Question about ASUS F5RL-X1 Notebook
Keyboard doent work very well
Hi !!
Some letters dont work, like X,C,B,N, space, Ctrl, Alt , windows key. These dont work in the left side of the keyboard.
Thank you very much.
Fabio.
    President:
  • 2,653 Answers
You'll need to replace the keyboard.
Ebay will probably be the cheapest place to get one.
If you're uncomfortable installing it yourself, find someone on craigslist or a local repair shop to do it.
Should only take them 5-10 minutes to do so don't let them charge you an arm and a leg to do it.
Best of luck!
Posted on Feb 26, 2009
Letter between c and b wont work! its the paste code key also and I dont recall using it to paste anything Whmat's your problem?
Of course, it wont work because you used a wrong short cut key. The correct short cut command for copying is press the control C simultaneously then for pasting it, it should control V simultaneously. Try it again using the right short cut command. Good luck!
Sep 20, 2011 | Microsoft Comfort Curve 2000 Keyboard
Tip
Amazing shortcuts
Getting used to using your keyboard exclusively and leaving your mouse behind will make you much more efficient at performing any task on any Windows system. I use the following keyboard shortcuts every day:<br /><br />Windows key + R = Run menu<br /><br />This is usually followed by:<br />cmd = Command Prompt<br />iexplore + "web address" = Internet Explorer<br />compmgmt.msc = Computer Management<br />dhcpmgmt.msc = DHCP Management<br />dnsmgmt.msc = DNS Management<br />services.msc = Services<br />eventvwr = Event Viewer<br />dsa.msc = Active Directory Users and Computers<br />dssite.msc = Active Directory Sites and Services<br />Windows key + E = Explorer<br /><br />ALT + Tab = Switch between windows<br /><br />ALT, Space, X = Maximize window<br /><br />CTRL + Shift + Esc = Task Manager<br /><br />Windows key + Break = System properties<br /><br />Windows key + F = Search<br /><br />Windows key + D = Hide/Display all windows<br /><br />CTRL + C = copy<br /><br />CTRL + X = cut<br /><br />CTRL + V = paste<br /><br />Also don't forget about the "Right-click" key next to the right Windows key on your keyboard. Using the arrows and that key can get just about anything done once you've opened up any program.<br /><br /><br />Keyboard Shortcuts<br /><br />[Alt] and [Esc] Switch between running applications<br /><br />[Alt] and letter Select menu item by underlined letter<br /><br />[Ctrl] and [Esc] Open Program Menu<br /><br />[Ctrl] and [F4] Close active document or group windows (does not work with some applications)<br /><br />[Alt] and [F4] Quit active application or close current window<br /><br />[Alt] and [-] Open Control menu for active document<br /><br />Ctrl] Lft., Rt. arrow Move cursor forward or back one word<br /><br />Ctrl] Up, Down arrow Move cursor forward or back one paragraph<br /><br />[F1] Open Help for active application<br /><br />Windows+M Minimize all open windows<br /><br />Shift+Windows+M Undo minimize all open windows<br /><br />Windows+F1 Open Windows Help<br /><br />Windows+Tab Cycle through the Taskbar buttons<br /><br />Windows+Break Open the System Properties dialog box<br /><br /><br /><br />acessability shortcuts<br /><br />Right SHIFT for eight seconds........ Switch FilterKeys on and off.<br /><br />Left ALT +left SHIFT +PRINT SCREEN....... Switch High Contrast on and off.<br /><br />Left ALT +left SHIFT +NUM LOCK....... Switch MouseKeys on and off.<br /><br />SHIFT....... five times Switch StickyKeys on and off.<br /><br />NUM LOCK...... for five seconds Switch ToggleKeys on and off.<br /><br />explorer shortcuts<br /><br />END....... Display the bottom of the active window.