Question about Apple iPod shuffle Second Gen. Silver (1 GB) MP3 Player (MA564LL/A)
Accidently copied a lot of foto`s to my ipod shuffle from a usb-stick. How do I get them out?
  • 62 Answers
Plug it in your computer get the files then remove them
Posted on Feb 26, 2009
Wen i connect my i pod to computer it does not connect
Check to see whether your iPod shuffle is the original stick version or the newer version, which plugs into the iPod dock connector.
Turn your PC on.
The PC needs to be on to transfer music and charge the iPod shuffle.
Place the iPod shuffle in the iPod dock connector if you have the newer version.
If you're using the original version, then plug it directly into a high-power USB port on your PC.
Check the monitor to ensure iTunes has loaded.
This means a connection was established.
hope this helps
Oct 11, 2012 | Apple iPod shuffle MP3 Player
How do you charge an ipod shuffle
Connect the included USB cable to your iPod Shuffle.
Plug the opposite end of the iPod Shuffle cable into an open USB port on your computer, which must be turned on.
Check the light on the iPod Shuffle. If the light has turned on, the iPod Shuffle is properly charging.
Using iPod charger
Plug the iPod charger into a working electrical outlet.
Plug the opposite end of the iPod Shuffle cable into the USB port on the iPod charger.
The iPod Shuffle should begin charging immediately.
hope this helps
Sep 18, 2012 | Audio Players & Recorders
NEED INSTRUCTION FOR Apple iPod shuffle 3rd Generation Silver
Connect the iPod shuffle USB cable connector into a high-power USB port on your computer.
Note: To charge an iPod shuffle battery, connect the device to a high-power USB port.
Please be aware that USB keyboards and non-powered USB hubs generally do not have high-power USB ports.
If you connect to a low or non-powered port, iPod shuffle will not charge.
The computer must be turned on and set to not go to sleep.
Plug the other end of the iPod shuffle USB Cable into the headphone port on the iPod shuffle.
Verify the iPod shuffle is connected securely.
Once the iPod shuffle is plugged in, it will take about 2 hours to charge the battery to 80% capacity and about 3 hours to charge it to 100%.
Find out how to check the battery charge here
hope this helps
Sep 18, 2012 | Apple iPod shuffle 3rd Generation MP3...
How do I re charge battery with electrical plug
To charge the battery using your computer:
Connect iPod shuffle to a high-power USB port on your computer using the included iPod shuffle Dock. The computer must be turned on and not in sleep mode (some models of Macintosh can charge iPod shuffle while in sleep mode). When the battery is charging, the status light on iPod shuffle is orange. When the battery is fully charged, the status light turns green.
If you don't see the status light, iPod shuffle might not be connected to a high-power USB port. Try another USB port on your computer.
To charge the battery using an iPod USB Power Adapter If you do not have then you have to buy the same from Apple Store) 1 Connect the AC plug adapter to the power adapter (they might already be connected). 2 Plug the USB connector of the iPod shuffle Dock into the power adapter. 3 Plug the power adapter into a working electrical outlet. 4 Put iPod shuffle in the dock. You can disconnect and use iPod shuffle before it is fully charged.
Apr 05, 2011 | Apple iPod shuffle MP3 Player
How do i turn on my ipod shuffle?.......and how long do i charge the battery for?... and how do i know my ipod is fully charged?
  • first i will cover turning the unit on. then i will cover how to charge the unit.
    -Move the power switch on the top of the iPod Shuffle to the "Normal" or "Shuffle" position.
  • Press the play button on the iPod Shuffle to begin music playback. If the iPod does not begin to play, follow the rest of the instructions.
  • Plug the iPod USB cable into the bottom of your iPod Shuffle and then connect the other end of the cable to your iPod power adapter.
  • Plug the iPod power adapter into a standard electrical outlet to charge the iPod Shuffle's battery. Try to press the play button again.
  • Connect the iPod Shuffle to your Mac or PC computer using the iPod USB cable. Then, open the iTunes program on the computer and sync your iPod with your music library. If your iPod Shuffle was frozen, it should now turn on.
  • to tell if the ipod shuffle is charging. Eject iPod shuffle in iTunes, but leave it physically connected to the USB port. The front LED should be orange if it's charging (or green if it's fully charged). If it's not charging (such is the case if it's connected to a low-power USB port on a keyboard), you won't see a front LED. If you need further assistance please feel free to follow up with a comment and i will be here to assist you. If this assisted you please feel free to rate the comment. thanks and have a great day.
    Aug 25, 2010 | Apple iPod shuffle Second Gen. Silver (1...
    How to remove foto`s from my ipod shuffle
    Well, a common problem. Generally, you can not delete the songs on your iPod directly even with the help of iTunes. Because when you sync with the iPod, it will be deleted when the sync is finished. Find a third party to help you is a wise choice! Many such applications on the Internet when you Google for it. 4Media iPod to PC Transfer is one of the most popular and recommendable software. It can can efficiently manage your iPod contents to help you do the iTunes can not do things!
    Feb 27, 2009 | Apple iPod shuffle Second Gen. Silver (1...
    I hooked up my childs new ipod with usb cord now it's flashing orange what next
    go to Apple.com and download a copy of iTunes. Install the music with that program.
    Oct 29, 2008 | Apple iPod shuffle Second Gen. Silver (1...
    Usb driver for ipod shuffle
    Make sure you followed the installation instructions to the letter.
    Then try the 5 R's
    See manual for details
    Sep 05, 2008 | Apple iPod shuffle Second Gen. Silver (1...
    IPod shuffle 1st gen. Not Recognized By PC
    Try a different USB port first. Here are some other suggestions:
    Connect iPod shuffle to a high-power USB port on your computer. iPod shuffle may
    need to be recharged.
    â Make sure you have installed the latest iTunes software from
    www.apple.com/ipod/start.
    â Try connecting to a different USB port on your computer. Make sure iPod shuffle is
    firmly seated in the dock. Make sure the USB connector is oriented correctly. It can be
    inserted only one way.
    â iPod shuffle might need to be reset. Turn iPod shuffle off, wait five seconds, and then
    turn it back on again.
    â If there is no status light (or the status light is dimmed) and iPod shuffle doesn’t
    appear in iTunes or the Finder, the battery may be completely discharged. Let
    iPod shuffle charge for several minutes to see if it comes back to life.
    â Make sure you have the required computer and software. See “If you want to doublecheck
    the system requirements” on page 25.
    â Try restarting your computer.
    â If none of the previous suggestions solves the problem, you might need to restore
    iPod software. See “Updating and Restoring iPod shuffle Software” on page 26.
    â If restoring iPod shuffle doesn’t solve the problem, iPod shuffle may need to be
    repaired. You can arrange for service on the iPod shuffle Service & Support website at
    www.apple.com/support/ipodshuffle/service.
    Jun 09, 2008 | Apple iPod shuffle MP3 Player
    IPod Shuffle and compatibility with USB ports
    yes it's a common problem, it might be a usb 2.0 or high speed usb port but the motherboard is unable to supply enough ampage to supply the port. Assuming you have tried removing other usb connected peripherals and tried a different port, the only way you may get the ipod to connect is to purchase a mains powered usb hub as the power supplied is sufficient to connect to ipods and pda's etc.
    Sep 10, 2007 | Apple iPod shuffle MP3 Player
    Apple iPod  shuffle Second Gen. Silver (1 GB) MP3 Player (MA564LL/A) Logo
    19 people viewed this question
    Top Apple Audio Players & Recorders Experts
    TO Lady
    Are you an Apple Audio Player and Recorder Expert? Answer questions, earn points and help others
