Question about Canon PIXMA MP470 All-in-One Printer
Printing in black only
I'm trying to figure out how to have my printer only print in black. Regardless of what application I am printing from, it still prints in all color, and I need just to see the images I'm printing in black. Any thoughts?
  • housecoatinc Feb 26, 2009
    No, it's not that anything is blocked, it's more of a settings issue.  I'm trying to have my printer only print in black.  Both ink cartridges are working, I'm just trying to print something in color, in black only.
  • 203 Answers
You may have a blocked cartridge. try running a cleaning cycle then a test print.
Posted on Feb 26, 2009
  • sean sutton
    sean sutton Feb 26, 2009
    1. Open the printer driver setup window, and check the Monochrome Effects check box on the Effects tab.
    2. Select your desired color from Sepia, Blue, Pink, Green, or the color selected using Select Color.
    If you use Select Color, move the Color slider to specify the color you want.
    The current settings are displayed in the Settings Preview on the left side of the printer driver.
    3. Click OK. The image will be printed with a single color.
Lexmark pro 900 will not print color
Try to check your printing preferences if it's set to print using all available ink or check if it's set to print in black and white. To do that, on the application that you're printing from, click on File > Print > Preferences/Properties.
Also, make sure that the firmware of your printer is up to date. Just go to http://bit.ly/ghfW8H to download the firmware update.
Jan 30, 2013 | Lexmark Office Equipment & Supplies
Canon Pixma 5100, no black ink, but blue won't print? why?
Main Cartridge is black it is required for printing it is not possible to print black with other cartridge.
Jan 02, 2013 | Office Equipment & Supplies
It wont let me print in black when the color ink is out
When this printer estimates a cartridge is empty it will indeed stop printing and ask for a promt from you. I believe your particular printer will ask you to hold down RESUME for 5 seconds to continue printing. The resume/stop/reset button will be marked with the symbol below. Once this prompt has been given printing will continue regardless of the estimate.
More information and a short video can be found here.
Nov 06, 2012 | Canon MP490 InkJet Printer
I am trying to print something in color using my canon pixma mp640. i have made sure all of my ink levels are good and that my setting on both the computer and printer are set to color. but it is only...
If you are certain that your printer online properties indicates color printing and you can get 'test print' in color (via Printer properties or Printer built-in menu), I would first check that your application is not overriding the default settings (e.g. such as proof/draft mode printing in mono or B&W) or try another application.
If no applications won't print in colors, I would try to re-install the Printer Drivers specific to your windows version.
Sep 21, 2011 | Canon Office Equipment & Supplies
I want to print in black and white, but i have no colour ink and it still won't let me print?
The Kodak printer is tricky ...if you went through some of the steps to download a printing utility to fix any printing error..... then the problem is the fact that you do not have color ink that's the trick with the Kodak printer...it's 30 bucks for a pack of Kodak black and color ink package...trust me ...lol...I had a client that had the same problem.... both ink needs to be above parr in order to print ...
Apr 06, 2011 | Kodak ESP 3 Multifunction Printer/ Copier/...
Printer not primtimg black ink
I sounds that the black printhead inside your printer is clogged. Please try head cleaning on the printer. Regardless of what brand name you using you can actually check it on your computer. Check on the example below:
click on start / settings / printers & faxes then right click on the printer icon left click on printing preferences
Click on maintenance tab and you will see cleaning button
Oct 15, 2008 | Epson Stylus CX3200 All-In-One InkJet...
Printing black and white photos from digitally taken colour photos
Hi Pat,
First you will have to check the Nozzle of your printer. To do this, press the setup button and select Nozzle Check. Use a plain paper to do this. Press Ok after that. It will print out a pattern for each color. Make sure that the lines are connected to each other specially for black since that you are printing a black and white photo. Lines going across is on a stair case pattern and should be connected to each other. Proceed with cleaning cycle if needed.
You can do a cleaning cycle using your printer of the computer. You can skip this if you have a good Nozzle check.
Using printer:
Press setup then select head cleaning.
Using computer.
Go to utility of the printer and find maintenance. Click on the head cleaning button.
Once that the nozzle are fine, you can now try printing. I strongly suggest that you use other application first instead of Adobe Photoshop. Since that Photoshop uses color management, it can be that the settings are incorrect. Save first the picture that you opened in Photoshop. You can save it on your desktop to easily locate the file. Make sure that the file is in jpeg format. Now to isolate the issue if it is cause by a software or not, try the standard application for your O.S.
Smaple Application:
Windows O.S. : Windows Picture and Fa Viewer
- right click on the file and select open with.
- select windows picture and fax viewer.
- folow the on screen instuctions.
Note: If you are now on the window on what pinter to use. Make sure that you set the option for printers under preferences to print in gray scale or black only. Select also the correct paper type.
- Proceed with printing.
Mac OSX: Preview or Iphoto
- open the picture under one of the application.
- click file then print.
- Make sure printer is selected.
- underneath the print option, you will have to go to print setting.
- find the option that says color then select black.
- select the appropriate settings for paper.
- the click on print.
Now see if it did print out corectly. If it did, it means that the appplication is the one causing this. If you are familiar with the color manage features of the application Photoshop. Let Photoshop handles the color. After getting to the widow what printer to use, to the the preferences of the printer and select the correct paper type. You will have to find the color management of the printer.
For Windows, It under the advance option under the main tab. Select off no color adjustment.
For Mac instead of going to print setting, find color manage and turn it off. Select off no color adjustment.
Then try printing.
Regarding your other question, If the printer is producing excess inks on your print out when ot comes to black printing and color printing, that pad needs replacement.
Aug 15, 2008 | Epson Stylus Photo RX700 All-In-One InkJet...
I am trying to print from a HP Deskjet F380, when I click print a msg saying Printing of jobs is stopped would you like to continue and restart the printing of jobs? I click Continue and a red...
1) Remove your printer from the USB port.
2) Uninstall the printer from Add/Remove Programs in the control panel.
3) Reboot
4) Download and install the latest drivers from HP's website.
You should be good to go.
Jul 16, 2008 | Computers & Internet
Epson Stylus CX5400 prints bands of color
directly hooking the printer to mac and windows computer are you getting bandings still? interesting issue... we will isolate it first by trying to hook printer directly to both computer, if its printing fine when directly connected, then there is something on the application or communication process. try printing a different document using same application when on the network and try printing from different application as well. update me afterwards..
Apr 03, 2008 | Epson Stylus CX5400 All-In-One InkJet...
Won't print docs in black ink
The application that you use to print may have been cofigured to avoid the black color.
And sometimes a virus has affetced your application e.g. MS Word.... this may cause the printer to print in any colour.
In this case you should reinstall the application. (first completely remove the application).
Mar 18, 2007 | HP PSC 2355 All-In-One InkJet Printer
Canon PIXMA MP470 All-in-One Printer Logo
59 people viewed this question
old marine
old marine
Corne Viljoen
