Question about MSI Wireless-G RG54G3 Router
How can you set up a network of 4 computers with a RG54G3 router?
  • beta-j May 11, 2010
    should be quite simple....just connect them directly to the router, or connect over WiFi.
    are you having any specific problems in doing this?
*** configurez router ,ca nu am cd la el nici manual rg54g3 msi
Posted on Aug 27, 2009
    Master:
    Sergeant:
  • 226 Answers
Wireless or wired either way just either plug them in or connect to the wireless network
Posted on Jul 20, 2009
How do i find the wap2 ket or network key
Your wireless network must be secured
You will need to check the wireless settings of the router.
Is there any computer online using the router.
check the IP address on that computer.
If yes then you can open the router set up page on that computer.
router set up page is the page where you can check all the router settings.
Click Here for more information about the routers and network
May 22, 2010 | MSI Wireless-G RG54G3 Router
Remote access working
DOWNLOAD TEAM VIEWER INSTALL IT ON BOTH PC'S
Apr 17, 2010 | MSI Wireless-G RG54G3 Router
Need to change password
Jan 15, 2010 | MSI Wireless-G RG54G3 Router
I have connected MSI RG54G3 to a caple and it's not give me ip and internet access
To connect to your wireless router, it needs the router’s wireless settings configured and also needs the wireless cards in all the laptops and or computers to be configured with the router’s wireless settings. Then the laptops and desktop computers can communicate with your wireless router.
To set-up and secure the wireless router from unauthorized access, follow these steps: -
1. Connect the wireless router to your computer with a LAN cable.
2. Start your browser and enter the router's configuration URL IP address.
3. Enter the router setup, login and password
4. Change the admin password
5. Go to the wireless settings and change the default SSID and turn off SSID broadcast.
6. Setup encryption key the strongest is WPA2 (if not then WPA).
7. For further security measures - turn on MAC address filtering and enter the MAC address of the wireless cards on the computer/s you want to connect to this wireless router.
8. Record the settings you have made and keep it in a safe place and Save the settings.
9. Configure the wireless cards on the computer/s with the SSID and encryption settings of the router.
10. Remove the LAN cable between the router and the computer then the computers should be able to connect to the router wirelessly.
To access the Internet you need to connect the DSL or cable modem to the WAN (Internet) port on the wireless router.
Dec 01, 2009 | MSI Wireless-G RG54G3 Router
I have been given the MSI RG54G3 Router without a
HI! I bliv u are having some issue setting up ur router.. I will be more than glad to assist u. . here are the steps u need to do:
1. press the reset button on the back of the router for 20sec..while pressing the reset button, unplug the power plug and after 2secs while pressing the reset button plug it back in and press for 30secs after that unplug the router for 15secs then plug it back in..once all the lights are solid and ok
2. connect the ethernet cable to port1 of the router and the other end to the lan port of your computer..
3. pull up ur browser then type at the url:192.168.1.1.or 192.168.0.1 or u can check the routers default gateway by right clicking the network icon on the lower right of your task bar and click on status and it will show the ip address of the computer, subnetmask and default gateway, the default gateway is the routers ip address, once u type in to the url, it will ask u the username and password, by default the username is admin and the password is 1234 or just leave it blank
4. it will show the setup page of the router. u can set the router on the specific internet setup that u have.
a. if ur isp is a cable company, normaly u need to do a mac clone on the router setup page by cloning the computer that is reg to the cable company, how to determine it. ex. the computer that is reg to the cable company is a desktop or laptop, if this computer is connected to the modem directly and u can access internet.
b. once u determined it u need to connect this computer directly to the router and do a mac clone and set ur internet settings to auto-dhcp..then save the settings and after that, unplug to the power of the modem and router, plug in 1st the power of the modem then once all lights lit, plug in the router, then once all lights lit, try to pull up a browser that ur computer is connected directly to the router.. ur cable connection shud be, cable from the modem will go to the WAN port of the router and connect ethernet cable on port1 going to the lan port of the computer..once u can access the internet, u can now access again the setup page of the router by typing at the url:192.168.1.1 and u can setup the wireless settings, u need to create a ssid or wireless name and a security..
5. If ur isp is a dsl normaly they give u a username and password to connect to the internet, ur settings on the router should be PPPoe
6. If ur isp gives u a static ip address settings, u need to set the router to isp setup.
a. how to check the isp of the isp given to u..
