Question about Acer Aspire 5050-3371 Notebook
Have a Acer Aspire 5050-3371 laptop. When turned on it says operating system not found. I made sure IDE was visible in bios and first in boot order. Tried to install fresh install of WINXP.(came with vista).Says drive not detected but is showing in bios.
  • mike281 Feb 26, 2009
    Ther is no option to change mode in bios.
  • DLMDRIVER25 Apr 26, 2009
    I have this Acer Laptop, and when I plug it in and turn it on, it says.
    For Realtrek RTL8139(X)/8130/810X PCI Fast Ethernet Controller v2.17 (051202)
    PXE-E61: Media Test Failure, check cable
    PXE-M0F: Exiting PXE Rom.
    Operating system not found.
    Is there a fix for this? And if this is what should I do?
    Thanks for your time.
  • 4 Answers
Go to bios
and change sata mode to ide
Posted on Feb 26, 2009
Forget password acer aspire 3610
Acer laptops are equipped with a BIOS utility. The BIOS (which stands for "Basic Input Output System") acts as an interface between the hardware and software installed on the computer. On some computers, a BIOS password may be required in order to boot the computer and make changes to the BIOS settings. If you are unable to access the BIOS settings and do not know how to reset the BIOS password, you might be tempted to send the computer back to the manufacturer for repair. Fortunately, that's not necessary as there is a simple way to do this on your own.
Go to "Start," then perform a search for "Command Prompt." The Windows Start button is located in the lower-left corner of your computer screen. Double-click on "Command Prompt" to open the application. You will need to use MS-DOS commands to reset the BIOS password. Type the following commands one by one in the order shown: debug o 70 2E o 71 FF quit Make sure that you are typing the letter "o" and not a zero at the beginning of the second and third commands. Reboot your computer by clicking "Start," "Shutdown," and then "Restart." The BIOS password will now be reset to default. or To get into your computer's Basic Input-Output System (BIOS), your computer must be on, but your operating system cannot be running. If the Microsoft Windows operating system has even started to load, you will not be able to access your BIOS. This is why getting into the BIOS on an Acer Aspire netbook computer must be done specifically during your computer's initial boot-up sequence, which happens immediately after pressing the power button on the device.
Turn on your Acer Aspire. Press and hold the "Ctrl" key. Press and hold the "Alt" key. Press and hold the "Esc" key. This key combination will open the BIOS on your Acer Aspire.
Feb 03, 2013 | Acer Aspire 3610 Notebook
How to reboot to default main hardrive
Restart your computer during the boot process you will a certain key to press to enter set up usually the Delete or F2 key this will vary depending on your operating system and computer Press and hold that key during the boot up process to enter BIOS using the arrow keys navigate to Advanced Bios features press enter you will see the boot order Change the first boot device to your hard drive.
The BIOS is AMI. Under ADVANCED SETUP:
The options listed for 1st,2nd ,3rd Boot device include:
IDE-0 means Pri master ?
IDE-1 means Pri slave ?
IDE-2 means Sec master ?
IDE-3 means Sec slave ? If you are unsure or have made mistakes you can load optimised or failsafe defaults this will automatically set the boot order Hope this helps.
Jan 11, 2013 | Acer Aspire M3400 PC Desktop
My acer aspire 5536 turns on and starts to boot up but error comes up operating system not found. any ideas. tried f8 laptop did not come with boot disc
Oh dear! You need a boot disk to get to your stuff or another pc to interrigate the faulty hard drive and get your data off.
I would say that you have a hard drive error to contend with.
Dec 22, 2010 | Acer Aspire 5500 5570-2609 Laptop
Hi, When I turn on my Laptop - Acer Aspire 5536, the following writing appears; Broadcom UNDI PXE-2.1 v11 .4.1 Copyright (C) 2000-2008 Broadcom Corporation Copyright (C) 1997-2000 Intel...
usually, this message means that when your computer is booting it is trying get the operating system files from a network location (shared folder)
what you need to do is to make sure your BIOS is not set to boot from network.
1. when the computer starts, there is a message like "to enter BIOS press Esc" or any other key like F2 or F10
2. in the BIOs settings, make sure the order of the boot is: DVD/CD then hard disk. make sure there is no Network booting in the list
Oct 26, 2010 | Acer Aspire 3690-2196 Notebook
It is an acer aspire 3680 laptop. when i power it on it says the acer screen and then it goes to a command prompt and say that the operating system is not found. please help me.
if youre sure you have an OS first ,,then go into bios settings(F2 whilst booting) and see if correct boot sequence is enabled,navigate with"tab"keys/arrow keys.save with "enter "key
save and exit once you are familiar with these pages
Sep 10, 2010 | Acer Aspire 3680 Laptop
Media Test Failure, Hardware Problem?
reset your BIOS settings to default, to do this go into BIOS screen and choose return to default settings.
Jun 17, 2009 | Acer Aspire 3680 Laptop
hi
Why cannot you change the boot order? you use the page up and page down keys
Mar 25, 2009 | Acer Aspire 5100 Notebook
Acer TravelMate 4200 Laptop
there are two posibility,
your hdd don't have operating system
or your hdd isnot detected.
check in bios, check if your hdd is there.
Jul 31, 2008 | Acer Aspire 5500 5570-2609 Laptop
Problem in acer aspire 5630
- is the BIOS set to boot from the hard drive ?
- have u changed any drive setting in BIOS (sata mode, pata mode ...)
- try to boot with a linux live cd, or with the vista dvd and see if they can see the drive ... if thay can, than most probably a reinstall of the OS would fix the problem, if not , check the BIOS settings, also make sure that the drive is properly fixed in it;s place, if posible test it on another laptop to be sure if it;s causing the probems or not ...
Jun 28, 2008 | Acer Aspire 5600 Series 5630-6951 Laptop
Acer Aspire 5050-3371 Notebook Logo
288 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Alun Cox
