Question about Remington 16" Electric Chain Saw
I need a new 16" chain saw tensioner for a remington 3.5 hp 16"/41cm
  • Jim Giesen May 11, 2010
    Is the tensioner damaged or it the chain stretched?
5 Suggested Answers
  • 10865 Answers
SOURCE: replancement bar for 16 inch remington chain saw
The bar is the piece of metal that the chain goes around. This link has lots of info on your saw http://www.remingtonchainsaw.com/chainsaw.html
Posted on Apr 01, 2009
firesnake09
  • 2923 Answers
SOURCE: Owners Manual for a Remington 2.5 HP 16 '' Chain saw, Model EL-7
Kindly check this link for manual. Please select the correct model:
http://lawnandgarden.owneriq.net/manuals/mfg/remington/remington_chainsaw_product_list.html
Posted on Apr 18, 2009
FixYaSteve
  • 57 Answers
SOURCE: How do I get a replacement chain for a remington
Master Distributors (masterparts.net) sells chains for Remington electric chainsaws. The page you probably want is here. I'm pretty sure you need a 16SC which runs about $18. If you can't find what you're looking for there, you can call them at 888-917-2244.
If this answer helped, please vote. Thanks.
Posted on Jun 14, 2010
hunter19_46m
  • 7482 Answers
SOURCE: need to order new 16" chain for my remington chain
Hi mariam608...
Go to HomeDepot and you can buy one off the shelf.
You can also order it online at:
http://www.amazon.com/Oregon-S56-Craftsman-Homelite-Remington/dp/B00004RA82
It will be made by Oregon...P/N S56 low profile...
It will fit your Remington Electric and other chainsaws.
Please take time to rate me
Posted on Sep 07, 2011
Need to order new 16" chain for my remington chain
Hi mariam608...
Sep 07, 2011 | Remington 16" Electric Chain Saw
What kind of oil does a Remington 3.25 (Peak hp) 16"/40, 6 cm Electric chain saw take
You need to use bar & chain oil. It's thicker and stickier that regular oil so it will stay on the bar and chain and not run out of the saw when you are done using it.
Jan 21, 2011 | Remington 16" Electric Chain Saw Assembled...
I have an Remington 3.25 (Peak Hp) 16"/40, 6 cm electric chain saw, And I have just a few questions 1.) Does it take oil/gas or just oil and if so what kind. 2.) How would I tighten the chain, its...
It uses oil only to lubricate the chain. The type of oil in not critical although special chain saw oil is available. If you use anything but chain saw blade oil, make sure that it is a light oil, both in viscosity and in colour because it is a total loss system and dark or dirty oil can become very messy. The chain adjustment is on the body at the end of the blade, it actually moves the blade in or out to set the chain tension. The chain should be tensioned that when it is pulled at the bottom, the guides of the chain should not quite come out of the slot in the blade. If the chain is too tight it overheats the blade and stretches the chain.
How do I get a replacement chain for a remington electric saw model 3.0 16 in/41cm ?
Jun 13, 2010 | Remington Electric Pole Saw
Does a Remington 3.0 HP 300 with #114732-01s have a chain tension and screw. I do not have the manual and can not see where a chain tension screw would go.
The part number is Remington's and cannot be interpreted. What is the saw model number (reply below please)?
See the 2 holes near the heel of the bar (each side of the slot)? That is where the adjuster fits. I do not recall any Remington with an "Intenz" type bar (tensioner embedded in the bar).
http://www.fixya.com/support/r4146814-chainsaw_chain_installation
If you have more questions or need additional help please reply below and I will get back to you. Thank you for using FixYa and Good Luck. HTH
Lou
Apr 06, 2010 | Remington Electric Chain Saw
Broken safty guard---need to purchase a new one model EL-7 Ser # 154445 Rimington 16 2.5 HP
Check out master parts, they have remington chainsaw parts, you'll need the model number of your unit ( usually 8 digits long). 800.446.1446 or www.masterparts.net. I hope this helps you!
Feb 25, 2010 | Remington 16" Electric Chain Saw
I need repair manual for chain saw model
Parts and manuals are listed Here:
I didn't see the model you listed, perhaps a typo or an obsolete model. If all else fails try to contact them.
Lou
Sep 05, 2009 | Garden
How do you adjust chain tension? I have the 16" Remington electric chain saw, and the chain will not stay tight; it slips off the rear sprocket as soon as I try to use it. I don't feel everything is...
Here is a link to instructions for EL-8 series saws ... http://www.desatech.com/pdf/115499-01_EL8_Series_Chain_Saw_Tension_Adjustment.pdf. For series LNT-2, LNT-3,EL-1, and EL-7 according to the manufacturer... "WARNING: The cutting edges on the chain are sharp. Protective gloves should be used when touching the chain. Unplug the chain saw from the power supply. Allow chain to cool. Loosen the guide bar nuts until they are finger tight. Ensure the adjusting block is in the adjustment hole in the guide bar. Turn the chain tensioning screw clockwise to increase tension. Turn the chain tensioning screw counterclockwise to decrease tension. Check for proper chain adjustment by pulling down on the chain at the bottom center of the guide bar. You should see no more than a ⅛ inch gap between the chain cutting links and the guide bar. The guide (or drive) links should not come out of the guide bar grooves. The chain should rotate freely around the guide bar. If it does not, chain tension should be decreased. When the chain is properly adjusted, tighten the guide bar nuts securely." On the M series if your chain keeps slipping off your sprocket... The Sprocket cover tab (located on the round part of the sprocket cover) isn’t inserted into the saw body tab slot. I hope this helps you!
Jul 01, 2009 | Remington 16" Electric Chain Saw
Oil
While Bar Chain oil will probably work, the owners manual (sitting in front of me) on page 9 says to "use SAE #30 motor oil". This is the owners manual for Models: M12510US, M15012US, M15014US, M15014AS, M30016US, M30016AS, M30016AW, M35016UW, M35016AW. Remington Electric Chain Saw
May 25, 2009 | Remington Electric Chain Saw
Apr 18, 2009 | Remington Garden
Remington 16" Electric Chain Saw Logo
174 people viewed this question
Top Remington Garden Experts
Phil Walker
Phil Walker
roeb
Are you a Remington Garden Expert? Answer questions, earn points and help others
