Question about Amana NDE2335AY Electric Dryer
How do i remove tumbler on admiral lnc7757a71 dryer ?
Where can i find repair manual on-line ?
  • ajb32a Feb 27, 2009
    thanks for info. i can get apart but need manual for part numbers. repair parts sites i have checked do not recognize model LNC7757A71 (1998 Mont Ward unit). any help here ??
  • 686 Answers
At the bottom on the front panel there might be a couple screws if so take them out and lift to hunhinge from the top b careful you have door switch wires to undo. If no screws then pry the top off with a wide flat standard screw driver then look inside front panel towards top should be more screws take them out and front should pull out slightly and lift off of the bottom latches or hook so to speak. Good Luck
Posted on Feb 27, 2009
  • James Chandler Mar 01, 2009
    If you have an appliance store where you live, just take your info and the old part to them they should be able to help you. Manuals are rarely available for older models and for the purpose of having to have to go to someone else. Go to www.repairclinic.com enter your model # and you'll find the parts
    too old of a dryer and montgomery i think is no longer in the dryer business. that was way back in the day
Tumbler belt came off
  • Unplug your dryer from the electrical outlet. Remove the lint trap by lifting its cover and sliding it out. Use a screwdriver to unscrew the two screws that hold in the housing of the lint trap.Lift up the top panel of the dryer and take off the holder for the door switch wire. Look for the screws that hold in the front panel of the dryer, located on top of the front panel, and unscrew them. Take the panel off the dryer by lifting it off.Look inside the dryer, find the broken dryer belt, and before taking it off, note the way it is routed around the pulleys, then take it off. Install a new Whirlpool dryer belt by slipping it around the tumbler with the grooves facing the surface of the tumbler. Ask an assistant to hold up the tumbler while you move the belt into the proper place, aligned with the black line around the width of the tumbler.Wrap the new dryer belt around the pulleys as noted in Step 3. If you don't remember how, or the old belt was snapped and not aligned properly, look at the dryer belt diagram in your user's manual.Align the front panel of the dryer with the tumbler. Put back in the two screws that hold the panel in place. Open the door of your dryer and with your hand, turn the spinner one time counterclockwise. Reconnect the holder for the door switch wire, being careful that it doesn't touch any moving parts.Use the screwdriver to carefully position the rubber seal along the back of the tumbler. Make sure the seal is on the outside of the tumbler and that none of it sticks to the inside of the tumbler.Slide the lint filter and housing back into place, and screw in the two screws that hold it in. Plug the cord of the dryer back into the electrical outlet and check that it spins properly.
  • Oct 11, 2010 | Whirlpool Dryers
    My admiral dryer is not drying as it should - troubleshooting advice?
    I love an admiral dryer. Simply a beautiful machine. They do have a few basic problems but whos doesn't. One of the main problems has to do with the 53-0106 plastic blower. It has a flat side to it to keep the blower from slipping but the heat wallers out the hub abd the blower spins. This results in improper air flow. The dryer takes twice as long to dry clothes and gets real hot on top because of poor air circulation. Also a hole could get in the filter and cause lint to build in the filter housing. The lint combined with the loos blower wheel makes a huge ball of lint form in front of the blower. I have some repair photos for various maytag dryers old and new and diff styles showing how to get inside and check all this stuff out. Remove power and clean out the vent to outside also and this sweet little admiral will be all kosher again. Repair photos and stuff: HERE
    I have other brands HERE
    You say you have an admiral but ler5636p is a whirlpool dryer, anywho I have posted the repair pix for whirlpool HERE
    Jan 18, 2010 | Whirlpool LER5636P Electric Dryer
    Dryer hums but won't tumble. I can manually turn
    most likely motor will need to be replaced if you do repair try to remove blower wheel first you will need a 1/2" rachet and a 7/8 for the motor to hold motor in place you may need to replace also they will lock together some times
    Sep 26, 2009 | Kenmore Dryers
    Dryer will not work. Makes buzzing sound when
    locked up dryer motor,replace-mike
    Jul 17, 2009 | Dryers
    Dryer belt
    here is a link where you can see a pic and tell you how to put it on
    http://www.repair-help.com/kb/index.php?article=105
    Jan 08, 2009 | Dryers
    Dryer stumbles to get started spinning
    probably need the wheels and idler inspected
    Dec 31, 2008 | Amana NDE2335AY Electric Dryer
    Admiral Designer Series
    http://www.repairclinic.com/SmartSearch/SSPartDetail.aspx?PartID=1737&PPStack=1
    Nov 21, 2008 | Dryers
    Put belt on dryerg
    While I don't know about your specific dryer, most dryers are set up the same. I just replaced the belt on my Maytag LDE8404ACE. It was easy. The hard part was cleaning out 14 years worth of lint and fuzz that coated everything inside. Here's the instructions:
    1. Unplug the dryer or disconnect power.
    2. Remove the front panel. There are two screws, each is about 4 inches up from the bottom of the front panel. Unscrew them. Then hold the front panel along the bottom edge and pull it away from the dryer. Once it's away enough, the clamps along the top will pop and disengage from the dryer. Be sure to note the wires connected to the door switch are connected to the dryer. Disconnect them if you need to move the panel away from the dryer.
