Question about AOpen F2705 17" LCD Monitor
My LCD show me "Out of range" when it is loading the windows. I need the driver. Thanks.
  • May 11, 2010
    Once Windows is done loading, does the message go away and the screen come up normally?
  • 37 Answers
Hello. In most Windows PCs today, there is not a big need for LCD Drivers, since most LCDs have a native resolution which the Operating System can support natively.
The Out of Range issue appears when your resolution is set too high for the LCD Screen to properly handle. As the result, you need to lower the screen resolution within the operating system. However since you cannot see the screen, there is no easy way to do that. VNC would allow you to so, but it is not easy to install remotely, unless on a local network domain environment.
The easier way is to use another LCD Screen which will support the currently set resolution so that you can adjust the resolution to the screen you are trying to use.
Old CRT monitors are great, because they are not prone to Out of range issues. If you have one lying around I would recommend utilizing it to change the Operating System resolution, to the native resolution that your LCD Screen is for.
Try google searching your LCD Specifications to find the native resolution and set your OS to use that. Any higher will create Out of Range issues, and any lower and your screen wont look as crisp and clear as it could with the native resolution.
Posted on Feb 26, 2009
  • 203 Answers
You will nee to find out the frequency range of your flatscreen whick should be in the book that came with it. Also, try pressing f8 and see if u can see the menu that comes up, if u can see it then select safemode and see if it will boot like that. If so, install the correct driver for the flatscreen.
your drivers are at this link.
Fujitsu siemens scenicview b19-3
hi you must disable the main screen in properties section of the display panel then when you start up the computer the screen will not activate until windows has loaded and found and installed the screen drivers after that all should be good to go if you need any further help don't hesitate to contact me :)
Feb 07, 2013 | Fujitsu Siemens Premium Line P19-1 19" LCD...
I am in charge of a computer account here at work and have about 15 ACER 1916B monitors that are all inop...The monitors power up and show the ACER startup then show the windows startup to only go...
This problem is caused by 2 things, the computer is set to a higher resolution that the monitors can handle, so when the graphics card drivers kick in as windows boots the screen goes blank, this is normally the problem for people trying to hook there computers to normal lcd televisions not monitors, as monitors generally are able to show higher resalutions.
In your case because you are using computer monitors, the problem will be caused by the refresh rate settings on the windows, most desktop lcd monitors have a fixed refresh rate of 60hz, my guess is your computers are set as 75hz therefore as windows boots the screen goes blank because it dosent support that high a refresh rate.
To resolve this problem, just before windows boots press F8 on the keyboard, this should bring up a black command prompt screen, at the top you will see the safemood option, tab up to it and press enter, this goes to windows but dosent load any drivers including the graphics driver. Once loaded right click the mouse in the middle of the screen, and bring the display properties window up, in this window click on the settings tab, click on advanced on the bottem right of the window, this will bring up another window, click on the monitor tab, on this window you will see the screen refresh rste setting, click the small arrow and set this to 60hz and click ok, in the other window reduce the resalution down abit using the slider, click apply and close the window, then reboot the mechine as normal, the problem should now be sorted, any problems post me back. thanks and hope this helped.
Sep 22, 2010 | Acer AL1916W 19" LCD Monitor
AKAI LCT3285TA 32 inch LCD not compatible with Wni 7 video driver
try to right click on the driver and search for Program Compatibility Troubleshooter or the properties where you can run the program in compatibility mode in other os version
Jun 02, 2017 | Akai LCT3285TA 32 in. LCD Television
Dialogue box in the middle of the screen
Out of range usually means that the computer is trying to use a resolution that is unsupported by the monitor. Try loading the PC in safe mode (for windows, press F8 before windows loads) and change the desktop resolution to 800x600, which is supported by pretty much any monitor. Restart the computer normally and you should get your video. Once inside windows you can experiment with different resolutions, and when it goes out of range, just wait 15 seconds for it to go back to 800x600.
May 15, 2009 | Microtek 710S 17" Flat Panel LCD Monitor
Vison Monitor ( device installer error)
First you need to uninstall the driver for your old monitor. Then install the driver for the new monitor. With both drivers installed your computer is confused and shows the conflict as an error message. Hope this helps.
Dec 23, 2008 | Computers & Internet
BenQ Monitor ' Out Of Range '
check your resolution settings and change to 800><600 and try again.If it does not work at 1024><768 try loading monitor driver In display properties it should show BenQ FP731 instead of plug and play monitor.
Oct 29, 2008 | BenQ FP731 17" LCD Monitor
Analog Out Of range (LG Flatron L1750T)
some games need high resolution. Monitor resolution not supporting for this game.
Powersaver mode showing when the main PCB of the monitor failed. check this link to get the service center info
Nov 21, 2007 | LG Flatron L1750S 17" LCD Monitor
Monitor out of range
Most commonly, this problem is caused by an incorrect refresh rate setting. LCD monitors typically DO NOT support refresh rates higher than 60hz - and this is no exception. Try running the game in "safe mode" if it has one. Adjusting the in-game video settings should solve the problem, just look for a screen refresh rate or any video-related setting with a number followed by "hz". Set it to 60, everything should be fine.
It could also be that at some point the game changes resolution (this frequently occurs if there is an in-game movie or cut-scene). In this case the resolution settings for the in-game movie might be at fault, check them if you can.
Sep 23, 2007 | Computers & Internet
AOpen F2705 17" LCD Monitor Logo
303 people viewed this question
Top AOpen Computers & Internet Experts
Michael Galve
Michael Galve
Alun Cox
Are you an AOpen Computer and Internet Expert? Answer questions, earn points and help others
