Question about Toshiba 2060 Copier
Leaving a black line at the top of the page
I have a Toshiba 2060 copy machine and it is leaving a black line at the top of the page when it copys.
  • John Harris May 11, 2010
    does it do it when you make a copy off the glass? Or when you use the document feeder?
  • 92 Answers
Make sure paper guides are secure other then that could b dirty optics (mirrors under the glass) or drum / fusing unit
Posted on Jun 28, 2009
Leaves black marks on copies
It could be leaking toner from the recovery area that sis on top of the dum, it removes any toner that was not transfered to the paper. You would have to remove it and empty out the toner.
Dec 11, 2012 | Toshiba e-Studio 232 Black and White...
Our Toshiba e-studio 352 is leaving a black line down the front of pages that are printed. what is the problem?
If u copy through feeder, then probably is the scanning mirror dirty. If u encounter this problem when printing from pc, then probably is process unit or t/s block problem.
Jun 04, 2010 | Toshiba e-Studio 350 Copier
Our Toshiba e-studio250 copy machine is leaving a
i think you machine lost scuner home positin try to adjust the scuner
Mar 25, 2010 | Toshiba e-Studio 350 Copier
I have black strip running top to bottom of copy. Machine has 65,520 copies on the counter
What type of copier? A professional grade or SOHO AIO? Check the glass where the copies take place, including where ADF copies, make sure there are no debris. If you can look to see if there are any debris or faults in the scanner assembly. If that's ok it could be many things. If it is a higher end copier it could be as simple as dirty corona wires or as bad as a worn drum.
Dec 18, 2009 | Toshiba 2060 Copier
Leaving a wide black line in right hand side of transaction
Pop open the fax document feeder, and look for a glass strip about 1cm wide, that runs from left to right across the machine.
You will probably see a few spots of dirt, or more commonly, a blob of white liquid paper stuck on the glass, on the side of the machine that corresponds to the black lines on your fax.
Clean this glass strip gently, using a soft cloth dampened with a mild detergent. I often use diluted windex. You may need to scrape liquid paper gently with your fingernail. Close the cover.
Next, put a blank sheet into the feeder and make a copy of the blank page. If you have cleaned it properly, the copy will be blank as well. If you still have a line, align it with the feeder and use this as a guide to show you where the glass may still have some **** stuck on it.
Dec 04, 2009 | Brother IntelliFAX 4100 Laser Fax
Black line at top of copies
You could have a scratch on your drum. If you take a look at it inside the machine, see if it appears on the drum.
Jul 31, 2008 | Toshiba 2060 Copier
Top Feeder scanner leaves a line along the copy
This Is good for all "all in one machines"
There is a dot on the 1inch glass, when making a copy or faxing or scanning it makes it form that part of the glass. It shows as a line because the paper is moving as it is being scanned. clean the glass w/ alcohool. Sometimes it is hard to see because the background is black and the dot may be a pen or pencil, but it's there.
try to take the copy and lign it up w the glass and look where the line is you might see it htere.
Oct 10, 2007 | HP LaserJet 3055 All-In-One Printer
367 people viewed this question
Top Toshiba Office Equipment & Supplies Experts
didi2005
jasbo
jasbo
Branko Djurdjevic
Branko Djurdjevic
Are you a Toshiba Office Equipment and Supply Expert? Answer questions, earn points and help others
