Question about Hitachi 60DX10B 60" Rear Projection Television
The screen does not turn on. When i press the power button the TV just chirps
Try to unplug it and try it again
Posted on Feb 26, 2009
How do I reset anti theft in my 2002 ford f150
tis a process so here goes..... Central Security Module (CSM) enable/disable mode allows autolock feature to be turned on or off. To enter enable/disable mode, close all doors. Ensure ignition switch is in LOCK position. Perform the following steps within 30 seconds:
Turn ignition switch from LOCK to RUN position.
Press power door lock switch UNLOCK button 3 times.
Turn ignition switch from RUN to OFF position.
CSM module should chirp horn indicating CSM module is in enable/disable mode and ready to accept program changes.
Press power door lock switch UNLOCK button once to command CSM module to toggle autolock feature on or off. Press power door lock switch LOCK button once to enable/disable autolock feature. CSM module will chirp one time to indicate autolock has been disabled.
CSM module will chirp once, followed by a longer chirp to indicate autolock feature has been enabled. Press power door lock switch UNLOCK button once, then turn ignition switch to OFF position to exit enable/disable mode. CSM module should chirp once to verify a feature change. Best to you.
Dec 31, 2017 | Ford Cars & Trucks
AUDIOVOX CAR APS787N ADVANCED REMOTE START DOES NOT FUNCTION EVEN AFTER EVERYTHING IS CONNECTED PROPERLY.
If everthing is properly connected and the system does function,you may need to program the remotes. But first,let's check a couple of things. Turn the ignition on and press and release the push button LED three times and check for a response.The alarm should chirp one time. If the alarm chirps one time, press and release the lock button on the remote. If the alarm responds with a long chirp, press and release the push button LED one time,should hear two chirps; press and release the unlock button on the remote. The alarm should respond with a long chirp. Press and release the push button LED one time, you should hear three chirps, press and release the green button. You should hear a long chirp from the alarm. Press and release the push button LED one time, you should hear four chirps from the alarm; press and release the (1)button on the remote. continue the process for button(2).Now, if you do not hear the one chirp in the beginning, the system is not responding. Check your power and ground connections. If the system does chirp but, no response from the remote, check your antenna cable for proper connection at the module and the antenna. If the connections are fine, check the remote. Also,it is possible that there is major RF interference where you are located. If all of the above check out, try moving the vehicle to a different location and test.
Oct 13, 2010 | APS787N Advanced Remote StartKeyless Entry...
5BCR07P PROGRAMMING INSTRUCTIONS
Ignition on, press and release programming switch three times,you will hear one chirp ( channel1), press lock button on remote, press and release switch 1 time ( two chirps, channel 2) press unlock button, press and release switch 1 time (3 chirps), press green remote start button, press and release switch 1 time ( 4 chirps),press option button. Turn ignition off, test.
After pressing the corresponding buttons on the remote programming sequence above ,you should hear confirming chirps from the alarm.
Sep 29, 2010 | 5BCR07P Remote Replacement Transmitter for...
TV makes chirping noise, won't turn on!
That usually means a problem in the start up or deflection circuits. Diode, Horizontal ouput or driver transformer. What Chassis is this set, and I will be ableto give you some better information. Rca , GE and phillips need to be diagnosedwith the chassis number. Let me know the chassis.
Jan 25, 2008 | Televison & Video
When tv turned screen is blank and chirping sound comes from back
A chirping sound usually means that one of the secondary supplies has shorted, most likely the horizontal output transistor. The power supply "chirps", which is the sound it makes when it protects itself from drawing too much current. The set should be serviced by someone with experience in Philips projection TV'.
Jun 21, 2007 | Philips 43PP9202 43" Rear Projection...
My Screen doesn't work
You can not find where the noise is coming but a service technician will know where to look and what to check.Get an estimate.
Sep 01, 2006 | Sony KV-27FS12 27" TV
Chirping noise and flashing front power light.
Theres a short somewhere in the set. Most likly the HOT is shorted or the vertical IC has caused this in the past. In one case I had shorted convergence IC cause this symptom.. This set is solid state and there are no user serviceable parts inside so please call a trained tech to assist you with this problem Good Luck
Aug 17, 2006 | Hitachi FDX Series 43FDX10B 43" Rear...
Hitachi 60DX10B 60" Rear Projection Television Logo
Top Hitachi Televison & Video Experts
Jaime Hernandez
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
