Question about Amana ALW480DA Top Load Washer
Amana Washer LWA50AW doesn't spin
This washing machine is 12 years old. Is it a belt drive or direct transmission for the agitator and spin cycle? If it's a belt drive what are the steps in replacing the belt?
  • 5 Answers
Ifi t does not spin it may be the timer. Try it in the delicate cycle to see what happens. Actually try all teh cycles to see if it spins in one of them. IF so it most likely is the time and is a 15minute job to replace.
Posted on Apr 26, 2010
  • 686 Answers
Pry up the top remove screws on front panel toward top set front panel aside and you should see what you need to do
Posted on Feb 27, 2009
Maytag washer doesn't agitate
Google the model number. I had the same problem, Googled it, and found the actual turial on YouTube to fix it.
Dec 11, 2011 | Maytag MAV6200 Top Load Washer
Washer fills, agitates, won't spin. Makes buzzing noise. Amana LWA50AW
Most likely it could be the forward belt . When the machine is under load you hear a winding noise it sounds like the pulley belt tensioner. One other thing to check the rinse and hold button is activated as in the past accidentally people have switched it off.
Jul 26, 2011 | Amana 3.2 cu. ft. Top-Load Washer
The washing machine belt will move to agitate, but will not move to spin. The spin action burns up the belt. This is an Amana LWA50AW
open rear cover , see if belt slips. then remove belt and rotate empty drum if its jam than drum bearings need to change. if drum is free then belt might be loose and needs replacement.
Nov 05, 2009 | Zanussi FJS1225W Front Load Washer
Agitator doesn't spin during wash cycle
If The washer won't agitate
Check to make sure no clothing got wrapped around the agitator. Check the lid switch, timer, and drive belt, other potential causes, such as a bad transmission or bad agitate/spin solenoid, but they are much more involved.
if the washer won't spin, the lid switch, timer, drive belt, transmission, or agitate/spin solenoid could be the cause here as well. Sometimes if the load is unbalanced or too heavy, the washer won't spin. Take some of the clothes out and try the spin cycle again with a lighter load.
Here are the steps to replace the agitator.
1: Take the fabric softener dispenser off and pry off the agitator lid.
2: Use a socket wrench with an extension bar to remove the stud and seal.
3: Remove the agitator top and bottom.
4: Check the agitator clutch assembly (located in the agitator top) for excessive wear.
5: To replace, just reverse the directions.
Jun 29, 2009 | Washing Machines
Kenmore washer (model # 110 24872300) won't agitate.
Your machine has no belt. It has a direct drive coupling. The direct drive coupling between the motor and transmission must be replaced.
May 20, 2009 | Kenmore 24902 Top Load Washer
Crown series 12 cycle washer will not agitate and smells like something is burning like a for instance a vacumme belt kinda smell in that cycle it spins fine fills fine drains fine but just makes a so
It doesn't agitate If your washer doesn't agitate, check these:
Lid switch
Motor coupler
Belts
Clutch
Drive motor
Drive pulleys
Transmission
Agitator
Lid switch If the lid switch is defective, the washing machine may not agitate or function at all. The switch is inside the washing machine main housing near the door frame. Often you have to raise or open the top or front of the washing machine to get to the switch. If it's defective, you need to replace it.
Motor coupler Many washers produced by Whirlpool® use a small, relatively inexpensive motor coupling. It's plastic and rubber and is mounted to the shaft of the motor on one side, and to the transmission on the other. Over time, the coupler wears out and fails. If this happens, you need to completely replace it.
Belts Many washing machines have one or two belts. If a belt is broken or badly worn, you need to replace it with a genuine belt from the manufacturer. (Some washing machine belts are designed with special characteristics not found in automotive belts.)
Clutch If your washer was made by GE®, it may use a clutch for agitating the clothes. As the clutch wears out, it may prevent the washer from agitating well or at all. If the clutch is worn, you need to replace it. For this job, you probably want to hire a qualified appliance repair technician.
Drive motor Many washer brands use a reversing motor. For agitation the motor runs in one direction, for spinning and draining, the other. It's possible for a motor to burn out in one direction and continue to operate in the other. If this happens, you need to replace the entire motor.
Drive pulleys The motor or transmission drive pulley may be worn and unable to turn the drive belt. If so, replace the pulley.
Transmission The transmission could have either of these problems:
  • Older washers produced by Whirlpool® have a transmission with an electro-mechanical shifter. If the shifter becomes even partially defective, the unit may not agitate properly or at all.
  • The transmission may have a worn or broken gear, or some other internal problem.
If you suspect a transmission problem, you may have to call a qualified appliance repair technician to repair it.
Agitator The inside of the agitator--where the transmission shaft attaches--can become worn, and strip out the spline that allows the agitator to properly grip the shaft. Then the transmission shaft rotates back and forth as it should, but the agitator doesn't move properly. If this happens, you may need to replace the agitator and/or the transmission spline.
May 07, 2009 | Frigidaire FWSB5700DS Top Load Washer
Washing Machine Shaft Wont Move
Lid switch
Motor coupler
Belts
Clutch
Drive motor
Drive pulleys
Transmission
Agitator
It's noisy Most noises from a washing machine occur during the spin cycle. If you hear loud thumping during the spin, the load of clothes may have become unbalanced. Stop the washer and redistribute the clothes, then re-start it. Repeat these steps if necessary.
Dec 08, 2008 | Amana 3.2 cu. ft. Top-Load Washer
Kenmore stacked W/D will not agitate during wash cycle
hi thanks for the question i dont know the model of your washer but i think yours is a direct drive no belt you have a motor drive coupling which is located between the motor and transmission replace that part thanks the appliance doctor
Mar 31, 2008 | Kenmore 98702 Stacked Washer/Dryer
Amana ALW480DA Top Load Washer Logo
1,037 people viewed this question
Top Amana Washing Machines Experts
Dan Webster
Dan Webster
Mike
Gerry Harvey
Gerry Harvey
Are you an Amana Washing Machine Expert? Answer questions, earn points and help others