1. click on start
2. run
3. type cmd
4. it will show a dos prompt
5. from the dos prompt type ipconfig/all
6. it will list the ip address, subnet, default gateway, dns server
this settings should be type in to the settings on the router for static ip addressing..
7. Once your done on the internet setting, go to your wireless connection settings and you can create a wireless network name or ssid, set a security by selecting wep, wpa, wpa2.
8. once all is set. save the settings and to check if your laptop can access the wireless network that you did, turn on the wireless switch of your laptop, once its on, it will show the wireless network icon on the lower right of the taskbar, right click it and select on view available network, the network name that u did should list, just select it and connect and it will ask for the password, just type the password and connect, you should be connected to the wireless network and have internet access..
9. If you are going to hook up your desktop to the wireless connection, you need to install a wireless network adapter, install the driver and do the same thing as u did to the laptop, for the desktop no need of turning on the wireless switch, once you install the driver correctly, it will show a network icon..
if you have any query pls feel free to get in touch.. good luck
Oct 05, 2009 | MSI Wireless-G RG54G3 Router
How do i encrypt my system
Hi, I will lend a hand if I can.
There are four basic steps to set up wireless security:
1) Login to your router
2) Change the router login password/username
3) Change the network name, or SSID
4) Enable WPA encryption
As you only want encryption, I will go straight to step 4. The following is based on the manual for the MSI RG54G3.
Here are the details:
1. Login to your router.
2. Go to Setup> Wireless.
3.
Select WPA-PSK - strictly speaking the correct option depends on your wireless adapter. However, this is usually a good choice to start with. You may see one or more new options pop up. Select ASCII if necessary.
4.
Under ‘Pre-Share Key’ you should enter a long password, or passphrase, between 8 and 63 letters/numbers long. This can be any series of letters/ numbers, or you can use a phrase with numbers ( eg - 456HappynEWYeartoyou8899). It is case sensitive.
5. Note down the ‘Pre-share key’, also called the network key, carefully. You will need this to connect wirelessly. (The network key may also be called a WPA shared key, PSK, pre-shared key, passphrase, authentication key). Click ‘Save’ when finished.
When you next attempt to connect wirelessly, you are asked for the network key you've just set up. If all goes well, you can then save this and will connect automatically in future.
Hope this helps, but if it is not clear or doesn't work, please come back to Fixya. Good luck.
Jan 05, 2009 | MSI Wireless-G RG54G3 Router
Wireless conncection
depending on who your ISP is, you need an ethernet cable coming from the modem into the WAN/Internet port on back of router. Once that is in you can try to connect wirelessly using the settings your router is setup for :
SSID/network name
encryption type
encryption key/passkey/passphrase
-- this part is dependent on above setting
wireless channel
Jul 08, 2008 | MSI Wireless-G RG54G3 Router
WIFI Connection
Ensure the router is able to broadcast b + g radio signals, select it to do both rather than just one or the other.
Mar 15, 2008 | MSI Wireless-G RG54G3 Router
Help me please
Two separate solutions are needed.
First, you will need to ask your ISP (Internet Service Provider) to assign a "fixed IP address" to your Internet connection. Your ISP typically assigns addresses to home users out of a large "pool" of addresses that are shared among several customers. Because of this, your home network address is not always the same. Most ISP's charge an extra fee to always keep your address the same.
The second task is to configure the firewall function in your router so it will pass connections through from the WAN to the device inside your network. The procedure to do this should be included in the instruction manual for your router.
Jan 06, 2008 | MSI Wireless-G RG54G3 Router
MSI rg54g3 ieee802.11g vista driver
Generally you do not install a router onto a PC you connect to a router with a wire using a network adapter or wirelessly with a wireless adapter. Can you any of the following you have identify you make and model of PC, make and model of add-on adapter card? Then I may be able to assist you in determining if a driver exists for the device attached to your computer intended to communicate with the identified router.
Thanks
Dec 09, 2007 | MSI Wireless-G RG54G3 Router
MSI Wireless-G RG54G3 Router Logo
223 people viewed this question
Top MSI Computers & Internet Experts
vsri9
Alun Cox
David
David
Are you a MSI Computer and Internet Expert? Answer questions, earn points and help others
