Question about KitchenAid KGSI901PBS Gas Kitchen Range
Ignitors wont shutoff
I have a Kitchen-Aid stove with gas cooktop. The ignitors click and stay on after the burner is shutoff.
  • raridon160 Feb 27, 2009
    Thanks I'll try that
  • KitchenAid Master
  • 5,568 Answers
The common way to control the ignitors is a cam on the individual shafts acting on a 'normally open' switch that is depressed in the ignition position. One of these switches has failed and no longer able to return to its normally open condition.
You may be able to locate the defective one by 'exercising' each control back and forth past the ignition position to see if one of them will cause the ignitor to stop. You may have had a spill that has allowed food liquids to gum up the switch.
Posted on Feb 26, 2009
AGR5844VDW oven not lighting
Most modern ovens have a glow bar ignitor, not a spark ignitor. It will glow a bright orange and then the oven valve will click open and allow gas through and the burner lights. Many gas ovens have a small shutoff handle located on the silver appliance regulator, which is located either behind the stove or at the bottom behind the oven drawer. Make sure it has not been accidentally closed. It will cut off gas to the oven only.
Apr 16, 2014 | Amana AGR5844VDW 5.0 cu. ft. 30" Self...
Ignitor for burner not working
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
Here is a tip that I wrote to give details about why your cooktop will not spark to light the burners..
Cooktop Range Stove spark ignition does not work
heatman101
Sep 02, 2010 | Jenn-Air JGS9900BDS Stainless Steel Gas...
Spark ignitors on gas stovetop wont stop sparking
Make sure yo haven't spilled liquid on the ignitor becuase this will cuase all ignitors to spark constantly. If all is dry, the spark module must be replaced.
Feb 15, 2009 | Cooktops
Oven and broiler won't come on. Cooktop burners are fine.
Have you run the self-cleaning feature recently? I had a similar problem on my stove of the same model, and it was the switch that detects whether the oven latch is engaged (if it gets stuck and thinks the latch is locked, it will not ignite the main burner or broiler). An easy way to check if that's the problem: without touching the latch, turn the controls to Clean. If the burner lights, that is your trouble.
Jan 24, 2008 | Hotpoint RGB745 Gas Kitchen Range
KitchenAid KGSI901PBS Gas Kitchen Range Logo
153 people viewed this question
Top KitchenAid Kitchen Ranges Experts
Colin Stickland
Colin Stickland
Dan Webster
Dan Webster
Are you a KitchenAid Kitchen Range Expert? Answer questions, earn points and help others