<br /><br />HOME....... Display the top of the active window.<br /><br />NUM LOCK+ASTERISK....... on numeric keypad (*) Display all subfolders under the selected folder.<br /><br />NUM LOCK+PLUS SIGN....... on numeric keypad (+) Display the contents of the selected folder.<br /><br />NUM LOCK+MINUS SIGN....... on numeric keypad (-) Collapse the selected folder.<br /><br />LEFT ARROW...... Collapse current selection if it's expanded, or select parent folder.<br /><br />RIGHT ARROW....... Display current selection if it's collapsed, or select first subfolder.<br /><br /><br /><br /><br />Type the following commands in your Run Box (Windows Key + R) or Start Run<br /><br />devmgmt.msc = Device Manager<br />msinfo32 = System Information<br />cleanmgr = Disk Cleanup<br />ntbackup = Backup or Restore Wizard (Windows Backup Utility)<br />mmc = Microsoft Management Console<br />excel = Microsoft Excel (If Installed)<br />msaccess = Microsoft Access (If Installed)<br />powerpnt = Microsoft PowerPoint (If Installed)<br />winword = Microsoft Word (If Installed)<br />frontpg = Microsoft FrontPage (If Installed)<br />notepad = Notepad<br />wordpad = WordPad<br />calc = Calculator<br />msmsgs = Windows Messenger<br />mspaint = Microsoft Paint<br />wmplayer = Windows Media Player<br />rstrui = System Restore<br />netscp6 = Netscape 6.x<br />netscp = Netscape 7.x<br />netscape = Netscape 4.x<br />waol = America Online<br />control = Opens the Control Panel<br />control printers = Opens the Printers Dialog<br /><br /><br />internetbrowser<br /><br />type in u're adress "google", then press [Right CTRL] and [Enter]<br />add www. and .com to word and go to it<br /><br /><br />For Windows XP:<br /><br />Copy. CTRL+C<br />Cut. CTRL+X<br />Paste. CTRL+V<br />Undo. CTRL+Z<br />Delete. DELETE<br />Delete selected item permanently without placing the item in the Recycle Bin. SHIFT+DELETE<br />Copy selected item. CTRL while dragging an item<br />Create shortcut to selected item. CTRL+SHIFT while dragging an item<br />Rename selected item. F2<br />Move the insertion point to the beginning of the next word. CTRL+RIGHT ARROW<br />Move the insertion point to the beginning of the previous word. CTRL+LEFT ARROW<br />Move the insertion point to the beginning of the next paragraph. CTRL+DOWN ARROW<br />Move the insertion point to the beginning of the previous paragraph. CTRL+UP ARROW<br />Highlight a block of text. CTRL+SHIFT with any of the arrow keys<br />Select more than one item in a window or on the desktop, or select text within a document. SHIFT with any of the arrow keys<br />Select all. CTRL+A<br />Search for a file or folder. F3<br />View properties for the selected item. ALT+ENTER<br />Close the active item, or quit the active program. ALT+F4<br />Opens the shortcut menu for the active window. ALT+SPACEBAR<br />Close the active document in programs that allow you to have multiple documents open simultaneously. CTRL+F4<br />Switch between open items. ALT+TAB<br />Cycle through items in the order they were opened. ALT+ESC<br />Cycle through screen elements in a window or on the desktop. F6<br />Display the Address bar list in My Computer or Windows Explorer. F4<br />Display the shortcut menu for the selected item. SHIFT+F10<br />Display the System menu for the active window. ALT+SPACEBAR<br />Display the Start menu. CTRL+ESC<br />Display the corresponding menu. ALT+Underlined letter in a menu name<br />Carry out the corresponding command. Underlined letter in a command name on an open menu<br />Activate the menu bar in the active program. F10<br />Open the next menu to the right, or open a submenu. RIGHT ARROW<br />Open the next menu to the left, or close a submenu. LEFT ARROW<br />Refresh the active window. F5<br />View the folder one level up in My Computer or Windows Explorer. BACKSPACE<br />Cancel the current task. ESC<br />SHIFT when you insert a CD into the CD-ROM drive Prevent the CD from automatically playing.