Question about Whirlpool 21.0 cu. ft. Top Freezer Refrigerator with IceMagic Plus Ice Maker
I have a GE refrigerator that is leaking water from the vent in the fridge coming form the freezer on top i found the drain hole what is the best way to thaw and clean it?
    Genius:
  • 1,122 Answers
IF THE DRAIN IS FROZEN YOU CAN USE A HAIR DRYER,TO CLEAN IT YOU CAN USE A FLEXIBLE HANGER AND THEN **** IT OUT WITH A SHOP VAC>-MIKE
Posted on Mar 02, 2009
Older ge refrig, freezer at top leaking water into refrigator compartment below. otherwise its working fine.
Its the defrost problem. The drain hole is clogged and water is leaking in fridge section instead of draining through drain hole.Defrost the unit and check, for defrosting procedure , click the link below and follow the procedure:--- http://technoanswers.blogspot.com/2011/07/ge-refrig-freezer-at-top-leaking-water.html --------- This should help.Thanks.Helpmech.
Jul 08, 2011 | Refrigerators
Water leaking in refrigerator and floor of a 1997 GE top freezer type,model numberTBX22P1
As the only source of water is condensation or melting food, I would check to see if there is a drain hole at the bottom back of the fridge. This hole is to drain any water into the back of the machine where it evaporates. Use a pipe cleaner or similar to poke the muck through the hole and the water will drain away. Keep this hole clean every time you clean your fridge.
Mar 27, 2011 | GE Refrigerators
Leaks water inside from the ports or vents under freezer but in fridge
Your problem more than likely is a plugged defrost line in the freezer...The freezer goes through periodic defrost cyles to keep the coils from freezing up. The water catches in a trough pan in the freezer and flows through a drain hole to the bottom of the fridge where it evaporates. This drain hole perodically freezes up and the water accomulates under the freezer bottom until the water level reaches your vent ports to the fridge section. Open your freezer and on the bottom floor of your freezer you should see two screws near the front on either side. Remove them and then take out the bottom tray....this will expose the drain hole near the rear of the freezer compartment. You will more than likely have to remove ice under the tray in order to see the drain hole. Remove the lower back panel on the back of the refrigerator and you should be able to see the drain line coming from the freezer. Unplug the refrigerator before you begin work. It will take a little while for the drain line to thaw to allow liquid to flow to the bottom. I find a hair dryer pretty handy in speeding up the process. To verify you have unplugged the drain line you should be able to pour hot water in the drain hole in the freezer and see it come out at the rear of the fridge in tube line just above a little catch pan
Feb 08, 2011 | Kenmore 64802 Top Freezer Refrigerator
Refrigerator ge profile model TFH27PR water leaking onto floor
Hi this problem could arise due to various reasons so lets find out what could it be the cause.
1)In the back of your freezer compartment is the drain hole. It's very common in GE for the drain to freeze up. With the drain hole plugged up, your freezer will continue to defrost the evaporator, but not the water in the drain hole. So the water builds and freezes, builds and freezes until it eventually overflows into the air diffuser for the fridge causing the leaky fridge problem."Heat Probe" that can be installed.This will prevent water from freezing up in the drain hole allowing it to drain as designed
2)Inspect the door seals and the sides of the refrigerator around the doors. If you see any beads of water or moisture, then the door seals may be failing to create an air tight seal which causes the cold air from the refrigerator to escape and form condensation around the doors. Sometimes you can solve this problem by applying a light film of gasket lubricant to the existing seals or just cleaning them of any debris with a warm soapy rag. If they still don't seal well after you apply lubricant, or clean them, you may need to replace the entire seal assembly.
3) If the water is coming from the freezer but you think that the defrost drain pipe is clear, then it may be coming from the ice maker. Check the ice maker for cracks in the unit's body or a misalignment of the water supply line. Make sure that the water supply spout in the freezer lines up with the ice maker's water supply cup.
4)Check the ice maker copper water supply line, your ice maker water filter, and the plastic ice maker water supply tube for any cracks, splits or connection leaks. If you find any leaks, remove the leaking part and obtain a replacement at the hardware store.
5)Your leaking refrigerator may just have a cracked or damaged drain pan. Your fridge regularly drains water into this pan to prevent water pooling in the fridge itself. Evaporation takes care of the rest. Look underneath your fridge where the drain pan sits and pull it out for inspection. If it has a crack or is otherwise damaged, contact the appropriate retailer about getting a replacement as soon as possible.
6)If your leaking refrigerator is draining inside as opposed to onto your floor, you're probably dealing with a clogged defrost drain. Your fridge is constantly producing condensation inside the freezer, and that condensation drips down the defrost drain into a drain pan underneath the unit. This defrost drain can become clogged with debris or, more often, it freezes shut. Look in your refrigerator manual to locate your defrost drain, and take the appropriate steps to unclog it (inundating your drain with warm water will often do the trick).
Note:Switch you Refrigerators for more than 8 hours and let the frost melt fully use hair dryer and now switch on and check you are getting leak.
post a comment for further assistance.
Thank you for using fixya have a nice day:-)
Sep 09, 2010 | GE Refrigerators
Kitchen Aid KTRC22EK leak inside refridgerator
It sounds like the drain for the defrost water is pluged. You can remove the back panel inside the freezer(ice maker will have to coe out first) and access the drain in the rear center of the freezer. Check the drain. It can be defrsted with a hair dryer(shut off the referigerator first) good luck, snugglepants
Nov 03, 2009 | KitchenAid KTRS22EL Top Freezer...
My ge fridge model TBX18k lg has water building up underneath the drawers in the bottom of fridge. Must be coming from freezer section, but my model has no water dispenser or ice maker. Got any ideas?
Remove the food from the freezer and then remove the rear freezer wall . Should be 2-4 screws and maybe a clip on each side on the top vent . Once the panel is removed , useing a hairdryer , defrost the tray below the coils until you can see the drain hole . Defrost the drain hole until water begins to flow into the hole . Use a small hose inserted into the hole and blow out any debris which has accumulated . You can also use hot water to help defrost the drain hole . Once completed , reinstaal the panel and of course , food .
Aug 08, 2009 | GE Refrigerators
Ice forming in the bottom of the freezer
Unclogh the drain hole inside the freezer in the bottom of the bakc wall pouring hot water until the ice melted and keep pouring until goes through.Repet this every 3 or 4 months to keep it clear.
Jul 22, 2009 | GE GSL25JFPBS Side by Side Refrigerator
Frozen vents from freezer to fridge
you most likely have a defrost problem.or a clogged drain.you need to check your defrost heater defrost timer and thermostat.if ice is formed over drain then you can unclog drain with hot water.you will see when it is unclogged,water will run down drain without running over into bottom of freezer.
Mar 09, 2009 | Kenmore 21.7 cu. ft. Top Freezer...
Ge fridge
the panel comes off the outside of the door, probably a cracked or loose water line. use care when prying around on the front panel, look for small screws in the bottom of tray drain (which should lift out ).
Jul 14, 2007 | GE Hotpoint Top-Freezer Refrigerator
Whirlpool 21.0 cu. ft. Top Freezer Refrigerator with IceMagic Plus Ice Maker Logo
67 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