    3. With the front panel off, you should be able to reach inside the dryer to remove the old, broken belt.
    4. Remove the tumbler from the dryer. It's held in place by the tumbler front which is secured by 4 screws, 2 on each side. That piece will pull straight out toward you. With the tumbler front out of the way, the tumbler itself will come straight out as well. I recommend taking it out and cleaning the inside of your dryer while it's open. A vacuum hose works great. Also, check the pulley and the back two wheels that the tumbler rests on to make sure they turn easily. If not, you may want to grease them. Also, it's normal for the idler pulley to appear to be loose and wiggle in place. Once a new belt is installed, it's under tension from the spring so any play that exists shouldn't be a problem.
    5. put the new belt around the tumbler with the smooth side of the belt against the tumbler. Use the old belt marks on the tumbler to align the new belt. It's easier to hook the belt to the idler pulley and motor pulley from the back. So we'll get to that part in a minute. Just let the belt hang loose for now.
    6. Reinstall the tumbler front and secure with the 4 screws you removed earlier.
    7. Reconnect the wires to the door switch, if you removed them earlier.
    8. Reinstall the front panel, reversing the steps you took to remove it in #2 above.
    9. Go to the back of the dryer and remove the access panel along the bottom right hand side.
    10. From there, reach in pull the dryer belt around the idler pulley. Then take the belt on the left side of the pulley and move both the belt and the idler pulley to the right, until you can get the grooved side of the belt onto the motor pulley. I've attached a diagram with instructions.
    11. Once connected, manually turn the tumbler so that the belt will align and make sure the tumbler turns as easily as it did when you first removed it.
    12. If the belt looks good and you've manually turned the tumbler at least one full revolution (to ensure the belt didn't get twisted), then plug the dryer in and turn it on to make sure it works correctly. If so, then re-attach the access panel on the back of the dryer. You're done!
    Nov 16, 2008 | Whirlpool LER5636P Electric Dryer
    Frigidaire Dryer
    If Dryer does not tumble , check the following:
    " It won't tumble If your dryer doesn't tumble, check these:
    Belt
    Motor
    Door switch
    Belt Dryers have a drive belt that turns the clothes drum. If the belt breaks, the drum stops rotating. Then you need to replace the belt, and often the idler pulley, because the pulley tends to wear out at the same time.
    Click here for a belt installation diagram.
    Motor If the dryer motor only hums when you press the Start button, the motor may be burned out. Here's how to test the dryer motor:
    • Remove the belt.
    • Check for obstructions in the blower fan housing.
    • Manually rotate the shaft of the motor.
    If the motor is very stiff, or impossible to rotate manually, and the blower fan housing is clear, you need to replace the motor.
    If the motor rotates freely, run the motor momentarily with the belt removed and the blower in place. If the motor runs fine with the belt removed, there may be a problem with the idler pulley or the clothes drum. Try to rotate the drum by hand. If it is very difficult to move, correct any problem with the rollers or pulley, and then reassemble the dryer and try it again.
    If the motor hums but doesn't rotate on its own even with the belt removed--yet you can turn it freely by hand--you usually need to replace the motor or the motor start capacitor.
    Door switch Your dryer can't operate at all if the door switch is defective. It's inside the dryer main housing near the door frame. Sometimes you need to raise or open the top or front of the dryer to reach the switch. If it's defective, you need to replace it."Source Repaiclinic
    Sep 08, 2008 | Frigidaire GLER642A Electric Dryer
    Broken belt that turns the drum
    12. If the belt looks good and you've manually turned the tumbler at least one full revolution (to ensure the belt didn't get twisted), then plug the dryer in and turn it on to make sure it works correctly. If so, then re-attach the access panel on the back of the dryer. You're done!0798e0b.jpg
    Aug 17, 2008 | Maytag PYG2300A Gas Dryer
    Amana NDE2335AY Electric Dryer Logo
    516 people viewed this question
    Top Amana Dryers Experts
    Dan Webster
    Dan Webster
    Tim Whalen
    Are you an Amana Dryer Expert? Answer questions, earn points and help others
