Question about Singer 2517 Mechanical Sewing Machine
I replaced the needle of my machine and now it wont sew
My singer 2517c wont sew. My son removed the needle and i placed it back however the bottom thread is not feeding
  • 10,865 Answers
Http://www.singerco.com/accessories/manuals.html
go to this site to get the manual. please mark this answer as a fixya
Posted on Feb 27, 2009
My needle broke and a piece of metal fell out of machine
just adjust to needle in fix to strait in needle clamp hole it operate to needle strait to hole so needle do nt break but needle is best buy qualtity
Aug 31, 2008 | Brother XR-65t Mechanical Sewing Machine
Sewing bobbin
Found several answers at this site, mostly addressing the tensioner.
Singer Sewing Machine Bobbin thread is bunching up Yahoo Answers
Jan 14, 2015 | Singer Sewing Machines
Singer ultralock 14u64a jumbles thead on bottom
try changing the needle
rethread the top thread-- Correct needle insertion is mandatory for proper use of your sewing machine.
Raise the needle bar to the highest point, then loosen the needle clamp screw to remove the old needle.
Place the new needle in the needle clamp with the flat side of the needle facing the back, (round needle, the groove in the needle should face away from the shaft).
Push the needle all the way up as far as it will go. Then tighten the needle clamp screw.
also check the bobbin to make sure that it's threaded correctly
& inserted correctly into the bobbin case
Jun 03, 2012 | Singer Sewing Machines
Remove sewing maqchine case
Plate on bottom: Remove screws. Keep screws in safe place and oil moving parts with good quality sewing machine oil. Zoom with spout for sewing machines & servers is what I use purchased online...lubricate gears with Singer lubricant (in tube). Tip machine back onto a towel to remove screws. Just one drop oil on moving parts & dot of lube gear only if not showing signs of grease already. Please remove bobbin and presser foot before cleaning/oiling. One drop oil then generously SMEAR oil on oscillating hook, open right front door & one drop top of needle bar. Clean out race shuttle for lint, fuzz balls, broken threads with soft sewing machine brush & clean your feed dogs gently with bristles too. Hope this helps. Do not clean machine near children or curious pets! I run my machine with pedal on table top so I don't accidentally step on it. Control with right hand to see moving parts. At your own risk, of course. Safe and effective but only if you are extremely careful. Replace all screws securely. Put in new needle all the way UP into needle bar groove, presser foot UP turning handwheel towards you, flat end of needle to back, Thread Front to Back of needle.. Keeping presser foot raised @ highest position ensures thread locates the tension slots properly. Jimmy
Apr 07, 2012 | Singer Sewing Machines
It is a singer quantum futura ce 200 sewing and embroidery machine .the machine sews but incomplete,skipping and missing stiches. does not always bring up bottom thread . grrrrr---help, i want to sew
Sewing machine skips stitches
1.needle inserted incorrectly--flat side of the needle faces the shaft
round needle--groove of needle faces away from the shaft
2.Correct needle insertion is mandatory for proper use.
Raise the needle bar to the highest point, then loosen the clamp screw to remove the needle. Place the new needle in the clamp with the flat side of the needle facing the back of the machine.
If round needle--the groove in the needle faces away from the shaft
Push needle all the way up to the stop or as far as it will go.
3.possible bent needle--lay needle on flat surface & roll needle over, if the needle does not roll good -replace
4.blunt needle point--needle makes a popping sound when needle penetrates the fabric--replace needle
5.needle not all the way up in needle holder--loosen needle clamp screw & push the needle up until it stops then tighten screw
6.incorrect threading--one step missed in sequence of threading can cause machine to skip stitches
7.wrong needle in machine--check instruction manual--some machines can use a generic needle with no problem--some can't--
8.size of needle & thread not compatible--
Using the wrong type needle can cause problems,,
A needle to fine for heavy fabric can bend or break when it hit's the fabric
And a too large needle can make puncture holes in the fabric and pull unevenly while stitching
Sep 14, 2011 | Singer CE-200 Quantum Futura Computerized...
Singer 2517c -I need Threading instructions please. Also the top thread is loose -how do I fix that
Lift the needle to the highest point by turning the handwheel. Lift the pressure foot to release the tension on the system. Place the spool on the spool pin and put the spool cap on to hold the spool firmly.
Next bring the thread to the thread guide and snap it into the guide. Then slide the thread under the guide and through the slot (use one hand). Next lead the thread down on the right of the tension knob and up on the left. This puts the thread in the tension discs. Next slip the thread into the take up lever. (Bring the thread to the top of the lever and back towards the machine. Then slide the thread into the slot on the take up lever and then back towards you.
Next lead the thread through the next pair of guides. One is on the machine below the take up lever; the other is attached to the needle holder.
Finally thread the needles from front to back.
First check if there is a slight drag on the upper thread when you pull it through the machine (pulling it under the foot of the machine). Move the tension knob to the right to increase the tension. When you stitch a test piece, your top thread is visible on the bottom of your sewing thread, rotate the tension knob to the right by half a turn (get the dot closer to a higher number).
If there is no change in the tension as you turn the knob, take the machine for service. The springs in the tension system may need to be replaced.
The manual is available from Singer here: http://www.singerco.com/accessories/manuals.html . Enter only the 2517 model (leave off the c). A pdf is available for free; there is also an option to order a hard copy. A picture of the threading route is on page 28 of the pdf (page 26 as the manual is numbered).
I hope this helps.
May 12, 2011 | Singer 2517 Mechanical Sewing Machine
I do not know how to adjust the tension on my singer sewing machine model # 2517C. please assist.
it should be right in front on the left of the machine small round knob or dail... going from 0123or 0-1-2-3 what is your problem not sewing good on top of material or bottom of material.... take out bobbin put back in change needle... re-thread the machine... sometimes it isnt the tension but just a odd thread in the bobbin case or too much lint from the fabric.... do you use it alot.... hope this helps...
Oct 26, 2010 | Singer 2517 Mechanical Sewing Machine
I dont know how to thread the singer 2517c sewing machine
all machines thread the same. TTN tension, take up, needle.
Beginning with the spool, guide the thread through the thread guides to the tension assembly. Pull the thread through the tension assembly and test it to make sure the tension is working correctly.
(To do this test, adjust your tension setting to normal or medium or 5 or something in the middle. Raise the presser foot and pull the thread through the tension. It should pull easily!! Lower the presser foot and pull the thread. It should pull noticeably harder.) If it passes this test, continue up through the take up lever,then down through the thread guides to the needle. Make sure your needle is fully inserted and turned the correct way.( If you load your bobbin case from the left side,the needle rule is normally FLAT to the RIGHT is RIGHT. There are some exceptions. If you have a newer style drop in bobbin or your bobbin case loads in the front then the rule is FLAT to the BACK.
sewman7
Jun 30, 2008 | Singer 2517 Mechanical Sewing Machine
Jammed
ROLL THE MANUAL LEVER BACK AND FORTH WITH CONTROLLED FORCE till the needle comes out! the jamming is caused by threads tangled inside the bobbin area. rolled it with a controlled force back and forth. when the needle comes out flip your machine to where you could open the bottom part and remove/clean the threads tangled on the bobbin!
place some OIL.
Nov 19, 2007 | Singer 1116 Mechanical Sewing Machine
Singer 2517 Mechanical Sewing Machine Logo
184 people viewed this question
Top Singer Sewing Machines Experts
Tally Girl
Tally Girl
mystery_soul
Are you a Singer Sewing Machine Expert? Answer questions, earn points and help others
