Question about Proscan 19LB30QD 19 in. LCD HDTV/DVD Combo
Unable to get channels 14 through 98.
Just purchased 19" Proscan TV/DVD combo, model #19LB30QD. Did the auto channel programming, however, channels 14 through 98 seem to be locked out. Help!
  • econtreras17 Feb 26, 2009
    Thank you so much. The tuner was set to Air. Once I changed it to cable mode and re-ran the auto channel programming, it worked. Thank you very much for your help!
  • lmoien Mar 24, 2009
    I just brought home a 19" tv/dvd player without manual.
    Would like to know how to get a picture or how to get the dvd palyer going.
    Thanks
    President:
  • Proscan Master
  • 1,779 Answers
Make sure in the menu that you have the tuner set to Cable Mode, then auto program again. Hope this helps.
Posted on Feb 26, 2009
Proscan tv problems
Yes. You should connect the TV with an external antenna, and should do an auto-scan, to search and store all the available channels. Refer its user manual for details.
Jan 28, 2014 | Televison & Video
My 16 year old son found a Proscan 19LB30QD on the side of the road (good old country living) anyway, it has not plugs, it is probably broke, but we thought we'd give it a try and see if it works. ...
Do you mean that the unit has no power cord or is the TV missing the input board from the side? Sears Parts Direct has parts for the Proscan 19LB30QD here: http://www.searspartsdirect.com/partsdirect/part-model/Proscan-Parts/Television-Parts/Model-19LB30QD/3027/0333300/50036238/00001?blt=06&prst=0&shdMod=19LB30QD . The AC cable is PART NUMBER: E080515H00 for $27. There is also an adapter, PART NUMBER: E075WDN1, for $26.79. The input board is part 6 on the diagram (main board).
Other cords will depend on what you want to connect to the TV. There is 1 HDMI port for connecting a set top box, component, composite and S-video jacks (for other set top boxes), a VGA port and a coaxial (antenna jack). Manage My Life has the manual here: http://www.managemylife.com/mmh/owner_manuals/19678/PROSCAN-TV-VCR-or-DVD-Combo-L0807673?brand_name_search=fall+back .
I hope this helps.
Oct 06, 2011 | Proscan 19LB30QD 19 in. LCD HDTV/DVD Combo
Proscan model number 19lb30qd, DVD will not play, lens has been cleaned. Are there replacement DVD players available?
judging on your brand of tv i wouldnt suggest pursuing a fix the cost could be close in comparison with a new tv if your ok with it buy a good quality dvd player to run into the tv im sure you would be happier than spending a pile of money only to end up back where you were ok hope this helps
Nov 17, 2010 | Proscan 19LB30QD 19 in. LCD HDTV/DVD Combo
Unable to get a picture
You may have bad back light inverter baord, check to see if it is getting the 12~18vdc feeding it, also check the fuse (F?) on the inverter board.
http://s807.photobucket.com/home/budm/allalbums
http://en.wikipedia.org/wiki/Capacitor_plague
Jun 28, 2010 | Proscan 19LB30QD 19 in. LCD HDTV/DVD Combo
Have new tv/combo and the tv shows no signal,we hooked up rabbit ears please help
you need to program the channels of your tv.to do it consult your owners manual..go to the menuand select auto program and the tv will automatic seach the channels
May 20, 2010 | SNK Skyworth SLC1963A 19 in. LCD TV/DVD...
Proscan 37 inch LCD 37LB30Q Model
I used a swicher box form monster I plug in my viedo games and cable tv into it and then you run the composit cable which is high def into the tv but the sound into the swicher box the swicher box sound is run into the surround sound you just hit a button and you have the sound go to wall mart has the box for 20 dollars
Jul 08, 2009 | Proscan 19LB30QD 19 in. LCD HDTV/DVD Combo
Unable to get channels after Channel 13.
Go into your menu and make sure the tuner is on Cable, then auto-program....Let me know?
Feb 26, 2009 | Proscan 19LB30QD 19 in. LCD HDTV/DVD Combo
Proscan 19LB30QD 19 in. LCD HDTV/DVD Combo Logo
232 people viewed this question
Top Proscan Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Jaime Hernandez
Are you a Proscan Televison and Video Expert? Answer questions, earn points and help others