<br /><br />Use these keyboard shortcuts for dialog boxes:<br /><br />To Press<br />Move forward through tabs. CTRL+TAB<br />Move backward through tabs. CTRL+SHIFT+TAB<br />Move forward through options. TAB<br />Move backward through options. SHIFT+TAB<br />Carry out the corresponding command or select the corresponding option. ALT+Underlined letter<br />Carry out the command for the active option or button. ENTER<br />Select or clear the check box if the active option is a check box. SPACEBAR<br />Select a button if the active option is a group of option buttons. Arrow keys<br />Display Help. F1<br />Display the items in the active list. F4<br />Open a folder one level up if a folder is selected in the Save As or Open dialog box. BACKSPACE<br /><br />If you have a Microsoft Natural Keyboard, or any other compatible keyboard that includes the Windows logo key and the Application key , you can use these keyboard shortcuts:<br /><br /><br />Display or hide the Start menu. WIN Key<br />Display the System Properties dialog box. WIN Key+BREAK<br />Show the desktop. WIN Key+D<br />Minimize all windows. WIN Key+M<br />Restores minimized windows. WIN Key+Shift+M<br />Open My Computer. WIN Key+E<br />Search for a file or folder. WIN Key+F<br />Search for computers. CTRL+WIN Key+F<br />Display Windows Help. WIN Key+F1<br />Lock your computer if you are connected to a network domain, or switch users if you are not connected to a network domain. WIN Key+ L<br />Open the Run dialog box. WIN Key+R<br />Open Utility Manager. WIN Key+U<br /><br />accessibility keyboard shortcuts:<br /><br />Switch FilterKeys on and off. Right SHIFT for eight seconds<br />Switch High Contrast on and off. Left ALT+left SHIFT+PRINT SCREEN<br />Switch MouseKeys on and off. Left ALT +left SHIFT +NUM LOCK<br />Switch StickyKeys on and off. SHIFT five times<br />Switch ToggleKeys on and off. NUM LOCK for five seconds<br />Open Utility Manager. WIN Key+U<br /><br />shortcuts you can use with Windows Explorer:<br /><br /><br />Display the bottom of the active window. END<br />Display the top of the active window. HOME<br />Display all subfolders under the selected folder. NUM LOCK+ASTERISK on numeric keypad (*)<br />Display the contents of the selected folder. NUM LOCK+PLUS SIGN on numeric keypad (+)<br />Collapse the selected folder. NUM LOCK+MINUS SIGN on numeric keypad (-)<br />Collapse current selection if it's expanded, or select parent folder. LEFT ARROW<br />Display current selection if it's collapsed, or select first subfolder. RIGHT ARROW<br /><br />
on Jan 10, 2011 | Computers & Internet
Tip
Key-bord shorcut
· Shift + F10 right-clicks.
Win + L (XP Only): Locks keyboard.
Similar to LockWorkstation.
· Win + F or F3: Open Find dialog. (All Files) F3 may notwork in some applications which use F3 for their own find dialogs.
Win + Control + F: Open Find dialog. (Computers)
Win + U: Open Utility Manager.
Win + F1: Open Windows help.
Win + Pause: Open System Properties dialog.
· Win + Tab: Cycle through taskbar buttons.
Enter clicks,AppsKey or Shift + F10 right-clicks.
· Win + Shift + Tab: Cycle through taskbar buttons inreverse.
· Alt + Tab: Display CoolSwitch. More commonly known as theAltTab dialog.
Alt + Shift + Tab: Display CoolSwitch; go in reverse.
· Alt + Escape: Send active window to the bottom of thez-order.
· Alt + Shift + Escape: Activate the window at the bottomof the z-order.
· Alt + F4: Close active window; or, if all windows areclosed, open shutdown dialog.
