Question about Sceptre X9G-NagaIV 19" LCD Monitor
Monitor stays black until boot up to Desktop
Eversince I've had my Sceptre Naga 19" LCD monitor, it's always booted up with a black screen until it goes to Desktop and everything shows up fine. Does anyone else have this problem and/or know how to fix this so I can you view the Bios startup screen?
  • 203 Answers
You use a graphics card as your main output?
and you have onboard graphics output too that you dont use?
if so then you will have to plug your monitor lead into the onboard output socket to see bios. i think you need to go into bios and change which device starts from boot.
it sounds like you have the onboard graphics as your boot device and windows using the graphics card.
Posted on Feb 26, 2009
I have a Sceptre X7G-Naga VI 17 inch LCD Monitor When I turn the monitor on and boot the computer I get the red light for a sec then the blue light comes on I will also see windows booting up but the...
try with restarting computer & press F8 at the same time. u will see a menu where choose "safe mode" & start the computer. in safe mode see the display properties, set the refresh rate & resolution according to monitors specifications, apply & restart again. if that does not work, replace the main board of lcd monitor.
Aug 25, 2011 | Sceptre 17" LCD Monitor
Aug 25, 2011 | Sceptre X20G-Naga II 20.1" Flat Panel LCD...
I have this monitor hooked to my PC ATI 7500 graphics card with a DVI cable. When the PC initially boots up, the monitor display is blank - it does not display the boot-up messages until the MS Windows...
This is normal. Your monitor has a VGA hook in for regular definition. What it is doing, the monitor always by default looks for the VGA hook first. On my desktop it does the same thing until it finds a signal on the DVI.
Dec 29, 2009 | Samsung SyncMaster 940MW 19" LCD Monitor
At start-up, Sceptre X7 monitor flashes on, then goes black. Must turn computer on and off numerous time before monitor will stay on. How can this be fixed?
Hi Friend,
You need to check your display setting in your computer..i mean to say..you need to click on desktop then properties then display then screen saver then change the time.....
Dec 20, 2009 | Sceptre X7G-Naga 17" LCD Monitor
NEED DRIVERS FOR THIS SCEPTREX9W MONITOR
http://www.sceptre.com/Support/index.htm
click on the link near the top right of the page or try this one.
ftp://ftp.sceptre.com/pub/monlcd/sceptre.zip
Unzip the file and then go to control panel - system- hardware- device manager - monitor open that then right click and select update driver and then brose to where you saved the drivers. Find your driver and you should be done. You may have to reboot but that should do it.
Nov 04, 2009 | Sceptre X9WG-Naga V / 19" / 8ms / 700:1 /...
I have a sceptre x9g-naga III
Not an expert, but from what Ive read, this is a cfl inverter issue. I had the same problem on my Sceptre. Good luck finding parts. My solution: get another monitor.
Feb 27, 2009 | Sceptre X9G-NagaIV 19" LCD Monitor
X20G-Naga III screen goes blank after 1-2 secs
most common lcd monitor break down, check all electrolytic capacitors for leakage and loose board solder specially on the ccfl inverter section.
May 31, 2008 | Sceptre X20g-Naga III 20.1" LCD Monitor
Sceptre naga x9 no osd
bad display board replace if you can find one on ebay
May 10, 2008 | Sceptre X9G-NagaIV 19" LCD Monitor
Sceptre X9 monitor problem
hy,
usually the capacitors on the inverter board for the backgroundlight
should be replaced.
good luck
hans
Nov 17, 2007 | Sceptre computers5: X9 S-Naga II 19" SXGA...
Sceptre X9G-NagaIV 19" LCD Monitor Logo
194 people viewed this question
Top Sceptre Computers & Internet Experts
Ricky Ostrom
Ricky Ostrom
Are you a Sceptre Computer and Internet Expert? Answer questions, earn points and help others
