Question about Samsung HL-R6167W 61" HDTV
I installed a new color wheel in my 6167w 61 inch hdtv. Now my colors are all messed up. Like the reds and blues are backwards.
    President:
  • Samsung Master
  • 1,779 Answers
You must go into service mode and re-align the registers, if you've never done this you must call a qualified svc center. Most color wheel replacements require re-alignment. The DLP must match the speed of the color wheel.
Posted on Feb 26, 2009
Is it possible to have only the red tint projector lamp replaced on 61" projector Samsung tv
No. This is a DLP TV. It gets it's color by a color wheel. If color seems to drift across screen or there is a loud-ish whining noise from back of TV that you can here clear across a room, then this color wheel may be bad. They wear out.
Jan 07, 2015 | Samsung HLN617W 61" Rear Projection HDTV
62" RCA dlp loses color
If you hear any winding, whirling or screeching noise (Color Wheel symptoms)
If there is any vibrations in the TV (Color Wheel symptoms) you would need to change the color wheel.
Apr 15, 2010 | RCA HD61LPW165 61" Projection HDTV
The color apprears to be in like 3d I was told it was teh color wheel but its not making any noises
It's the color wheel. The color wheel does not need to make noises for the color wheel to be bad. Sometimes it can spin slower or malfunction all together and you'll get intermittent shadows or color splotches with messed up skin tones.
Feb 05, 2010 | RCA HD61LPW165 61" Projection HDTV
My RCA 61" DLp has lost its red hue.
If its not the color wheel its the Light engine! Call Encompass Parts 1-800-638-3328
Dec 17, 2009 | RCA HD61LPW165 61" Projection HDTV
Samsung HLN617W DLP 61" TV only show green color
BINGO! Light Engine, Maybe listed as- Assy Engine Go to website Encompass Parts Distr their you will find what you need or Call 1-800-638-3328 ,or Try UED 1-800-648-6657
Dec 01, 2009 | Samsung HLN617W 61" Rear Projection HDTV
Infocus 61 inches DLP-HDTV.
Infocus was always made by RCA for infocus the parts are straight RCA be warned that the parts for the RCA dlp's are very exspensive
Mar 04, 2009 | RCA HD61LPW42 61" Rear Projection HDTV
Color is wrong after color wheel replacement
You probably replaced a bearing colorwheel, and it was replaced with a bearingless. If you look inside the TV on the back of the light engine (the silver box in front of and to the left of the color wheel), there should be a jumper (that connects two wires coming out) toward the bottom of it in a recessed little hole. That jumper should be removed if the color wheel was replaced with the air bearing type. Just grasp it gently with a pair of needle nose pliers, and pull it out slowly.
This should restore a normal color operation, but there might be some other adjustments that need to be made if it doesn't clear it up completely.
I hope this helps you...
Jan 22, 2009 | RCA HD61LPW42 61" Rear Projection HDTV
Mixed colors
Color wheels in that unit were updated to remedy a flaw in their initial manufacturing. I suspect you have one of the updated wheels and now the dmd board is having a problem distinquishing relative speed etc. Pull dmd jumper to fix it. Remove the jumper pin on the dmd board, metal shield has a cut-out so you can just reach in and grab it with a pair of needle nose pliers and pull it out.
Bill
William Rayburn, CET
Premium Technologies
PO Box 442
Long Beach, WA. 98631
360-642-4993
Nov 04, 2008 | Samsung HL-R6167W 61" HDTV
Samsung color wheel jumper
possible cable is not making full contact with connector to or from color wheel assy.
Jul 15, 2008 | Samsung DLP HL-P5663W 56" TV
Samsung 61 inch DLP
Needs color wheel. What's the model #?
Oct 27, 2007 | Samsung HLN617W 61" Rear Projection HDTV
Samsung HL-R6167W 61" HDTV Logo
380 people viewed this question
Henry  Thomas
Henry Thomas