Shift while a CD is loading: Bypass AutoPlay.
· Shift while login: Bypass startup folder. Only thoseapplications will be ignored which are in the startup folder, not those startedfrom the registry (MicrosoftWindowsCurrentVersionRun)
· Ctrl + Alt + Delete or Ctrl + Alt + NumpadDel (BothNumLock states): Invoke the Task Manager or NT Security dialog.
· Ctrl + Shift + Escape (2000/XP ) or (Ctrl + Alt +NumpadDot) : Invoke the task manager. On earlier OSes, acts like Ctrl + Escape.
· Printscreen: Copy screenshot of current screen toclipboard.
· Alt + Printscreen: Copy screenshot of current activewindow to clipboard.
Ctrl + Alt + Down Arrow: Invert screen. Untested on OSesother than XP. · Ctrl + Alt + Up Arrow: Undo inversion.
Win + B : Move focus to systray icons.
2.) Generic
· Ctrl + C or Ctrl + Insert: Copy.
Ctrl + X or Shift + Delete: Cut.
· Ctrl + V or Shift + Insert: Paste/Move.
· Ctrl + N: New... File, Tab, Entry, etc.
· Ctrl + S: Save.
Ctrl + O: Open...
· Ctrl + P: Print.
· Ctrl + Z: Undo.
· Ctrl + A: Select all.
· Ctrl + F: Find...
Ctrl+W : to close the current window
· Ctrl + F4: Close tab or child window.
F1: Open help.
· F11: Toggle full screen mode.
Alt or F10: Activate menu bar.
Alt + Space: Display system menu. Same as clicking theicon on the titlebar. · Escape: Remove focus from current control/menu, or closedialog box.
3.) Generic Navigation
Tab: Forward one item.
· Shift + Tab: Backward one item.
· Ctrl + Tab: Cycle through tabs/child windows.
Ctrl + Shift + Tab: Cycle backwards through tabs/childwindows.
· Enter: If a button's selected, click it, otherwise, clickdefault button.
· Space: Toggle items such as radio buttons or checkboxes.
Alt + (Letter): Activate item corresponding to (Letter).(Letter) is the underlined letter on the item's name.
Ctrl + Left: Move cursor to the beginning of previousword.
· Ctrl + Right: Move cursor to the beginning of next word.
Ctrl + Up: Move cursor to beginning of previousparagraph. This and all subsequent Up/Down hotkeys in this section have onlybeen known to work in RichEdit controls.
· Ctrl + Down: Move cursor to beginning of next paragraph.
Shift + Left: Highlight one character to the left.
· Shift + Right: Highlight one character to the right.
· Shift + Up: Highlight from current cursor position, toone line up.
· Shift + Down: Highlight from current cursor position, toone line down.
· Ctrl + Shift + Left: Highlight to beginning of previousword.
Ctrl + Shift + Right: Highlight to beginning of nextword.
Ctrl + Shift + Up: Highlight to beginning of previousparagraph.
Ctrl + Shift + Down: Highlight to beginning of nextparagraph.
Home: Move cursor to top of a scrollable control.
· End: Move cursor to bottom of a scrollable control.
on Oct 10, 2010 | Computers & Internet
Hi im sorry to bother u but im wondering wich letter goes on each key ? plz answer back soon thank u!
1234567890-=backspace
tab qwertyuiop
caps lock asdfghjkl;'enter
shift zxcvbnm,./ shift
ctrl fn alt space bar alt ctrl
besides # and letters most keyboards r a bit different...hope this helps.
