Question about Panasonic Toughbook CF-27 Notebook
Wont load windows after loading antivirus
Wont load windows after installing. wants setup now
Click refresh
Posted on Feb 26, 2009
Blue screen wont load windows
It might be due to following issues:
Hardware failure
Bad driver
Corrupt file or volume
System misconfiguration
Virus infection
To load windows you need to login via Safe Mode and try these techniques:
Scan your computer with an antivirus
Apply De-fragmentation on your system
Delete all temporary files
Run disc clean up
Fix registry errors
For an instant fix download and install PCFresher to fix this issue instantly.
Apr 23, 2013 | Computers & Internet
I want to install windows xp on dell inspiron mini 1018 but i am not able to install.some blue screen comes.please help
turn off your antivirus before you try to revert back to xp. your system antivirus might see this as an attack on your windows 7,thus it won't allow you to install a different system.
Feb 25, 2012 | Dell Inspiron Mini 10 Netbook
What to do,computer is full of viruses wont let me in anywhere,system locked up,
In cases like this, you have no alternative but to format the hard disk and install Windows again.
You need your Windows installation CD and product installation code. After installing Windows and the Service packs, plus the computer's device drivers, then activate Windows, and install your programs.
Dec 14, 2010 | Computers & Internet
Windows wont load
If the windows wont load then it is corrupted.
If you have a Windows CD Installer then run this and repair the operating system.
In order to run your cd installer, you will need to set on the cmos that cd rom is the first booting device.
Reboot your pc and hit any key to run the windows setup.. When prompted, press F8 to accept the agreement.
On the process of selecting previous windows operating system... select repair by pressing "R"
then continue the setup. You will also be asked to input serial key so be prepared to have it.
Good luck
Much appreciated if you could rate this help...thanks!!
May 20, 2010 | Gateway Solo 9550 Notebook
Wont start up
In safe mode
Go to start / run / type in msconfig / enter, click on blind that says startup / select all programmes EXCEPT your antivirus and any others you want but keep it basically at only the antivirus. Restart PC as requested, when it reboots a box with explaination of what you have just done will appear, TICK that box in lower left. Should fix problem. By ticking nearly all the apps will not affect the way the pc runs but will startup much faster, If you want to enable a startup rpogramme ie google toolbar, simply go back into msconfig, find it and tick box.
If still no go you probably have a registry error.
Dec 03, 2009 | Acer Aspire 3000 Notebook
My Phillips web cam doesnt work anymore. BTW I have a Japanese Windows XP When trying to load my driver the it loads up to about 44 percent and then stops. install shield wizard says component transfer...
Good day sir/maam, if the driver does't finish loading, means that the CD or the CD drive is the culprit. try to use the CD on another PC. copy the files to a flash drive (just make sure you get a good copy). then bring the copy to your PC. load the driver again.
If still wont load. problem with the XP, reinstall your XP again. scan your files with antivirus and also all your flash drives. Reinstall your driver. just make sure your PC is virus free.
Oct 08, 2009 | Computers & Internet
Xp wont load
go to BIOS setup check that sata is recognized also if you have an ide drive in computer it may not find the one to use I had to remove ide drive for windows to install
Aug 09, 2008 | EliteGroup ECS GeForce6100SM-M (1.0)...
How to install sound drivers
in safe mode windows uses minimum drivers to load. It just load that drivers that are neccessary to boot. so you can't see many drivers in safe mode.
If you find that your system is infected by virus, then you should run an antivirus. Or if you have all the setups of required software and drivers, you can make format and re-install.
thanks
iqbal
Mar 25, 2008 | Intel Motherboard
Installing photo express
Knight, as i have understood when you reinstall windows XP, it can't load photo express. This is probably because you had installed Photo express in your the same drive you had installed your windows. When you reinstall windows that drive is completely formatted and thats why it can't load the software.
Make sure you install photo express in some other drive. You can also rip the setup on a dvd so that you could reinstall it when your window crashes. For window crash, you might like to use an antivirus software like Avast.
I hope that must solve your problem. You might also like to read Photo express manual for specific instructions if it doesnt work.
Nov 22, 2007 | Adobe Photoshop 7.0 for PC
My PC will not boot but only displays "press F2 to enter bios setup"
Go to BIOS and go to LOAD SETUP DEFAULT OR LOAD OPTIMIZED DEFAULT -YESS- AND RESTART
Oct 11, 2007 | AMD (90613) PC Desktop
Panasonic Toughbook CF-27 Notebook Logo
70 people viewed this question
Top Panasonic Computers & Internet Experts
Oloyede Monsuru
micky dee
Are you a Panasonic Computer and Internet Expert? Answer questions, earn points and help others
