Question about Canon DR-1210C Scanner
Using job registration tool for a Canon Dr-1210C on Vista 64
I tried setting up the job registration tool but none of the buttons on the printer start anything. I'm running Vista Business 64 which i just received the new computer. Before I was running XP.
  • Anonymous Mar 28, 2009
    the scanner doesn't work at all under vista 64
5 Suggested Answers
SOURCE: how locate and transfer job registration tool data for new installation
There are 2 methods:
1) On the existing PC, start the Job registration tool, click the "Administrators" button (on the bottom of the dialog), then click the "Backup" button in the dialog that appears. This will save a registry file that you can then transfer to the new PC.
2) Use regedit to browse to the
HKEY_CURRENT_USER\SOFTWARE\Canon Electronics Inc.\DR-1210C-JobTool
branch. Save this branch to a file, then transfer it to the new PC.
Cheers!
Posted on Aug 31, 2008
mohanchennai
  • 490 Answers
SOURCE: CANON DR 1210C Scanner Driver Mac
Try http://software.canon-europe.com/products/0010336.asp for mac drivers
S. Mohan
Posted on Jun 13, 2009
  • 3 Answers
SOURCE: I have a canon dr-1210c scanner. The menu display
The lamp is getting too hot. Turn off your scanner when not in use.
Posted on Aug 28, 2009
SOURCE: "warming up" all the time
Be careful fixing this problem with the firmware update version 0087 dated May 28, 2009. We downloade this update and installed it into the scanner. That fixes this issue but causes an intermittent issue where scanning stops and a "Lamp was over (-4430)" error message is printed. My workaround for this latest problem is to tell the user to turn off the printer, exit the Capture Perfect software, then run a script I wrote for him which stops and restarts the XP image capture service, then turn it back on and continue scanning. Canon tech support says it might be a USB issue but backed off that position when I mentioned it is intermittent, occurring on one out of 20 to 30 stacks of paper.
Posted on Jan 27, 2010
  • 196 Answers
SOURCE: I have the canon dr-1210c scanner. Software is
check first to see if ur scanner is compatible with ur windows operating system if is the next thing i would suggest in uninstalling the software the reinstalling the software.
Posted on Jul 28, 2010
Canon DR-1210C scanner does not work with Capture Perfect software
you can download and Install Twain driver for this model and you can scan from Any Image Editor like photoshop and Acrobat PDF editor
download link http://www3.canon-asia.com/downloads/drivers/dr/DR1210C/DR-1210C%20Driver1.1.zip
Feb 06, 2013 | Canon Office Equipment & Supplies
My canon dr 1210c scanner cd is failed
pick your operating system and language and download software from web
Rob
Please. Rate.
Mar 03, 2011 | Canon DR-1210C USB
Need step by step instructions on how to download driver for Canon DR-1210c scanner for Vista.
http://www.usa.canon.com/cusa/support/office/imageformula_scanners/imageformula_dr_1210c/imageformula_dr_1210c_universal_color_scanner?selectedName=DriversAndSoftware
Hi, heres the link.
Thanks
Adam
please leave me some feedback
Feb 18, 2011 | Canon DR-1210C Scanner
ERROR MESSAGE lamp was over Canon DR-1210C driver
lamp was over Canon DR-1210C driver verion 1.01.10601.23003(-4430)
Sep 29, 2010 | Canon DR-1210C Scanner
Jul 28, 2010 | Canon DR-1210C Scanner
I have a canon dr-1210c scanner. The menu display "lamp error." How can I fix it?
Jul 15, 2009 | Canon DR-1210C Scanner
If you go to the Canon Support site for this scanner they have a firmware upgrade that seems to specifically address this problem:
http://www.usa.canon.com/opd/controller?act=OPDSoftwareAct&fcategoryid=2204&modelid=13057
May 02, 2009 | Canon DR-1210C Scanner
Black line on scanned document
Please clean the glass with Isopropyl alcohol. Dont use solvents.
S. Mohan
Mar 27, 2009 | Canon DR-1210C Scanner
How locate and transfer job registration tool data for new installation
Cheers!
May 10, 2008 | Canon DR-1210C Scanner
442 people viewed this question
old marine
old marine
Corne Viljoen