May 13, 2010 | Toys
Guide
General keyboard shortcuts loadTOCNode(2, 'moreinformation');
  • CTRL+C (Copy)
  • CTRL+X (Cut)
  • CTRL+V (Paste)
  • CTRL+Z (Undo)
  • DELETE (Delete)
  • SHIFT+DELETE (Delete the selected item permanently without placing the item in the Recycle Bin)
  • CTRL while dragging an item (Copy the selected item)
  • CTRL+SHIFT while dragging an item (Create a shortcut to the selected item)
  • F2 key (Rename the selected item)
  • CTRL+RIGHT ARROW (Move the insertion point to the beginning of the next word)
  • CTRL+LEFT ARROW (Move the insertion point to the beginning of the previous word)
  • CTRL+DOWN ARROW (Move the insertion point to the beginning of the next paragraph)
  • CTRL+UP ARROW (Move the insertion point to the beginning of the previous paragraph)
  • CTRL+SHIFT with any of the arrow keys (Highlight a block of text)
  • SHIFT with any of the arrow keys (Select more than one item in a window or on the desktop, or select text in a document)
  • CTRL+A (Select all)
  • F3 key (Search for a file or a folder)
  • ALT+ENTER (View the properties for the selected item)
  • ALT+F4 (Close the active item, or quit the active program)
  • ALT+ENTER (Display the properties of the selected object)
  • ALT+SPACEBAR (Open the shortcut menu for the active window)
  • CTRL+F4 (Close the active document in programs that enable you to have multiple documents open simultaneously)
  • ALT+TAB (Switch between the open items)
  • ALT+ESC (Cycle through items in the order that they had been opened)
  • F6 key (Cycle through the screen elements in a window or on the desktop)
  • F4 key (Display the Address bar list in My Computer or Windows Explorer)
  • SHIFT+F10 (Display the shortcut menu for the selected item)
  • ALT+SPACEBAR (Display the System menu for the active window)
  • CTRL+ESC (Display the Start menu)
  • ALT+Underlined letter in a menu name (Display the corresponding menu)
  • Underlined letter in a command name on an open menu (Perform the corresponding command)
  • F10 key (Activate the menu bar in the active program)
  • RIGHT ARROW (Open the next menu to the right, or open a submenu)
  • LEFT ARROW (Open the next menu to the left, or close a submenu)
  • F5 key (Update the active window)
  • BACKSPACE (View the folder one level up in My Computer or Windows Explorer)
  • ESC (Cancel the current task)
  • SHIFT when you insert a CD-ROM into the CD-ROM drive (Prevent the CD-ROM from automatically playing)
  • CTRL+SHIFT+ESC (Open Task Manager)
Dialog box keyboard shortcuts loadTOCNode(2, 'moreinformation'); If you press SHIFT+F8 in extended selection list boxes, you enable extended selection mode. In this mode, you can use an arrow key to move a cursor without changing the selection. You can press CTRL+SPACEBAR or SHIFT+SPACEBAR to adjust the selection. To cancel extended selection mode, press SHIFT+F8 again. Extended selection mode cancels itself when you move the focus to another control.
