove dust. Re-application of lubricant to the mechanical portion would also help.
If none of the above solves the problem, then chances are that the laser wiould require replacment. Considering the cost of repair and downtime, it might be more economical to purchase a new unit.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FixYa.
Jul 21, 2008 | LG Televison & Video
No Disc
Initially, try cleaning the lens using a CD ROM disc cleaner similar to those used in PC's CD ROM drives. They are normally and readily available from most computer shoppes. If the cleaning would not be corrective, pls try to manually clean by opening and use cotton buds to clean the laser/optics. it may also be worth your while to spray the insides with a can of compressed air to remove dust. Re-application of lubricant to the mechanical portion would also help.
Jul 21, 2008 | Pioneer DV-270-S DVD Player
No datas is showing in dc rom
plz clear data is available in cd , cd is proper write or not
plz sure
Dec 19, 2007 | Microsoft Windows XP Professional for PC
CD CHANGER
This only happens to me with burnt cd's.
Nov 04, 2007 | Panasonic SCAK410 5-Disc CD Changer
Dell Dimension E521 PC Desktop Logo
Alun Cox
