Question about Audiovox D1020 Portable DVD Player
Audiovox D1020 will not power on?
When I plug my Audiovox D1020 in the cigarrette lighter or electric socket, red lights come on at the bottom of the dv player.When I press play nothing happens.
I have a unit with a broken screen that I am trying to find a replacement for. (one with a good screen) Please email me and let me know if you are willing to sell yours. Thanks
buckeyevcr@aol.com
Posted on May 07, 2009
Both my cigarrette lighter and my rear 12v power socket have no power. fuse -f9-is okwhat else can be wrong
Check the schematic for it to see just what is feeding the circuit . And do not overlook the ignition switch circuit - on may cars that socket is dead unless the ignition is on.
Sep 11, 2015 | 2008 Peugeot 308 1.6
How do i bypass the ignition switch on a renaulit modus car
I obtained a extra lighter socket . run 4mm wire from socket to starter motor solenoid (big terminal) with 20 amp inline fuse , earth socket metal body to the metal frame. works like a charm and have not had to change other wiring.
Sep 17, 2014 | 2005 Renault Modus 1.6
All my power outlets and cigarrette lighters don't work in my 2005 jeep grand Cherokee. I've checked and swapped out fuses and it stoo don't work. What else can I check?
sometimes these are on a circuit breaker check with a test light for power in the center of your socket then be sure to check the ground if no ground or power always go back to source this circuit may even have a relay
Aug 01, 2012 | 2002 Jeep Grand Cherokee
My cigarette lighter won't work. Either the unit is burnt out; the fuse is blown or??? I need to fix this as I need a place to plug my cell phone/computer charging stuff. Any help is gr8!
if you don't need the lighter itself to light up cigarrettes, then get rid of the lighter and using a test light or meter, make sure there is power inside thesocket where the lighter plugs into. if power is already there, then your done and ready to go, if power is not there, then check for an open fuse in your fuse panel...some lighter go directly to the battery, in that case make sure that the wires are not broken somewhere between the lighter socket and the battery
Aug 15, 2009 | 2001 BMW Z3
Stripes on the right side of my Audiovox D1020
Hi..
If the player does this on any DVD then, I'm sorry to say, the screen is broken and it's cheaper to buy a new one.
Jan 08, 2009 | Audiovox D1020 Portable DVD Player
Cigarrette lighter wont work
using a test light touch each side of all the fuses one at a time lift seide then right side of fuses. if power on only one side then bad fuse. this fuse should be the same as the radio or acc fuse. also check power to the back of the socket as this connection sometimes burns out.
Ps dont forget to rate the solution. Thanks
Dec 28, 2008 | 1995 Toyota Corolla
Audiovox D1020 DVD player won't read DVD anymore
I have the same problem! The only way to fix this is to replace the motor that spins the DVD. if you take it apart and spin the DVD the movie will play. The motor is just wore out and has no torque to start the play process. I am still looking for a replacement motor for it and haven't found anyone that carries the motor required. Only Audiovox so far and they want 180 to send in and fix.
Nov 16, 2008 | Audiovox D1020 Portable DVD Player
Problem with white screen
Similar experience with a D1020. A very small component on a surface mount PCB developed a cold solder joint and eventually came off altogether. If you have a small low power soldering iron and experience with very intricate soldering, you can attempt a repair. Do not imagine that a repair shop can repair for a reasonable expense.
Sep 06, 2008 | Audiovox D1020 Portable DVD Player
Rwr supply
Buy an adapter such as the one in this link to convert AC power to a 12V "cigarette Lighter" outlet.
http://www.amazon.com/Universal-Cigarette-Lighter-Socket-Adapter/dp/B000EG8RIM/ref=sr_1_5?ie=UTF8&s=wireless&qid=1207184215&sr=8-5
Feb 06, 2008 | Audiovox PVS72901 Portable DVD Player
Audiovox D1020 Portable DVD Player Logo
135 people viewed this question
Top Audiovox Televison & Video Experts
Jaime Hernandez
Are you an Audiovox Televison and Video Expert? Answer questions, earn points and help others