  • CTRL+TAB (Move forward through the tabs)
  • CTRL+SHIFT+TAB (Move backward through the tabs)
  • TAB (Move forward through the options)
  • SHIFT+TAB (Move backward through the options)
  • ALT+Underlined letter (Perform the corresponding command or select the corresponding option)
  • ENTER (Perform the command for the active option or button)
  • SPACEBAR (Select or clear the check box if the active option is a check box)
  • Arrow keys (Select a button if the active option is a group of option buttons)
  • F1 key (Display Help)
  • F4 key (Display the items in the active list)
  • BACKSPACE (Open a folder one level up if a folder is selected in the Save As or Open dialog box)
Microsoft natural keyboard shortcuts loadTOCNode(2, 'moreinformation');
  • Windows Logo (Display or hide the Start menu)
  • Windows Logo+BREAK (Display the System Properties dialog box)
  • Windows Logo+D (Display the desktop)
  • Windows Logo+M (Minimize all of the windows)
  • Windows Logo+SHIFT+M (Restore the minimized windows)
  • Windows Logo+E (Open My Computer)
  • Windows Logo+F (Search for a file or a folder)
  • CTRL+Windows Logo+F (Search for computers)
  • Windows Logo+F1 (Display Windows Help)
  • Windows Logo+ L (Lock the keyboard)
  • Windows Logo+R (Open the Run dialog box)
  • Windows Logo+U (Open Utility Manager)
Accessibility keyboard shortcuts loadTOCNode(2, 'moreinformation');
  • Right SHIFT for eight seconds (Switch FilterKeys either on or off)
  • Left ALT+left SHIFT+PRINT SCREEN (Switch High Contrast either on or off)
  • Left ALT+left SHIFT+NUM LOCK (Switch the MouseKeys either on or off)
  • SHIFT five times (Switch the StickyKeys either on or off)
  • NUM LOCK for five seconds (Switch the ToggleKeys either on or off)
  • Windows Logo +U (Open Utility Manager)
Windows Explorer keyboard shortcuts loadTOCNode(2, 'moreinformation');
  • END (Display the bottom of the active window)
  • HOME (Display the top of the active window)
  • NUM LOCK+Asterisk sign (*) (Display all of the subfolders that are under the selected folder)
  • NUM LOCK+Plus sign (+) (Display the contents of the selected folder)
  • NUM LOCK+Minus sign (-) (Collapse the selected folder)
  • LEFT ARROW (Collapse the current selection if it is expanded, or select the parent folder)
  • RIGHT ARROW (Display the current selection if it is collapsed, or select the first subfolder)
Shortcut keys for Character Map loadTOCNode(2, 'moreinformation'); After you double-click a character on the grid of characters, you can move through the grid by using the keyboard shortcuts:
  • RIGHT ARROW (Move to the right or to the beginning of the next line)
  • LEFT ARROW (Move to the left or to the end of the previous line)
  • UP ARROW (Move up one row)
  • DOWN ARROW (Move down one row)
  • PAGE UP (Move up one screen at a time)
  • PAGE DOWN (Move down one screen at a time)
  • HOME (Move to the beginning of the line)
  • END (Move to the end of the line)
  • CTRL+HOME (Move to the first character)
  • CTRL+END (Move to the last character)
  • SPACEBAR (Switch between Enlarged and Normal mode when a character is selected)
Microsoft Management Console (MMC) main window keyboard shortcuts loadTOCNode(2, 'moreinformation');
  • CTRL+O (Open a saved console)
  • CTRL+N (Open a new console)
  • CTRL+S (Save the open console)
  • CTRL+M (Add or remove a console item)
  • CTRL+W (Open a new window)
  • F5 key (Update the content of all console windows)
  • ALT+SPACEBAR (Display the MMC window menu)
  • ALT+F4 (Close the console)
  • ALT+A (Display the Action menu)
  • ALT+V (Display the View menu)
  • ALT+F (Display the File menu)
  • ALT+O (Display the Favorites menu)
MMC console window keyboard shortcuts loadTOCNode(2, 'moreinformation');
  • CTRL+P (Print the current page or active pane)
  • ALT+Minus sign (-) (Display the window menu for the active console window)
  • SHIFT+F10 (Display the Action shortcut menu for the selected item)
  • F1 key (Open the Help topic, if any, for the selected item)
  • CTRL+F10 (Maximize the active console window)
  • CTRL+F5 (Restore the active console window)
  • ALT+ENTER (Display the Properties dialog box, if any, for the selected item)
  • CTRL+F4 (Close the active console window. When a console has only one console window, this shortcut closes the console)
Mar 29, 2009 | Microsoft Basic Keyboard 1.0A PS/2 KEMIBA
Tip
General Keyboard shortcut
CTRL+C (Copy)
CTRL+X (Cut)
CTRL+V (Paste)
CTRL+Z (Undo)
DELETE (Delete)
CTRL+A (Select all)
Dialog Box Keyboard Shortcuts
Microsoft Natural Keyboard Shortcuts
Accessibility Keyboard Shortcuts
Windows Explorer Keyboard Shortcuts
Shortcut Keys for Character Map
Microsoft Management Console (MMC) Main Window Keyboard Shortcuts
MMC Console Window Keyboard Shortcuts
Remote Desktop Connection Navigation
CTRL+ALT+END (Open the Microsoft Windows NT Security dialog box)
ALT+PAGE UP (Switch between programs from left to right)
ALT+PAGE DOWN (Switch between programs from right to left)
ALT+INSERT (Cycle through the programs in most recently used order)
ALT+HOME (Display the Start menu)
CTRL+ALT+BREAK (Switch the client computer between a window and a full screen)
ALT+DELETE (Display the Windows menu)
CTRL+ALT+Minus sign (-) (Place a snapshot of the active window in the client on the Terminal server clipboard and provide the same functionality as pressing PRINT SCREEN on a local computer.)
