Question about Bagatrix Algebra Solved! 2005 (105101) for PC
3x + y = 0
Solve the equation answer in fractions.
  • rockfixya
    rockfixya May 11, 2010
    explain your problem.
3x+y=
Posted on Mar 10, 2009
    Genius:
  • 1,550 Answers
The possible solutions are
x= -y/3
y= -3x/1
Posted on Feb 26, 2009
Im trying to solve the equation 5x=10-3x
5x (-3x) = 2x -3x - -3x = 0
The equation then becomes 2x=10 2x/2 = x and 10/2 =5
then x=5. does it work 5x5=10+3*5 YES
Jan 20, 2017 | The Office Equipment & Supplies
Chacha answers
It seems to me that you are trying to solve the quadratic equation
aX^2+bX+c=10 with a=-3, b=3, c=15 or -3X^2+3X+15=0.
Since the all the coefficients are multiples of 3, one can simplify the equation by dividing every thing by 3, leaving -X^2+X+5=0. But to avoid confusing you I will consider the original equation -3X^2+3X+15=0..
You must first find out if the equation has any real solutions. To do that you calculate the discriminant (you do not have to remember the name if you choose to).
Discriminant is usually represented by the Greek letter DELTA (a triangle)
DELTA =b^2-4*a*c =(3)^2-4*(-3)*(15)=189
If the discriminant is positive (your case) the equation has two real solutions which are given by
Solution1 =X_1=(-3-SQRT(189))/(-2*3)=(1+SQRT(21))/2
Solution2 =X_2=(-3+SQRT(189))/(-2*3)=(1-SQRT(21))/2 or about -1.791287847
Here SQRT stands for square root.
Aug 17, 2014 | Computers & Internet
Chacha answers
Aug 17, 2014 | SoftMath Algebrator - Algebra Homework...
3x+6y=90 what is the y and x intercepts
By definition, the y-intercept is the value of y when x=0. Just set x=0 in the equation and solve for y.
Hence 3(0)+6y=90 or 6y=90. This gives y=90/6=15. The point of intercept of the y-axis is (0,15).
To get the x-intercept, set y= 0 in the equation and solve for x.
3x+6(0)=90 or 3x=90. This gives x=90/3=30.
The point of intercept of the x-axis is (30,0).
Jan 20, 2012 | SoftMath Algebrator - Algebra Homework...
Find the y and x intercept of this equation 3x-6y=-21
To get the y-intercept of a line you set x=0. So 3(0)-6y=-21. Solve for y: y=(-21/-6)=7/2.
For the x-intercept, set y=0 in the definition of the function, then you solve for x.
3x-6(0)=-21. or 3x=-21 and x= -21/3=-7
Oct 31, 2011 | MathRescue Word Problems Of Algebra Lite
2x2-3x+5=0 solving the quadratic equation
Here you are :
2X2-3x+5=0 => 4-3x+5=0; (2X2=4) => -3x+9=0; (4+5=9) => 9 = 3x; (-3x moved to the right-hand side and it became 3x) => 9/3=x; (3 moved to the right hand side, so it becomes 1/3, i.e 1/3X9= 9/3) i.e. x=9/3 => x=3
Hence x equals to 3.
You can add or remove the explanation/description, I simply add them to make you understand.
If you need help, let me know.
Good luck.
Thanks for using FixYa.
Oct 08, 2010 | Computers & Internet
How do I solve a polynomial equation: x^4+5x^3-3x^2-43x-60 on a TI-83 plus graphing calculator?
Sorry, but what you wrote is not an equation but a polynomial expression. You want to solve the equation x^4+5x^3-3x^2-43x-60 =0.
The solve( command, can only be used with real numbers.
The solve( is available through the CATALOG : [2nd][CATALOG], scroll down till you reach the command. Highlight it and press [ENTER]. The command echodes on main screen as solve( .
You complete the command by entering the expression (not the equation), the name of the variable you solve for, the initial guess , and { lower limit, upper limit} between curly brackets, and the closing parenthesis.
Exemple:
solve (x^4+5x^3-3x^2-43x-60 , x,0 {-5,0} ) [ENTER]
should give you the negative root,
solve (x^4+5x^3-3x^2-43x-60 , x,0 {0,5} ) [ENTER]
should give you the positive root.
It is implied that the expression is 0, so you should not insert =0, otherwise you get an error. Here for the lower limit is -5 you must use the change sign symbol (-) under the 3 key, not the regular MINUS.
You may ask how I knew that there were two roots when the equation is a quartic? By first graphing it to have an idea about where the roots lie and how many there are. You should always do that to speed up the search.
There is another way to zoom in on the roots: by drawing the graph and using the tools accessible under the [2nd][CALC] menu, namely the option [2:Zero]
The resolution of the TI83/84 is not good enough for this function that grows too fast, but I am inserting a picture of the curve from another calculator with a much better resolution.
Hope it helps.
Oct 18, 2009 | Texas Instruments TI-83 Plus Calculator
Inequality
You can see images below
Oct 02, 2008 | Texas Instruments TI-89 Calculator
How to use ti 89 with a problem like "-(3x+1)-(4x-7)=4-(3x+2)'
Just plug in one side of the equation and find the answer. Then plug in the other side and compare answers.
Feb 19, 2008 | Texas Instruments TI-89 Calculator
Solving word problems involving linear equation
A positive number is 5 times another number.If 21 is added to both the numbers,then one of the new numbers becomes twice the other number.What are the numbers
Nov 29, 2007 | Computers & Internet
Open Questions:
Your friend John asks you for advice concerning life insurance. John is 32 years old and graduated from law school last year. he currently earns $48,000 per year as a first year attorney. John is married and has two children, Billy, age 10, and Sarah, age 4. John's wife, Mary, is a professor who currently earns $58,000 per year. Mary is 34 years old. John and Mary pay $1,700 per month for their home mortgage, which will be paid off in 20 years. The interest rate on their mortgage is 4.5%. (Their current equity in the home is $75,000.) The couple owns two cars, both 8 years old, and personal property (such as clothes, electronics, furniture, etc.) values at $45,000. Their investments have been used up paying for John's law school education, so they currently have only $1,000 in savings and checking accounts, and $2,000 in a mutual fund. John has no life insurance. Mary has $100,000 of life insurance provided by her employer. mary's pension plus social security are expected to total $45,000 per year, beginning when she is 67 years old. If John should die, Mary would receive approximately $10,000 per year from social security until Sarah reaches age 18. John and Mary spend most of their current income, although they do try to save about $50 per month. Their investments earn approximately 5% per year. In addition to their home mortgage, John has a student loan of $15,000 that he must start making payments on in 6 months. he plans to pau back the loan in 5 years and the loan's interst rate is 6% per year. Given that Mary enjoys a flexible work schedule, and because Mary's mother lives close by and watches the kids two days per week, the currently are not paying any child care expenses.
Nov 22, 2013 | Bagatrix Algebra Solved! 2005 (105101) for...
Bagatrix Algebra Solved! 2005 (105101) for PC Logo
149 people viewed this question
Top Bagatrix Computers & Internet Experts
ali_zulfikar
ali_zulfikar
Are you a Bagatrix Computer and Internet Expert? Answer questions, earn points and help others
