Question about Reddy Heater-170,000 BTU Kerosene Deluxe
Will not start
16500 BTU reddy heater will not start.
Other 16500 reddy heater starts and shuts down after about 5 minutes.
These units are working in a dirty dusty environment.What will plug up and what needs to be cleaned?
  • Anonymous Apr 15, 2009
    how do you check the pump pressure
You need to wash the foam filter, and check pump pressure, if after this pump pressure is not high enough than change the other air filters, re check pump pressure and a just accordingly.
Posted on Feb 27, 2009
Have a Reddy Heater 55,000 BTU unit, when plugged in it will run for about 5 minutes or so and then shut off.
Here are a couple of tips that I wrote that tell you how to troubleshoot a Torpedo or Reddy heater...
Reddy Heater - Troubleshooting Torpedo Heaters
Torpedo Heater Pump Pressure Adjustment
heatman101
Jan 11, 2011 | Reddy Heater-30-55,000 BTU Variable
Reddy heater 40000 btu ker/forcedair plug it in it takes off for a little while then shutsoff
First thing is to download the service manual.
http://www.desaparts.com/service_manuals.html
You need to make sure the filters are clean and that you are getting the proper air pump pressure.
If the units starts up and runs good and slowly goes out it will normally be due to a lack of fuel getting to the nozzle. When there is not enough fuel being delivered to the nozzle from either a clogged fuel filter of dirty air pump output filter the unit will slowly shut down from lack of fuel.
If the unit shuts down while it is running properly and the nose come is orange then you probably have a problem with a photocell or the flame out control.
Thanks
M Cramer
www.allpartsinc.com
Jan 04, 2011 | Reddy Heater-70,000 BTU Kerosene w/T'stat
I have a 100,000 btu reddy heater, and every time I turn it on, it runs for about 5 minutes, then stops, then I have to push the reset button and start it again. Can you tell me where to start? thanx
If it actually ignites and burns but shuts off either the flame sensor is bad (or dirty) or the control is bad. I would verify the flame sensor is clean and had good electrical connections to the controller for starters.
Feb 10, 2010 | Reddy HEATER R115 115,000-BTU PORTABLE...
Unit will start, run about 5 seconds and
You did not state the model numbers of the heaters, so a good guess is all that I can do. Manuals might be available, but models are a must.
By your description the heaters are Hot Surface Ignitor types, opposed to the older technology spark plug heater. Right or wrong? Technology is different & troubleshooting is different.
The heaters are shutting down because the photocell is not seeing the flame, or the flame color is not absolutely correct. The photocell tells the computer to shut the heater down for safety reasons. It's going to be your job to troubleshoot and find out what's wrong.
READ these tips
Jan 06, 2009 | Reddy Heater-30-55,000 BTU Variable
Reddy Heater R 40
the fuel filter is dirty even if it dosent look like it,,they have a high particulate filter and they will stop up pretty quick if you have had a dirty fuel container or just a bad location that you purchased your fuel.
Jan 11, 2008 | Reddy Heater-170,000 BTU Kerosene Deluxe
Readyheater portable forced air 170,000btu/hr
reset switch my heater did the same thing after 5 sec of running
Dec 20, 2007 | Reddy Heater-170,000 BTU Kerosene Deluxe
Reddy Heater-170,000 BTU Kerosene Deluxe Logo
224 people viewed this question
Top Reddy Heating & Cooling Experts
Ronny Bennett Sr.
Ronny Bennett Sr.
Mack Baxter
T bone 1963
Are you a Reddy Heating and Cooling Expert? Answer questions, earn points and help others