CTRL+ALT+Plus sign (+) (Place a snapshot of the entire client window area on the Terminal server clipboard and provide the same functionality as pressing ALT+PRINT SCREEN on a local computer.)
Microsoft Internet Explorer Navigation
CTRL+B (Open the Organize Favorites dialog box)
CTRL+E (Open the Search bar)
CTRL+F (Start the Find utility)
CTRL+H (Open the History bar)
CTRL+I (Open the Favorites bar)
CTRL+L (Open the Open dialog box)
CTRL+N (Start another instance of the browser with the same Web address)
CTRL+O (Open the Open dialog box, the same as CTRL+L)
CTRL+P (Open the Print dialog box)
CTRL+R (Update the current Web page)
CTRL+W (Close the current window)
on Mar 10, 2010 | Computers & Internet
Tip
Windows keyboard shortcuts
CTRL + C = copy
CTRL + X = cut
CTRL + V = paste
Keyboard Shortcuts
explorer shortcuts
notepad = Notepad
wordpad = WordPad
calc = Calculator
internetbrowser
For Windows XP:
Copy. CTRL+C
Cut. CTRL+X
Paste. CTRL+V
Undo. CTRL+Z
Delete. DELETE
Select all. CTRL+A
To Press
Display Help. F1
on Dec 24, 2009 | Computers & Internet
Keyboard Shortcut for Windows
This is usually followed by: cmd = Command Prompt iexplore + "web address" = Internet Explorer compmgmt.msc = Computer Management dhcpmgmt.msc = DHCP Management dnsmgmt.msc = DNS Management services.msc = Services eventvwr = Event Viewer dsa.msc = Active Directory Users and Computers dssite.msc = Active Directory Sites and Services Windows key + E = Explorer
CTRL + C = copy
CTRL + X = cut
CTRL + V = paste
Keyboard Shortcuts
explorer shortcuts
devmgmt.msc = Device Manager msinfo32 = System Information cleanmgr = Disk Cleanup ntbackup = Backup or Restore Wizard (Windows Backup Utility) mmc = Microsoft Management Console excel = Microsoft Excel (If Installed) msaccess = Microsoft Access (If Installed) powerpnt = Microsoft PowerPoint (If Installed) winword = Microsoft Word (If Installed) frontpg = Microsoft FrontPage (If Installed) notepad = Notepad wordpad = WordPad calc = Calculator msmsgs = Windows Messenger mspaint = Microsoft Paint wmplayer = Windows Media Player rstrui = System Restore netscp6 = Netscape 6.x netscp = Netscape 7.x netscape = Netscape 4.x waol = America Online control = Opens the Control Panel control printers = Opens the Printers Dialog
internetbrowser
type in u're adress "google", then press [Right CTRL] and [Enter] add www. and .com to word and go to it
For Windows XP:
Copy. CTRL+C Cut. CTRL+X Paste. CTRL+V Undo. CTRL+Z Delete. DELETE Delete selected item permanently without placing the item in the Recycle Bin. SHIFT+DELETE Copy selected item. CTRL while dragging an item Create shortcut to selected item. CTRL+SHIFT while dragging an item Rename selected item. F2 Move the insertion point to the beginning of the next word. CTRL+RIGHT ARROW Move the insertion point to the beginning of the previous word. CTRL+LEFT ARROW Move the insertion point to the beginning of the next paragraph. CTRL+DOWN ARROW Move the insertion point to the beginning of the previous paragraph. CTRL+UP ARROW Highlight a block of text. CTRL+SHIFT with any of the arrow keys Select more than one item in a window or on the desktop, or select text within a document. SHIFT with any of the arrow keys Select all. CTRL+A Search for a file or folder. F3 View properties for the selected item. ALT+ENTER Close the active item, or quit the active program. ALT+F4 Opens the shortcut menu for the active window. ALT+SPACEBAR Close the active document in programs that allow you to have multiple documents open simultaneously. CTRL+F4 Switch between open items. ALT+TAB Cycle through items in the order they were opened. ALT+ESC Cycle through screen elements in a window or on the desktop. F6 Display the Address bar list in My Computer or Windows Explorer. F4 Display the shortcut menu for the selected item. SHIFT+F10 Display the System menu for the active window. ALT+SPACEBAR Display the Start menu. CTRL+ESC Display the corresponding menu. ALT+Underlined letter in a menu name Carry out the corresponding command. Underlined letter in a command name on an open menu Activate the menu bar in the active program. F10 Open the next menu to the right, or open a submenu. RIGHT ARROW Open the next menu to the left, or close a submenu. LEFT ARROW Refresh the active window. F5 View the folder one level up in My Computer or Windows Explorer. BACKSPACE Cancel the current task. ESC SHIFT when you insert a CD into the CD-ROM drive Prevent the CD from automatically playing.
To Press Move forward through tabs. CTRL+TAB Move backward through tabs. CTRL+SHIFT+TAB Move forward through options. TAB Move backward through options. SHIFT+TAB Carry out the corresponding command or select the corresponding option. ALT+Underlined letter Carry out the command for the active option or button. ENTER Select or clear the check box if the active option is a check box. SPACEBAR Select a button if the active option is a group of option buttons. Arrow keys Display Help. F1 Display the items in the active list. F4 Open a folder one level up if a folder is selected in the Save As or Open dialog box. BACKSPACE
Display or hide the Start menu. WIN Key Display the System Properties dialog box. WIN Key+BREAK Show the desktop. WIN Key+D Minimize all windows. WIN Key+M Restores minimized windows. WIN Key+Shift+M Open My Computer. WIN Key+E Search for a file or folder. WIN Key+F Search for computers. CTRL+WIN Key+F Display Windows Help. WIN Key+F1 Lock your computer if you are connected to a network domain, or switch users if you are not connected to a network domain. WIN Key+ L Open the Run dialog box. WIN Key+R Open Utility Manager. WIN Key+U
Oct 19, 2008 | Computers & Internet
Usage of keyboard
right click in keyboard. you can find in the space bar line "
from left;
CTRl, logo windows, Alt,space bar,Alt,Logo windows,right clickkey,Ctrl.
You can identify right click key cause there's an arrow pointer on it.
Jan 14, 2008 | Intel Dot Station (INTC300AIO) PC Desktop
Tip
General Keyboard Shortcuts, General Keyboard Shortcuts General Keyboard...
CTRL+C (Copy)
CTRL+X (Cut)
CTRL+V (Paste)
CTRL+Z (Undo)
DELETE (Delete)
CTRL+A (Select all)
on Apr 12, 2009 | Microsoft Windows XP Professional
ASUS F5RL-X1 Notebook Logo
140 people viewed this question
Top ASUS Computers & Internet Experts
Alun Cox
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
